Old 08-23-2016, 01:39 PM   #127
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by weederr33 View Post
I was thinking something like the cosworth kit paired with the avo turbo kit since it's mounted low and out of the way.
You still need to get a bigger turbo on it. I already have a turbo kit. I just need the bigger turbo, and cosworth kit. Plus small modifications to run the two together plus tuning.
Old 08-23-2016, 01:44 PM   #128
Originally Posted by Jaden View Post
NO your posts don't say anything (I'm sorry you are incapable of understanding my long winded posts). My 153 IQ and my three degrees graduating summa cum laude proves that you're wrong and honestly I don't give a rat's ass if I come off as arrogant, it doesn't change the reality.
LOL...
Jaden
"prove"
"my reality"
HunterGreene (08-23-2016), kch (08-24-2016), KR-S (08-23-2016), Toyarzee (08-23-2016), weederr33 (08-23-2016), wparsons (08-24-2016)
Old 08-23-2016, 01:48 PM   #129
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Fair enough. What turbo kit do you have? I do like the cosworth has the A-2-W intercooler so that would help
MS, CSCS, TSAC-F, CPT
Old 08-23-2016, 01:50 PM   #130
HunterGreene
Hail Magnet
HunterGreene's Avatar
Found it!
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
DustinS (08-23-2016)
Old 08-23-2016, 01:54 PM   #131
DustinS
DustinS's Avatar
Originally Posted by HunterGreene View Post
Found it!
Even has a place for the hamsters to run and help pre-spool the turbo. Kind of defeats the supercharger though.
Speed By Design. I had plans to change a few things on the kit over winter anyway. Mainly external wastegate, GTX3076 w/Tial housing, intercooler. Have all the stuff for a 3" downpipe already.
Same reason I chose the cosworth. Only issue (as brought up in the mess of posts before) is the stacking of intercooler/A/W cooler. Proper ducting could help with that, but until it is actually tested, the extent of modifications needed to make it perfect can only be guessed.
The Following User Says Thank You to DustinS For This Useful Post:
Old 08-23-2016, 02:16 PM   #132
weederr33
weederr33's Avatar
True. It sounds silly but what about mounting the intercooler on the underside of the car?
Old 08-23-2016, 02:53 PM   #133
DustinS
DustinS's Avatar
A V-Mount should take care of any issues. Though keeping A/C without a ton of modifications is what holds me back from doing that.
I am hoping to swing a second hand cosworth (or 335) for a decent price.
Old 08-23-2016, 03:05 PM   #134
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
By any chance, do you have a build thread? I'd love to follow it if you go through with this project.
Old 08-23-2016, 03:52 PM   #135
Yes he does and it is proof that some guys actually do the work (and do it right) instead of just shooting their mouth off without actually doing squat!
http://www.ft86club.com/forums/showthread.php?t=68363
chaoskaze (08-24-2016), DustinS (08-23-2016), KR-S (08-23-2016), Spartarus (08-23-2016), weederr33 (08-23-2016), WRBrzRX (08-23-2016)
Old 08-23-2016, 04:42 PM   #136
DustinS
DustinS's Avatar
Maybe @Matt@Cosworth can lead me to the dent and ding section of the Cosworth website
Tcoat (08-23-2016)
Old 08-23-2016, 05:48 PM   #137
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
sadly no dent and ding parts
I have 1 dev unit left over from our dyno testing and another in our dev car
bear in mind though that thanks to our recent departure from the EU club a dollar now buys you 75 pence instead of 63 pence so all of our stuff has gotten cheaper if you have american dollars in your pocket...
I'd like to see a compound setup with our charger as the cooling is somewhat oversized for the standard kit so it'd be nice to see it stretched a bit and I know of a couple of people investigating this layout
hopefully something will surface soon
Matt@Cosworth is offline   Reply With Quote
The Following 5 Users Say Thank You to Matt@Cosworth For This Useful Post:
DustinS (08-23-2016), killboy (08-23-2016), Sportsguy83 (08-24-2016), Tcoat (08-23-2016), weederr33 (08-23-2016)
Old 08-23-2016, 06:53 PM   #138
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
@Jaden
I am having some difficulty with some of your numbers.
Disclaimer - Some of these numbers are guesses (e.g. BSFC = .4), if you have better values, please provide them and I can recalculate
First lets verify that we have starting numbers right.
In stock form, the FA20 does:
Stock engine: 200 hp, AFR 12, BSFC .40, charge temp 105F, VE = .95, RPM 6500, disp 122 in^3
0 PSI boost required @ 16 lbs/min air flow
But you mention:
That should give you 20 psi at 3300 rpm with the air flow to be making 450-500 hp. Then max out boost at like 35 psi sending through 80-90 lbs a minute of air.
Which doesnt make much sense.
for one example: to get 80-90 lbs of air flow in this engine (@3300 RPM) you would need ~130 PSI boost (or 62PSI @ 6500RPM)
My calcs show:
Stock engine: 500 hp, AFR 12, BSFC .40, charge temp 130F, VE = .95, RPM 3300, disp 122 in^3
64.2 PSI boost required @ 40 lbs/min air flow
So when you say "That should give you 20 psi at 3300 rpm with the air flow to be making 450-500 hp" I think you are off on your required boost by a factor of ~3X.
Even if we assume you can get the intake charge temp down to a non-boosted value (105F) you get:
Stock engine: 500 hp, AFR 12, BSFC .40, charge temp 105F, VE = .95, RPM 3300, disp 122 in^3
60.89 PSI boost required @ 40 lbs/min air flow
So by running at 105 F intake charge temp, you only reduce the required boost by ~3.5 PSI
Just trying to understand where you are coming from.
This is a fascinating topic for me.
On a related topic: I SWEAR that Toyota had a production MR2 with compound boost, but I can find no mention of it.
Perhaps it was only a prototype I read about in the 80-90s??
Anyway one of the concepts I found intriguing was that the SC output could be routed to the turbo while the car was idling to keep the turbo spun up.
I dont recall how they accomplished this but it was an interesting concept.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
chaoskaze (08-24-2016), Tcoat (08-23-2016)
Old 08-23-2016, 08:48 PM   #139
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by justatroll View Post
@Jaden
But you mention:
My calcs show:
I really wish I could understand this to see who is full of shit lol
Also, it wasn't production but HKS made a twincharge kit for the AW11 MR2 with a 4AGZE (S/C only from factory). A few have replicated the setup since HKS stopped making it
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
CSG Mike (08-23-2016), DustinS (08-24-2016), justatroll (08-24-2016)
Old 08-23-2016, 09:30 PM   #140
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
@Jaden
Close, not Toytoa but HKS. Back in the day they did their TRD stuff. They did play around with the compound "charged" not boost. Same thing different wording.
There was an HKS turbo kit for the SC. As I said before a few dudes I know have succesfully did a compound charged MkI MR2. Power wise it was not much if I recall it was 250-280whp. But they always had overheating problems. Then again when the MKII turbo came out. Many ditched the compound charge idea and did engine swaps.
The Following User Says Thank You to Mr.ac For This Useful Post:
all talk no substance, everyone is wrong
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
New Hawk HP + compound Hyper4mance2k Tracking / Autocross / HPDE / Drifting 24 11-11-2014 11:05 AM
help im really dumb i think!!! compound issue.. nickmerronesucks Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-02-2014 03:53 PM
new R compound from Maxxis Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 02:27 PM
