Old 08-22-2016, 12:18 PM   #29
ort895
ort895's Avatar
This and a flex fuel kit would totally revive my love for this car lol
I need to start saving my pennies.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
The Following User Says Thank You to ort895 For This Useful Post:
CSG Mike (08-22-2016)
Old 08-22-2016, 12:19 PM   #30
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm not exactly sure what you're asking...
The brief dip in the torque band is often caused by a cam timing anomaly. Different ramp times and/or different gears alter that false dip on a tuned Ace header car, because it's not "actually there"; its only there under a certain set of conditions.
There's something like that on the Nameless dynos as well - I wonder if it's a similar cause.
Even if it's actually there, it's not something that's ever been obvious while driving.
I might have gone a different route if this setup had been available when I ordered parts... tough sell to switch now - though getting the car quieter may still push me along! It's a bit rough on the ears on road-trips right now. Need to get the suspension sorted first though.
Old 08-22-2016, 01:10 PM   #31
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The brief dip in the torque band is often caused by a cam timing anomoly. Different ramp times and/or different gears alter that false dip on a tuned Ace header car, because it's not "actually there"; its only there under a certain set of conditions.
Ok, thanks for the anomoly part. The other part doesnt really matter then but now is more out of curiousity
when I say more I don't mean raw numbers but mean sacraficing a smaller HP gain for more TQ or vice versa.
I guess what I was trying to say was what is a bigger benefit in terms of real world, more HP or more TQ?
From my understanding HP equals speed which is great on straights. But say a technical track (aka AutoX) where there is a lot of turns and decel/accel happening would more TQ equal faster times?
edit: I guess the simple way to word this would be am I correct in thinking of HP as how fast I could go and TQ as how fast I can reach that speed?
Old 08-22-2016, 01:48 PM   #32
ort895
ort895's Avatar
Yeah that's pretty much right.
finch1750 (08-22-2016)
Old 08-22-2016, 01:55 PM   #33
Teseo
Drives: frs
Keep RPM's in the power band, 5k>
The Following User Says Thank You to Teseo For This Useful Post:
Old 08-22-2016, 02:36 PM   #34
sw20kosh
Drives: 2013 Black FR-S
HP and TQ are forever intertwined. The two numbers relative to each other tell you a lil something about the power band but to get the full picture you need to look at the dyno graph. For autocross I would recommend the ACE350 or the 400/410.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (08-22-2016), finch1750 (08-22-2016)
Old 08-22-2016, 03:47 PM   #35
CSG Mike
CSG Mike's Avatar
The best advice I can give you is to run the stock muffler, or possibly the upcoming CSG "quiet" catback.
Old 08-22-2016, 03:48 PM   #36
CSG Mike
CSG Mike's Avatar
It depends purely on what part of the powerband you're in. Ultimately, Area Under the Curve (AUC) for the part of the powerband you use is what matters.
This is why a Turbo car with a torque spike that tapers hard, is faster than a linear powerband NA car with the same peak power; the turbo car has more AUC.
finch1750 (08-22-2016), Teseo (08-22-2016)
Old 08-22-2016, 07:41 PM   #37
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
What is the quiet catback going to run?
Jmonty is offline   Reply With Quote
Old 08-22-2016, 07:44 PM   #38
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I assume this is different than than the ACE 'quiet muffler' paired with the ACE header?
n8dog11914 is offline   Reply With Quote
The Following User Says Thank You to n8dog11914 For This Useful Post:
Jmonty (08-22-2016)
Old 08-22-2016, 07:49 PM   #39
Jmonty
Not Sure, I have the ACE Header/ Front pipe combo now and with the 3" Perrin catback it was a bit too much
Old 08-22-2016, 08:07 PM   #40
churchx
churchx's Avatar
Drives: 2014 GT86
Then how about one that is most mentioned when asked for quiet one - Q300?
Seeing how well ace header performed i have no doubts for their catback to be exemplary to reach it's design goals .. except that who knows when it will hit the market :/
Old 08-22-2016, 08:30 PM   #41
CSG Mike
CSG Mike's Avatar
They are one and the same
Jmonty (08-23-2016)
Old 08-23-2016, 08:54 PM   #42
n8dog11914
n8dog11914's Avatar
Will definitely be interested when it's available!
stock tune only bolt ons dyno slow15frs Engine, Exhaust, Transmission 14 05-12-2016 01:42 AM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 05:54 PM
Header/Dyno Tune Chase1996 Engine, Exhaust, Transmission 26 02-26-2016 06:25 PM
A/T, AVO panel filter, Borla UEL, Stock cat-back, Drift Office dyno tune Turbo Den Engine, Exhaust, Transmission 2 09-20-2013 03:01 AM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 12:35 PM
