Old 08-30-2016, 08:07 PM   #15
BRZnut
Drives: BRZ DGM Limited
Originally Posted by jefars View Post
Nothing is broken except the center of Blades.
I bought my FRS 2 months ago.
it's a car back 3 years.
I had air conditioning problems since day 1.
I found the non-functional fans because the engine overheated and the check engine has Alume
The dealer said it can not be guaranteed because the radiator is not part of the motor.
dealer diagnostic = 69$ + 39$ +tx
repair (by dealer) = 500$ + tx
I expect a response from Toyota Canada
Have never seen that before. But if you bought the 2013 just 2 months ago, you really don't know what may have happened to it before you owned it.
The Following 2 Users Say Thank You to BRZnut For This Useful Post:
skye67 (08-31-2016), Tcoat (09-02-2016)
Old 09-02-2016, 07:11 AM   #16
jefars
Drives: FRS RED
and yes, Toyota Canada said this is not guaranteed.
So I brought the car to my house and I repair it myself.
Finally as I thought the fans motors
working well.
only 2 fans was broken (2x 31$ each).
Here are pictures of the broken fans:
The center have not the same size (height):
Here are pictures of the new fans:
jefars is offline   Reply With Quote
The Following 2 Users Say Thank You to jefars For This Useful Post:
humfrz (09-03-2016), Tcoat (09-02-2016)
Old 09-02-2016, 08:28 AM   #17
working well.
Any visible signs that they may have hit something? I see a black mark in the top left corner of your pic that may be an impact. Of course it could also be from them wobbling but there could be a larger mark someplace. Pretty hard for something to get up in there for them to hit but not impossible.
This one still intrigues me since both went the same way at the same time and that is a rare occurrence in an equipment failure.
Old 09-02-2016, 10:23 AM   #18
jefars
Drives: FRS RED
No hit or impact, Juste a heavy scrape (the fan fall on turning)
& scrape on Rad
Old 09-02-2016, 10:24 AM   #19
jefars
Drives: FRS RED
stripped because of the retaining something ?!?
retained by the ice ?!?
Old 09-03-2016, 12:09 AM   #20
Wouldn't think so. If just held solid the electric motors wouldn't have enough start up torque to even move. Would probably just blow a fuse. The only way I can see is if the fans were both suddenly stopped by something blocking the blades but that should have left ovious Impact marks. I am truely baffled but don't want to go jamb something in my fans to find out.
Old 09-03-2016, 12:31 AM   #21
I'll hazard a guess. Fatigue failure from running out of balance.
Old 09-03-2016, 12:48 AM   #22
I kind of like that theory.
Do the fan shafts run true.. ??
If not, that would show up when you put the new blades on.
Like Tcoat mentioned, both going out at the same time puzzles me.
Were you "hot rodding" the fans ??......
Old 09-03-2016, 01:01 AM   #23
Aw hell, I don't know. Maybe one cracked slowly and finally failed. Then it collided with the second one and took it out.
Old 09-03-2016, 01:09 AM   #24
Well, now that sounds reasonable ......
Too bad we will never know ........
Ultramaroon (09-03-2016)
Old 09-03-2016, 07:15 AM   #25
BRZnut
Would guess front end damage from a previous accident
UPDATED!!! Ohio Route 555/26, October 20th 2013: Fall Colors Meet!! HunterGreene Great Lakes 211 04-16-2014 09:34 AM
Mach V Fall Dyno Night 2013: 9/27/13 Mach V Dan Mid-Atlantic 6 09-25-2013 08:25 PM
Any F1 fans here? Shipwreck Hawaii 6 04-09-2013 02:56 PM
Any e30 fans here? streetwaves Other Vehicles & General Automotive Discussions 83 12-12-2012 11:30 AM
Any UFC fans? Enemies Off-Topic Lounge [WARNING: NO POLITICS] 13 06-25-2012 11:21 PM
