Old 08-19-2016, 10:10 PM   #29
steve99
Drives: FT86
Yes, but which one is which?
The switch at the top of the clutch pedal travel is for detecting the clutch is fully released. As above as you start to press clutch it trips and will disengage cruise control and on manual cars the gear indicator will turn off.
The Switch at the bottom of clutch pedal travel is for the start inhibit, if clutch is not to floor to activate the bottom switch car wont start.
Unplug switch and measure with multimeter, you should be able to bypass it by either unplugging it or looping the connector depends if its normally open or normally closed operation.
Old 08-19-2016, 10:16 PM   #30
Well now I feel bad. I was just trolling mav.
steve99 (08-19-2016)
Old 08-21-2016, 01:25 PM   #31
pevsfreedom
Drives: 2014 BRZ
So I finally found it and I noticed one thing: when the clutch is fully depressed it only pushes in about 2/3 the plunger.
On second thought maybe the switch IS bad because I just noticed this post:
Originally Posted by extrashaky
(3) Measure the gap shown in the figure with the clutch pedal fully depressed.
Normal clearance : 3.5 to 4.0 mm {0.138 to 0.157 in}
So I assume that gap is normal. Maybe the switch is just going bad because it still works sometimes. I'll leave it up to the dealership I guess but I don't think I'll leave without them having ordered the part.
pevsfreedom is offline   Reply With Quote
Old 08-21-2016, 02:44 PM   #32
ryoma
ryoma's Avatar
make sure you point it out to them which switch is bad, otherwise they might replace the wrong one lol.
Old 10-10-2016, 03:17 AM   #33
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Gonna bump this as I've been having the same issues.
@pevsfreedom how did you end up fixing this? Did the dealer fix it, and if so what was the issue? Hoping to figure out if its just a misalignment or if they had to replace the switch.
Old 10-10-2016, 01:25 PM   #34
Pull the connector and jumper it. I bypassed mine long ago for totally OCD reasons.
Old 10-10-2016, 09:39 PM   #35
PandaSPUR
PandaSPUR's Avatar
Thinking bout doing that. But kinda worried about dumb parking valets that dont realize the car is MT before hitting the button.
Old 10-10-2016, 10:25 PM   #36
Whoops, no way. Don't even consider it. I wouldn't do it myself if I had pushbutton start.
Didn't think about that.
Old 10-10-2016, 10:25 PM   #37
SS4goku
SS4goku's Avatar
Drives: BRZ tS
I got mine fixed at Subaru. They replaced the clutch switch and the battery and now it starts every time.
SS4goku is offline   Reply With Quote
Old 10-10-2016, 10:29 PM   #38
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I think the bigger issue is that you allow people to valet your car
Stang70Fastback is offline   Reply With Quote
Old 10-10-2016, 10:44 PM   #39
I had to do it once at a ritzy hotel. It was truly painful. After chastising him for slamming the door shut (I demonstrated by pushing it closed with one finger) he let me keep it in the staging area.
Old 10-10-2016, 11:33 PM   #40
PandaSPUR
PandaSPUR's Avatar
Hard to avoid in NYC. A lot of the parking lots here use valets. Even at my own parking garage, they let you park the car yourself but they keep a spare key in case they need to move it because a lot of the cars are double parked.
I'm gonna take a peek at the switch and see if i can just adjust the nut a bit. If not, I guess I'll go to the dealer.. sigh.
Old 10-14-2016, 05:45 PM   #41
PandaSPUR
PandaSPUR's Avatar
Interesting experience today...
Went to dealer to have them fix it under warranty but they told me I'd have to leave the car for 4-5 hours. Since its a $20 part and some really basic work, I decided to just pay for the part and do it myself.
But here's the interesting part, their system showed the clutch start safety switch as part #83281AA000. From doing my own prior research, I knew it was part #83281AA010. Checked on the subaru parts site while I was at the dealership, confirmed part #83281AA010. Looked under my dash and caught a glimpse of the switch confirmed it had no blue bit on the port (the clutch cruise control switch is partially blue). Finally asked an actual mechanic there and he agreed, it was part #83281AA010.
Not sure what the hell is wrong with that dealership's computer.
Old 11-30-2016, 10:52 AM   #42
PandaSPUR
PandaSPUR's Avatar
Could not freaking get to the nut holding in the old switch. Took off the bottom half dash cover, sat backwards in the drivers seat and had my head down there. Still could not get my wrench on that nut properly.
Any tips?
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
