| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Black MT LMT BRZ
What am I missing about getting a flush look
I've been on the wheel directory for idk how many hours looking at different setups. At first I was set on getting work kiwami wheels 18x9.5 +38 and st coilovers to drop the car about an inch but now I'm worried about there bring too much poke and i dont want the wheels all cambered out and looking broken. I pick 18x9.5 because I like the deep concave look. I would want to do 18x8.5 in the front but I feel semi concave wheels up front and deep concave wheels in back may look funny.
My question is what else am i missing in getting the stance you want for your car because some of the other wheels running the same specs look perfect to me and then the wheels I'm looking at are poking too much on the directory. I don't know much about camber bolts and stuff either so I don't know if that plays a part or is completely irrelevant. Any suggestions, help, or 18x9.5 pictures to show me I'm wrong and it won't poke appreciated. As of now I'm tempted to just make the purchase of 18x9.5 all around and hope for the best or get 18x8.5 up front and hope for the best. I figured I'd ask the much more knowledgeable people on the forum first though. |
#2 |
*Some really cool title*
Whenever someone asks for advice about stancing their car, my answer is always this:
Don't do it. |
#3 |
Drives: 2013 Raven FR-S
Are you going for just stance or do you want good performance?
#4 |
Just looks right now.. and when I say stances I don't want the car slammed to the ground with the wheels sticking out. Just lowered a bit with a clean flush look. The more I look at the forums I'm leaning towards 18x8.5 +38 all around. The wheels would only be semi concave then
| The Following User Says Thank You to Kendallkab For This Useful Post: | 15limited (08-18-2016) |
#5 |
Seeing this thread I'm about to say fuck it and order the 18x9.5 all around. I don't even want to drop mine as much as he did
http://www.ft86club.com/forums/showt...t=20907&page=5 |
#6 |
If going just for looks, might as well go staggered. The 18x9.5 is really too wide up front.
For a more performance oriented option, 18x8 +35 square setup would sit pretty flush. |
#7 |
18x10 all around
| The Following User Says Thank You to Apex-Apex For This Useful Post: | whataboutbob (08-21-2016) |
#8 |
Drives: '13 SWP ZC6 R
Jesus, this forum.
1. don't go staggered. 2. with 18x9.5, +38 and a 255/35 tire... you'll need something like 1.5 to 2 degrees of camber in front to avoid rubbing the fender. that's hardly "stanced." Go read the meaty tire thread and see what's been done. Stop posting junk threads. And the rest of you, stop giving bad advice and being "performance" snobs.
| The Following 2 Users Say Thank You to sdemo For This Useful Post: | Hostile_Kittens (08-27-2016), skye67 (08-26-2016) |
#9 |
Time Traveller
@sdemo is totally correct. The amount of perceived "poke" is going to be determined by how much negative camber you're running as well as wheel offset and width.
In the front, with a 1.5" drop, you might need 1.0 - 2.0 degrees of negative camber to "tuck" the top of the wheel and prevent it from looking like it's poking (even though, technically, the bottom of the wheel will be). Don't worry about that, in the end it works and looks good. Most achieve this with either camber bolts or adjustable top hats. In the rear, if you drop the car 1.5" you'll get roughly -1.2 degrees of natural negative camber. That should be enough because the rear fender clearance is better. In general I avoid buying staggered setups if that's not what came from the factory. The last thing you want to have to deal with is a RWD car that understeers like a FWD car because the balance of front and rear grip has been thrown for a loop just to get a look. |
#10 | |
Personally I think it's retarded to use an 18x9.5 wheel on an 86 with stockish power levels. A light 18x8 with a low offset would be a good compromise. |
#11 |
I care about understeer? When did I say anything about that? OP just wants some wheels that look nice and are semi-flush with the fender... not hellaflush, not stanced, not any of that other nonsense.
To turn this into a stance v. performance thread is ridiculous and likely confusing for the OP. EDIT: @DAEMANO we must be brothers from another mother... both with RSR Sports-I and SA10rs heh
| The Following User Says Thank You to sdemo For This Useful Post: | DAEMANO (08-19-2016) |
#12 | |
| The Following User Says Thank You to Kendallkab For This Useful Post: | DAEMANO (08-19-2016) |
#13 | |
Second don't call my thread "junk" when I in fact got the exact answer I was looking for from @DAEMANO. I was looking for an explanation as to why some cars looked different with the same wheel spec and @DAEMANO provided that for me. Im new to modding cars as I didn't care to mod my auto frs I initially had. Id like to have a full understanding of what I'm getting myself into before I spend a few thousand dollars and end up upset so I figured I'd ask the forum seeing as I thought that's what the forum was for. I spent plenty of time on other threads including the meaty tire one before making this one. Thank you as well for telling me the amount of camber I'd expect with those wheels |
#14 |
Thanks
Op from what you've posted I really think you will be unhappy with 9.5
Look how many wider wheels are for sale in classifieds. IMO you sound like you want a 8.5 with a higher offset. 38-45 is good. I have staggered 8.5/9.5 +45 I regret. Then 9.5 +45 even pokes in the rear imagine up front.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | Kendallkab (08-19-2016) |
| Can I get this flush? | BRZBYE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-24-2016 06:26 AM |
| FlushBrz's Flush FR-S. lol | FlushBrz | Member's Car Journals | 40 | 02-08-2014 08:35 PM |
| RPF1 most flush? | goshem | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 11-27-2013 10:34 AM |
| Flush +/- | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 08-13-2012 11:37 AM |
| Help with DIY transmission flush. | ahausheer | Other Vehicles & General Automotive Discussions | 0 | 06-26-2012 03:51 PM |
