Old 02-17-2013, 06:33 PM   #1
Jacob G.
Jacob G.'s Avatar
Drives: '13 Scion FR-S Whiteout
Help Morimoto HID kit
So I recently received a morimoto HID kit and went to install it to find out it has mounting brackets instead of the 3M adhesive tape... Where do I attach these? Do I need to get the tape? Of course it doesn't come with directions and the ones on TRS website don't mention mounting the ballast
Jacob G. is offline   Reply With Quote
Old 02-17-2013, 07:11 PM   #2
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
You can just drill a hole anywhere or use an existing hole to mount the bracket, no real need for a install guide..
If I were you though, I'd just get some 3M automotive mounting tape like this or at O'Reilly/Autozone:
[ame="http://www.amazon.com/3M-03614-Scotch-Mount-Molding-Tape/dp/B002JOVUO0/ref=sr_1_1?ie=UTF8&qid=1361146157&sr=8-1&keywords=3M+automotive+mounting+tape"]3M 03614 Scotch-Mount 1/2" x 15' Molding Tape : Amazon.com : Automotive[/ame]
Clean the surface of the ballast and location in your engine bay, slap on the 3M tape, and stick it somewhere. I've been through about 3+ HID kits that came with mounting brackets. I just used my own 3M tape to mount it anywhere I wanted. Threw away the brackets it came with.
If you want a really strong bond, use 70% isopropanol (rubbing alcohol) to clean the surfaces, press the ballast down for at least 1 minute when mounting while using a hair dryer to heat up the double sided tape. Gonna be honest though, my very first HID kit, I didn't clean anything, pressed it down for a few seconds (no heat used) - and it held up for 5 years until I sold the car.
cdo221 is offline   Reply With Quote
Old 02-17-2013, 07:42 PM   #3
Jacob G.
Jacob G.'s Avatar
I'm not ready to drill into my car so I'm going to pick up some 3M tape tomorrow. Is 91% alcohol ok or do I need the 70% for some reason? I just already have 91%... Thanks
Old 02-17-2013, 10:49 PM   #4
cdo221
91% is fine in this case since you're not using it on any painted surfaces, just make sure it's completely dry before stick on the tape (it'll evaporate fast with a few wipes anyway).
I just keep 70% around to use on my car paint to strip off wax or other surface protectants when I'm mounting a trunk lip w/ 3M tape or something - too high percentage is supposedly bad for your car paint.
Old 02-18-2013, 02:03 AM   #5
kanundrum
Drives: 2013 Whiteout FR-S
Use Zip Ties, they are more secure
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 12:04 AM
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
Other distributors of Morimoto Products than TRS Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 0 01-12-2013 09:46 AM
H11: MORIMOTO ELITE HID SYSTEM FRS-PR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-24-2012 05:47 PM
Any chance of a group-buy on TRFS Morimoto Retro-Quik? SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 2 07-20-2012 01:06 PM
