Old 08-30-2016, 07:23 AM   #1
jefars
Drives: FRS RED
FR-S 2013 fans Blades fall
The Blades of TWO radiator fans have fallen.
WTF
I am the only one?
video:
http://vid433.photobucket.com/albums...psudk6wafa.mp4
jefars is offline   Reply With Quote
Old 08-30-2016, 07:31 AM   #2
First I have seen!
All stock? No accidents or front end work?
Old 08-30-2016, 07:48 AM   #3
jefars
Drives: FRS RED
First I have seen!
yes
All stock & No accidents
Old 08-30-2016, 08:04 AM   #4
Originally Posted by jefars View Post
yes
Very odd. Get some pics once apart if you can. I am very curious as to the failure mode.
Can't see any sign of blade damage or impact in the video.
Old 08-30-2016, 08:37 AM   #5
jefars
Drives: FRS RED
Nothing is broken except the center of Blades.
I bought my FRS 2 months ago.
it's a car back 3 years.
I had air conditioning problems since day 1.
I found the non-functional fans because the engine overheated and the check engine has Alume
The dealer said it can not be guaranteed because the radiator is not part of the motor.
dealer diagnostic = 69$ + 39$ +tx
rent car = 20$ per day
repair (by dealer) = 500$ + tx
I expect a response from Toyota Canada
Old 08-30-2016, 08:54 AM   #6
Nothing is broken except the center of Palms.
"Palm" est pas le bon mot. Devrait etre "blade" ou simplement "fan".
Old 08-30-2016, 10:14 AM   #7
jefars
Drives: FRS RED
Merci
(Thanks)
Old 08-30-2016, 10:17 AM   #8
Merci
(Thanks)
Pas de probleme
Sorry for no accents I am too lazy to change the keyboard settings and don't know the function keys to get tem.
LOL and my spell check now hates me even more than normal.
Old 08-30-2016, 10:25 AM   #9
Icecreamtruk
Drives: Track preped NA FRS
Pas de probleme
Ctrl+Shift switches your current keyboard language settings to the next one available, if you have only two, it will switch back and forth, if you have more it will go thru it like a list from top to bottom.
Old 08-30-2016, 10:27 AM   #10
All these years and it was that simple!
Old 08-30-2016, 10:54 AM   #11
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Tu est Le Dumb!!!
Stang70Fastback is offline   Reply With Quote
Old 08-30-2016, 11:10 AM   #12
Originally Posted by Stang70Fastback View Post
Tu est Le Dumb!!!
Old 08-30-2016, 12:40 PM   #13
humfrz
That's spooky ......
I'm guessing that the nut/clip/whatever that holds the fan to the motor shaft came off. But, both at the same time ..... ??
Maybe they were taken off to fix something else and never put back on proper .. ??
Please let us know what was the cause after they are taken off.
humfrz
Old 08-30-2016, 02:26 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Toyota of Canada will tell you the same thing.
Radiator fans fall under bumper to bumper warranty, it's not powertrain.
-alex
UPDATED!!! Ohio Route 555/26, October 20th 2013: Fall Colors Meet!! HunterGreene Great Lakes 211 04-16-2014 09:34 AM
Mach V Fall Dyno Night 2013: 9/27/13 Mach V Dan Mid-Atlantic 6 09-25-2013 08:25 PM
Any F1 fans here? Shipwreck Hawaii 6 04-09-2013 02:56 PM
Any e30 fans here? streetwaves Other Vehicles & General Automotive Discussions 83 12-12-2012 11:30 AM
Any UFC fans? Enemies Off-Topic Lounge [WARNING: NO POLITICS] 13 06-25-2012 11:21 PM
