#15 | |
Drives: BRZ DGM Limited
Have never seen that before. But if you bought the 2013 just 2 months ago, you really don't know what may have happened to it before you owned it. |
#16 |
Drives: FRS RED
and yes, Toyota Canada said this is not guaranteed.
So I brought the car to my house and I repair it myself. Finally as I thought the fans motors working well. only 2 fans was broken (2x 31$ each). Here are pictures of the broken fans: ![]() The center have not the same size (height): ![]() ![]() ![]() ![]() ![]() Here are pictures of the new fans: ![]() ![]() ![]()
#17 | |
This one still intrigues me since both went the same way at the same time and that is a rare occurrence in an equipment failure.
#18 |
Drives: FRS RED
No hit or impact, Juste a heavy scrape (the fan fall on turning)
& scrape on Rad |
#19 |
Drives: FRS RED
stripped because of the retaining something ?!?
retained by the ice ?!? |
#20 |
Wouldn't think so. If just held solid the electric motors wouldn't have enough start up torque to even move. Would probably just blow a fuse. The only way I can see is if the fans were both suddenly stopped by something blocking the blades but that should have left ovious Impact marks. I am truely baffled but don't want to go jamb something in my fans to find out.
#21 |
I'll hazard a guess. Fatigue failure from running out of balance.
#22 | |
Do the fan shafts run true.. ?? If not, that would show up when you put the new blades on. Like Tcoat mentioned, both going out at the same time puzzles me. Were you "hot rodding" the fans ??...... ![]() humfrz |
#23 |
Aw hell, I don't know. Maybe one cracked slowly and finally failed. Then it collided with the second one and took it out.
#24 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (09-03-2016) |
#25 |
Would guess front end damage from a previous accident
| UPDATED!!! Ohio Route 555/26, October 20th 2013: Fall Colors Meet!! | HunterGreene | Great Lakes | 211 | 04-16-2014 09:34 AM |
| Mach V Fall Dyno Night 2013: 9/27/13 | Mach V Dan | Mid-Atlantic | 6 | 09-25-2013 08:25 PM |
| Any F1 fans here? | Shipwreck | Hawaii | 6 | 04-09-2013 02:56 PM |
| Any e30 fans here? | streetwaves | Other Vehicles & General Automotive Discussions | 83 | 12-12-2012 11:30 AM |
| Any UFC fans? | Enemies | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 06-25-2012 11:21 PM |
