Old 08-20-2016, 04:32 PM   #1065
Reamer
Drives: 2015 FRS
Originally Posted by Sojhinn View Post
Is it out?
https://www.fftec.com/item/2078/Open...el_System.html
Only for MT for now.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
Old 08-20-2016, 04:54 PM   #1066
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
The problem is the tune. Memory addresses need to be discovered for most of the US MT and AT cars, to communicate with the sensor. Once those are discovered they can be added to the appropriate definition files and the tunes can be made. Then the kit can be released.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 08-20-2016, 06:26 PM   #1067
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Is it out?
I believe so
shaynek is offline   Reply With Quote
Old 08-20-2016, 07:23 PM   #1068
KoolBRZ
KoolBRZ's Avatar
The kit is out. The tune is not. Purchase directions point to OFT's custom E-Tunes page, and specify they are currently only available for MT's. So, they are still needing the correct memory addresses to use the kit with all CAL ID's. I would love to help create the tunes for AT's, but can't afford it right now.
Old 08-21-2016, 02:17 PM   #1069
shaynek
shaynek's Avatar
do you know where i can get an aux charger @Sojhinn?
Old 08-21-2016, 03:50 PM   #1070
KoolBRZ
KoolBRZ's Avatar
I had an aux charger and it didn't do a bit of good. The problem was the batteries. They just didn't recharge quick enough for my liking. The 600 watt audio batteries recharge so quickly, if I'm not paying attention, I miss it completely. That also means the charge doesn't last as long though. So ask yourself, which means more to you, quick dump with quick charge, or slow discharge with slow recharge.
Old 08-21-2016, 03:54 PM   #1071
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
What version of phantom?
Installed Mods:
Old 08-21-2016, 04:07 PM   #1072
Sojhinn
Sojhinn's Avatar
Phantom FTS Electric Supercharger Owners Thread
I'm sorry but that's not true. The aux charger makes a pretty big difference depending on the setup. On the setup I first had the aux charger: it reduced charging time by 50% and on my current setup I've sped up charging by 80%-100%.
More importantly the amount work the controller does is reduced which helps reduce the chances of hitting thermal limits.
The aux charger may not be for everyone but to state it doesn't do anything is wrong.
But don't just take my word for it... Feel free to ask others who have it.
Installed Mods:
Old 08-21-2016, 05:22 PM   #1073
shaynek
shaynek's Avatar
version 1.5. I was thinking of getting some new batteries as well (the big crank). will it work with the old batteries as well? @Sojhinn
Old 08-21-2016, 05:25 PM   #1074
Sojhinn
Sojhinn's Avatar
Based on my experience I would snag 3x PC 680s... 1 for the starter two for dump packs and forget the big cranks. Just cap the .5 connections and call it a day. With that setup you shouldn't need the aux charger per Rob.
Installed Mods:
Old 08-22-2016, 01:15 AM   #1075
shaynek
shaynek's Avatar
do you know anyone running this set up @Sojhinn?
Old 08-22-2016, 01:22 AM   #1076
Sojhinn
Sojhinn's Avatar
I used a variation just recently.
Installed Mods:
Old 08-22-2016, 11:47 AM   #1077
shaynek
shaynek's Avatar
which pc680 would you recommend? will they fit in the tray?
Old 08-22-2016, 11:54 AM   #1078
Sojhinn
Sojhinn's Avatar
PC 680 mj
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
