Southern California SoCal
Old 05-15-2015, 02:13 PM   #1
Twig
Instagram: twig_RS1
Drives: FRS RS1
Looking for Header Ceramic Coating in Los Angeles area!
I am looking for a local shop in the Los Angeles area to do Ceramic Coating on a UEL Header and Overpipe.
Looking for recommendations, referrals or a quote.
I don't mind getting feedbacks on why I shouldn't get it. I don't plan to track but I do drive avg 30k miles a year, avg 2-3hrs commute daily.
I am also pretty handy and don't mind any DIY Ceramic Coating recommendations.
Sorry, i don't want to wrap.
Thanks!
Twig is offline   Reply With Quote
Old 05-16-2015, 01:22 PM   #2
Twig
Instagram: twig_RS1
Drives: FRS RS1
Bump
Old 05-16-2015, 07:32 PM   #3
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Pacific Coast Powder Coating in Palmdale did my header for $150.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Twig (05-18-2015)
Old 05-16-2015, 10:38 PM   #4
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Whats the benefits of ceramic coating your header??
Vincenttam is offline   Reply With Quote
Old 05-17-2015, 10:21 AM   #5
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Ceramic coating functions as an insulator, so it will keep your engine bay cooler (like the stock heatshield does). But it also has a performance advantage, in that hotter gasses (like exhaust) flow faster, so a coated header theoretically expels the exhaust fumes faster away from the block.
V_86 is offline   Reply With Quote
The Following User Says Thank You to V_86 For This Useful Post:
Vincenttam (05-18-2015)
Old 05-18-2015, 07:05 PM   #6
Vincenttam
WtsTofu
Vincenttam's Avatar
Is this a big beneficial difference or theoretical?
Old 05-19-2015, 11:09 AM   #7
V_86
V_86's Avatar
Not sure, I know that on an older car like a Jaguar, it can cool the engine bay by 30%. But that's more about reliability, not performance necessarily.
Old 05-19-2015, 06:34 PM   #8
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Specialized Coatings in Huntington Beach.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
Hyper4mance2k (05-20-2015)
Old 05-19-2015, 06:43 PM   #9
DAEMANO
Time Traveller
Embee Performance Coatings in Santa Ana is legendary. its off the 55.
Old 05-19-2015, 06:49 PM   #10
Crazypinoy9
Drives: FR-S TRD RS1#1488
+1 for Embee. used them before and only have positive things to say about their work and customer service.
But as an alternative in the OC you can also give Black Oxide Industries a try:
http://blackoxideindustries.com/en/ceramic-coating
Crazypinoy9 is offline   Reply With Quote
Old 05-19-2015, 06:53 PM   #11
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
I know the upside to the ceramic coating is a cooler engine bay, but doesn't that cause increaseD wear on the header itself?
megamarines is offline   Reply With Quote
Old 05-20-2015, 02:48 AM   #12
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
No. If anything it extends the life of the header by keeping the heat in the exhaust and out of the metal, plus it protects it from corrosion.
Edit: I just noticed today that my ceramic coating is flaking off after only two weeks on the car. I am NOT happy. I've been doing this for years and this is the first time I've had this happen...
Old 05-20-2015, 04:26 AM   #13
megamarines
Too thin of coating or just getting too hot?
Old 05-20-2015, 12:35 PM   #14
Twig
Instagram: twig_RS1
Drives: FRS RS1
Probably improper prepping. "paint" will stick on a smooth metal surface without a good sand. The paint needs some porous surface to adhere. I got convinced to wrap the header. I am going to silicone spray and then titanium wrap over that to double up.
The Following User Says Thank You to Twig For This Useful Post:
ceramic coating eddiev116 NY / NJ / CT / PA 3 02-06-2015 06:54 PM
Ceramic Coating on Header? ELutz04 Engine, Exhaust, Transmission 37 06-05-2014 02:13 PM
Ceramic coating recommendations mrk1 Forced Induction 5 03-03-2014 11:51 AM
Ceramic Coating options or Jet hot coating brzadmir NY / NJ / CT / PA 4 07-10-2013 01:35 PM
AVO FR-S/BRZ Turbo Kits with Ceramic Coating JoeBoxer Forced Induction 23 06-19-2013 11:59 PM
