Alexandrino_Auto
Drives: series.Blue
New Hawk HP + compound
Hey all! I thought I would let it be known that Hawk is coming out with a new track/street pad for our cars soon. I met someone at hawk who told me if I like the HP+, that I should hold out on buying them for a few months; because, they will be releasing a new pad that is similar in stopping power and fade resistance to the HP+ with little to no noise.
This is a big upgrade for us weekend warriors who have wives and girlfriends who complain about the brake noise on date night. LOL Happy motoring!
The Shadetree Project: I turn wrenches
Drives: '13 BRZ / '11 Outback / '06 Tundra
Interesting. I love my HP+ pads except for the noise (which has been pretty good lately?). I'd definitely buy the same thing with less noise.
Awesome. I had been thinking about HP+ as my next brake pad. Will be interesting to see how these are with the new compound.
2022 BRZ Build 2013 FR-S Build |
Keep my eye out. I have Projct Mu HC800+ pads. Pretty decent hybrid pads.
C-Street AutoX
There's actually going to be two different compounds coming out....
There's going to be one that's a bit more aggressive than the HPS, but not quite as much as the HP+(less dust/noise), This is coming out VERY soon. Called the HPS 5.0 http://www.hawkperformance.com/perfo...ance-street-50 Then I hear there's going to be a pad that's just a bit more aggressive than the HP+ that is better suited for heavy track use, while maintaining the characterics necessary for street driving. However, the front for the FR-S wasn't on the first list of upcoming applications, which is disappointing as I'd really like to try a set of those HPS 5.0 pads....I expect this to be addressed though. I think this would be a fantastic, and potentially the perfect autocross pad for any FR-S running street tires. |
Drives: Attitude
If the WRX was on the list, then we get fronts at least. Rears are more trouble: 2010 LGT fitment.
#7 | |
The Stig's German cousin
On stock rotors at least, I feel you will need at least another 200-300 degrees F more in the operating range. If I remember right the HP+ is good to 900 F. I am pulling these numbers from my butt - if anyone has cold (heh) hard data to share on stock rotor temps, I'd love to see it. Point being, I'm a little skeptical the newer HP+ will be a viable track day option - if they even make it for our car. Their lack of track options for us is disappointing. |
#8 | |
The symptoms are VERY different. Pad fade you have a hard pedal, but no bite from the pads. Boiled fluid the pedal goes to the floor and you have no hydraulic pressure. I would believe HP+ getting horrible pad fade, but I can't imagine you boiled RBF600 before getting pad fade.
C-Street AutoX
How can you say Hawk has terrible offereings for our cars, they make like 4 different race compounds that are more aggressive than the HP+, what exactly are you looking for?
What track is this, and at what speeds are you braking from. You can't expect a 'street' pad to handle 100 MPH+ stops going balls out every lap. The guy above is right, if you're boiling the fluid, you need to step up the the STR660 fluid. |
#10 | |
If you slowly heat the system, slow enough that you never get the surface temps high enough to fade the pads, the entire system (calipers and rotors) are still slowly heating up. Eventually, the calipers will get hot enough to boil the fluid, but before the pads fade. Remember RBF600 boils at around 600F, but the pads give out at 900F. If the heat impulses are 200F at a time, you can boil the fluid, without having the pads give out. Either way, we don't recommend RBF600 or HP+ for the stock braking system. Side note: If you're boiling RBF600, which is really, really common, it really means your brakes are inadequate for you use. You're heating up the caliper more than it is designed for, and in the long run, will result in fatigue. The solution (albeit expensive up front) is a BBK. I've learned this the hard way... AP Racing sells temp indicator strips and paint, so that you can measure how hot your caliper and rotors get. |
#11 | |
#12 | |
Drives: 2004 Toyota RAV-4 5M
![]() Pads were Hawk DTC-60. Stuck with them for now, but I won't be getting them again, even though I will probably be able to get them for free with their NASA TT contingency. |
#13 |
C-Street AutoX
All my track cars have black wheels...I've ran in the rain with DTC-60's and have not seen my wheels ever look like those ones above. I think the DTC-60's work great, I've never had any issues with QC. I'm interested in lowering lap times though, not winning car shows. Every brake pad is going to have a compromise, what pads are you guys going to switch to that can handle the heat, give consistent laps without any noise/dust?
#14 | |
I just don't want it to look like my wheels will disintegrate at a moments notice.I also know someone else who has been running the DTC-60's on their car for a couple years now (E36 M3) and hasn't had these problems, so I don't know if mine are just a bad or not, but you can find several other horror stories about corrosive dust from Hawk pads by googling around, so its not an isolated incident. I'm probably going to go back to Ferodo DS-UNOs for track use. They will squeal on the street and also make a fair amount of dust. The difference is the dust doesn't turn to rust the instant it comes into contact with water and has always been a piece of cake to remove. Performance has been excellent as well. I'd like to run the Hawk pads, I really would, since their NASA TT contingency program is pretty generous, but if they are going to do this to my wheels (and probably other areas of my car eventually) its just not worth it. |
| help im really dumb i think!!! compound issue.. | nickmerronesucks | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 05-02-2014 03:53 PM |
| Compound turbo setup /w pics | Ironsquid | Forced Induction | 2 | 04-01-2014 07:24 PM |
| new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
| Hard compound street rubber? | slaxx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 05-01-2012 07:47 AM |
