#15 |
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
There was no visible difference between the high beam lever on (flash to pass) and DRL level. The threshold is presumably too high to allow the advertised function.
It's too bad, the product seems to be of high quality, shipping snd service were excellent. Just not a good fit for this specific application. |
#16 | ||
Is not fast.
Drives: 2014 Whiteout M/T
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#17 |
Seems reasonable, but I imagine doing this right (no consequences to the high beam function) might be a little more complicated than simply wiring in a resistor.
Then again, it's been quite a while since I found myself falling asleep in EE101, and I couldn't diagram a Norton/Thevenin equivalent diagram anymore if you put a gun to my head. And even if solved, it doesn't make up for the donut hole in the pattern. |
#18 |
Drives: 2015 Ultramarine FR-S
#19 |
Is not fast.
Unfortunately, we haven't seen rain in Southern California in many moons. We're almost to the point of making live sacrifices.
| The Following User Says Thank You to Manic For This Useful Post: | SlammedSilly (09-07-2016) |
#20 |
Drives: 2013 Firestorm FRS
also, I will have review of high beams with 2strokes at night soon...just got the driveshaft installed in the car lol, so I'll be able to test soon.
| The Following User Says Thank You to continuecrushing For This Useful Post: | SlammedSilly (09-07-2016) |
#21 |
#22 |
not yet-I did drive the car at night, and the high beams are epic-but I also have a retrofit so I get a "high beam" from my low beams.
One thing for certain-the instant on from the high beams is absolutely noticeable. I had the stock halogens in there before, and although they turn on quickly, the leds now are RIGHT NOW on haha. |
| The Following User Says Thank You to continuecrushing For This Useful Post: | SlammedSilly (09-21-2016) |
#23 | |
#24 | |
When I get the chance, i'll probably just pull the low beam wire, and do a comparison of stock halogen vs led (but high beams only) |
| Morimoto LED Fogs | Struckbylitenin | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 08-08-2014 11:53 AM |
| 6K H11 Morimoto HID Kit | Zero90 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 05-20-2014 12:49 PM |
| Stroke saving, room giving front camber plates please. | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 01-31-2014 04:34 PM |
| Possible crickets fix? Adding a capfull of synthetic 2 stroke oil per tank full? | mike the snake | Issues | Warranty | Recalls / TSB | 29 | 09-29-2013 04:29 PM |
| Help Morimoto HID kit | Jacob G. | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-18-2013 02:03 AM |
