Old 08-25-2016, 07:59 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile Openflash FLEXFUEL OTS Tunes!
Hi guys,
We have been plugging away in getting Flexfuel kits and Flexfuel tunes out for the general masses. So far, we have only been testing them in a closed Facebook group (SBD Turbo owners group) and all has been good. But now it's time for a wider release. But first, I need a few volunteers to work with. Basically I'd like to test the OTS Flexfuel Stage 1 and Stage 2 UEL/EL maps in a handful of cars and offer free custom e-tuning to dial it in properly.
Here is what is required to be a early tester:
1) An Openflash Tablet and our XRP Flex Fuel Kit
2) Access to E85
3) Must have a naturally aspirated 6MT (USDM or nonUSDM). No 6AT FlexFuel support yet.
4) Stock airbox (any drop in filter is fine)
5) Must know how to data log so I can make tune revisions for you
After custom e-tuning this first batch of cars, we can release OTS FlexFuel tunes for everyone. Major thanks go out to ztan for developing the FlexFuel code. He put a lot of time into getting it work the way it does. It's brilliant and it works beautifully!
If you are interested in becoming an early adopter (and get free E-tuning), please email me at shiv@openflashperformance.com and write "FlexFuel Testing" in the subject line.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 16 Users Say Thank You to Shiv@Openflash For This Useful Post:
504 (08-25-2016), Awstryker (09-20-2016), DustinS (08-25-2016), D_Thissen (08-25-2016), everythingsablur (08-25-2016), fang_gt86 (08-25-2016), JonAvalon (08-26-2016), OrangeGuitar (02-14-2017), phrosty (08-25-2016), ShadowSeraph (08-26-2016), solidONE (08-28-2016), steve99 (08-25-2016), Teseo (08-25-2016), trigger happy (02-10-2017), waterbison777 (09-05-2016), wparsons (08-26-2016)
Old 08-25-2016, 08:53 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you get any volunteers from Australia, please send them the ignition maps and maf scales for E0 from the flex roms I sent you, not openflash ones for E10 that run shit on E0.
We will have the flex tune running on MT with moto east kit in the next week or two.
Old 08-25-2016, 10:10 PM   #3
phrosty
Will jump on this when the AT tune is available.
phrosty is offline   Reply With Quote
Old 08-25-2016, 10:28 PM   #4
stokeless
stokeless's Avatar
Drives: 2020 BRZ PP Silver
Sub....
"the car is not slow...people need to take turns faster"
stokeless is offline   Reply With Quote
Old 08-25-2016, 10:31 PM   #5
Wayno
Wayno's Avatar
Originally Posted by stokeless View Post
Sub....
You are aware there's a button for that, you don't need to post less than half a word.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
1slowbrz (05-25-2017), yelsew (08-25-2016)
Old 08-25-2016, 10:55 PM   #6
steve99
Drives: FT86
@Shiv@Openflash
does the fftec flex sensor supplied output 0-5v for direct connection to ecu ?, the kit does not seem to have separate box or circuit to convert 50-150hz signal to 0-5v.
also do you have wiring schematic for fftec it to connect to evap input as in Europe/Australia we have no connection to ECU at connector A35 pin 20.
Old 08-26-2016, 03:09 AM   #7
Shiv@Openflash
Drives: 2013 FRS
@Shiv@Openflash
Built into the harness, there is a nifty little bit of electrics that converts the freq single to voltage. The range is actually 0.5 to 4.5v (instead of 0-5v). For those Aussie/EU ECUs that have a blank at A35, pin 20, they will need to source a spare pin to insert as explained by ztan in his open source flex fuel thread. I'm looking into it as well to make things easier for our international customers
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (08-26-2016)
Old 08-26-2016, 08:36 AM   #8
KDad2
KDad2's Avatar
Drives: 2013 Raven
Interested. When you jump over to 6AT, keep me in mind as well.
KDad2 is offline   Reply With Quote
Old 08-26-2016, 11:15 AM   #9
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
I would be interested in this as well when 6AT's come around. I have a OFT, datalog, 2 E85 stations within 5 miles of my house, NA with stock airbox and plenty of open road to drive on.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 08-26-2016, 11:45 AM   #10
wparsons
wparsons's Avatar
No e85 available, wish I could help.
flickr
Old 08-26-2016, 11:49 AM   #11
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Curse my choice of transmission
Glad to see it being finalized and can't wait for this to be available to for AT
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 08-26-2016, 12:53 PM   #12
Teseo
Drives: frs
At least you have e85, only need wait some time meanwhile im cursed because i dont have e85 available
Old 08-26-2016, 01:12 PM   #13
DAEMANO
Time Traveller
@Shiv@Openflash
All the ESC guys running e85 I know want to know if you'll have a tune for us as well. What's the word?
Old 08-26-2016, 01:25 PM   #14
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by DAEMANO View Post
@Shiv@Openflash
Hi,
We won't have any OTS flex fuel for forced induction applications. All those will require custom e-tuning (just as we do for the turbo guys that are currently running our flex fuel kit/tune).
For all you 6AT guys, I should soon have a test ECU to test Wayno's 6AT flex fuel code on. Thank you e-bay!
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
phrosty (08-26-2016), Tectoniic (08-26-2016)
End of Summer Sale! OpenFlash tablet+OpenFlash Header+OEM Gaskets Shiv@Openflash Engine, Exhaust, Bolt-Ons 2 10-01-2015 06:25 PM
FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 5 09-16-2015 03:26 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
