Old 08-19-2016, 08:12 PM   #1
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Ceramic Thermal Coating on Flanges of ACE Header?
I just ordered an ACE Type-A 4-2-1 350 header from CounterSpace Garage and I'm going to have them ceramic thermal coat it before they send it out to me. I've seen several examples on the forum of headers that have been coated and some people have masked off the flanges, while others have coated them - is it just a matter of personal preference, or is there a benefit to doing it one way or the other? To me it seemed like the former, but I did wonder if leaving them uncoated (my preference) could create a hotspot? At the same time I could see how it could provide better sealing for the gasket, so I thought I would ask for people's opinions here on the forum. Well, what does everyone think?
On a sidenote, I want to give a shout out to the people at CounterSpace Garage - these guys couldn't have been more patient or professional with me, and they really know their stuff when it comes to our cars. Highly recommended!
RJasonKlein is offline   Reply With Quote
Old 08-19-2016, 08:49 PM   #2
Cole
Not a troll
Cole's Avatar
Originally Posted by Norville Rogers View Post
Chill. Why do you think "ceramic" coating will make any difference to anything in the first place. Apart from your bank balance.
Find a sunset, grab a drink, and just forget about your car engines exhaust coating....
You're kidding me, right?
OP, I don't think it would make a huge difference, but to me, id rather them be not coated, just for peace of mind in avoiding any possible fitment/leak issues.
Cole is offline   Reply With Quote
Old 08-19-2016, 09:06 PM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The coating is fractions of a mm thick. You can coat the whole lot including inside and the o2 threads. It makes no difference to fitment.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
Cole (08-20-2016), FRS Justin (08-20-2016), RJasonKlein (08-19-2016)
Old 08-19-2016, 09:19 PM   #4
CSG Mike
CSG Mike's Avatar
You'll become a believer the first time you touch a ceramic coated exhaust pipe immediately after the car is parked.
Old 08-19-2016, 10:02 PM   #5
CSG Mike
CSG Mike's Avatar
Then ceramic coating is probably not for you, but there is a very tangible purpose and function to the coating.
Old 08-19-2016, 11:08 PM   #6
Why both sides? Inside makes perfect sense but doesn't the outside just trap heat in the header itself?
Old 08-19-2016, 11:14 PM   #7
CSG Mike
CSG Mike's Avatar
Same reason you do double/triple pane windows. More layers = more insulation.
The goal is to keep the heat in as much as possible, so having two layers of ceramic with a hot header in between keeps MORE heat (energy) in the exhaust gas.
Old 08-19-2016, 11:35 PM   #8
Right, I get that but we don't like header wrap because of embrittlement, and we are essentially doing the same thing to the header with that outer layer.
Old 08-20-2016, 05:33 AM   #9
CSG Mike
CSG Mike's Avatar
You mean the wrap becoming brittle or the header itself?
Old 08-20-2016, 12:53 PM   #10
Maverick986
Drives: 2014 Subaru BRZ
The header itself will become brittle over time. Wrapping a header shortens it's lifespan, I'm not sure by how much, but do know that if your doing any racing with it it will be significant because of the heat the header will be exposed to. If I understand my research correctly, this is mainly due to the higher heat and cycling it is exposed to vs designed to hold, and I've seen some things about condensation playing a roll too.
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
The Following User Says Thank You to Maverick986 For This Useful Post:
Ultramaroon (08-20-2016)
Old 08-20-2016, 02:59 PM   #11
The header itself. Or is that header wrap thing just a myth?
Old 08-20-2016, 03:13 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I have never seen a discussion about that with stainless steel headers before.
Ceramic coating is almost always reccomended.
Old 08-21-2016, 12:58 AM   #13
CSG Mike
CSG Mike's Avatar
I've not seen that become an issue with stainless steel headers... but my experience is fairly limited.
Old 08-21-2016, 01:43 AM   #14
Yes, but I wonder if there isn't an advantage to only coating the inside of the header. I have zero personal experience but, based solely on my understanding of heat transfer and assuming there is something to this embrittlement rumor, there might be something there.
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 03:39 PM
Looking for Header Ceramic Coating in Los Angeles area! Twig Southern California 16 05-21-2015 01:45 PM
Anyplace near LA to get ceramic coating header? ZHoward Southern California 4 05-19-2015 01:45 AM
Ceramic Coating on Header? ELutz04 Engine, Exhaust, Transmission 37 06-05-2014 02:13 PM
P&L EL 4in1 header w/ high flow cat+black ceramic coating(N/A) madpcsupreme Engine, Exhaust, Bolt-Ons 3 05-09-2014 05:17 PM
