08-26-2016, 11:53 AM | #183 | |
Proud of BOXER
Drives: Subaru Boxer
Here's your problem. Don't try to accelerate in third gear at 2k rpm.
The Following User Says Thank You to Clipdat For This Useful Post: | Brandond15 (08-26-2016) |
08-26-2016, 01:03 PM | #184 | |
Also, new clutches need time to break in .... they act sort of ragged till they get smoothed off. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Brandond15 (08-26-2016) |
08-26-2016, 04:22 PM | #185 | |
Doesn't shed any light. Have only done it about 3-5 times before in the car, and every time I would just down shift. Trust me, I like having the revs higher up. It's just that I was told to keep the revs low for 1,000 miles for the break in period. They suggested I shift at 3.5k rpms so that's exactly what I'm doing. I must have just given it too much gas that one time. |
08-26-2016, 04:36 PM | #186 | |
Proud of BOXER
I'm glad you finally got your car back. Keep us updated on how it goes day to day with the new motor.
I think by keep the revs down they probably just meant don't go redlining it in every gear or doing throttle blip rev matched downshifts as you approach every stop light or something else that could be considered hard on the clutch. More important than keeping the revs down, I would say would be driving the car in a "smooth" fashion. Meaning, listen to the auditory response your motor is giving you and shift when it's easy/natural for it. It's not a very good rule to "always shift at 3.5k no matter what". Just feel the car, listen to it's feedback, and give it smooth inputs and the break-in process will be fine.
08-26-2016, 04:37 PM | #187 | |
Drives: Track preped NA FRS
The Following User Says Thank You to Icecreamtruk For This Useful Post: | Brandond15 (08-26-2016) |
08-26-2016, 04:38 PM | #188 | |
Yeah that's true, makes more sense when you say it that way. I'll definitely drive it smoothly! Thanks for the tips! |
08-26-2016, 05:03 PM | #189 |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
The Following User Says Thank You to billwot For This Useful Post: | Brandond15 (08-26-2016) |
08-26-2016, 05:45 PM | #190 |
Drives: '13 FRS - STX
^OP has taken that incredibly well, credit to you.
imo the engine doesn't lug at >2k rpm no matter the gear or loading, sure it'll be slow as dog stink but it does sound like there's some little quirk still needing to be ironed out. |
The Following User Says Thank You to strat61caster For This Useful Post: | Brandond15 (08-26-2016) |
08-26-2016, 06:17 PM | #191 | |||
Wait... Wait... You went through all this hassle because the dealers said there were aftermarket parts on the car and then you had the dealer install aftermarket parts on the car? Kiss that warranty goodbye if they decide to blame the new flywheel for any future engine issues. Oh and like the others said you were lugging the crap out of it at 2K in 3rd.
The Following User Says Thank You to Tcoat For This Useful Post: | soulreapersteve (08-26-2016) |
08-26-2016, 06:22 PM | #192 | |
The aftermarket parts they were referring to had to be something like a turbo or supercharger. They wouldn't deny warranty for stuff that wouldn't cause the engine to fail like that. Also, I bought OE flywheel and clutch. Asked them if I could supply the flywheel and clutch and they said it was perfectly fine, won't mess with my warranty. |
The Following User Says Thank You to Brandond15 For This Useful Post: | Tcoat (08-26-2016) |
08-26-2016, 06:25 PM | #193 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Brandond15 (08-26-2016), chaoskaze (08-26-2016) |
08-26-2016, 06:26 PM | #194 |
08-26-2016, 06:31 PM | #195 |
So now that I've had more time to look at my car closer, I've noticed a few things.
Yesterday I just got my car and drove straight to work so didn't even have time to inspect it properly.. Once I got to work though, I noticed something. I don't even know how they managed to bend my license plate like this. Got me a bit irritated but haven't talked to them yet. Also, when I got off work at 4:30 am, I started the car and it started up just fine, but TPMS light came on. At first I thought "well it's cold right now, maybe a tire went slightly below the pressure spec because of it" and I looked at all of the tires just to make sure one wasn't completely low and they all looked fine. Just went for a drive right now though and light was still on so I went to put some air and both the front tires were at 30 psi instead of 35 psi as it should be so I put some air in them and sure enough the light turned off... But here's an issue I had just bought stem covers for my tires.. 3 of them still have them, passenger front tire though, missing. I know these are little things but still, I believe I should have received my car the way it was when I took it in (well, except with a new engine of course). |
08-26-2016, 06:59 PM | #196 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Peanut gallery over here i know, but just to gently interject... these things are other worldly unimportant in comparison to some of the other things to be sensitive about, like oil consumption, running temp ranges, knock detection, etc. License plate can be removed and bent back and most tire shops give those petty dust caps away by the bucket and aren't even necessary anyway...
But how did they bend the plate and not damage the mount.. |
The Following User Says Thank You to Toyarzee For This Useful Post: | Brandond15 (08-26-2016) |
Similar Threads | ||||
FR-S MT Complete Engine/Motor with 20K (Possible Bent Rod) | FRSH86 | Engine, Exhaust, Bolt-Ons | 6 | 07-18-2016 03:42 PM |
Password:JDM Engine Bay Dress Up Kit 2013+ Subaru BRZ / Scion FR-S | password:jdm | Engine, Exhaust, Bolt-Ons | 153 | 01-28-2015 03:16 PM |
2013 scion frs engine | scion123 | Engine, Exhaust, Bolt-Ons | 16 | 10-13-2014 09:03 PM |
2013 Scion FRS Engine, Transmisison, harness 9k miles! | JoeDrifter | Engine, Exhaust, Bolt-Ons | 4 | 12-10-2013 09:08 AM |
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts | ptuning | Engine, Exhaust, Bolt-Ons | 0 | 02-04-2013 10:24 AM |
