#15 |
insert witty quip here
Drives: 2016 Limited BRZ
I thought the same thing at first but the OP said in post #6 that both keys are doing the same thing. The key is also unlocking the door and turning on all of the ACC power and internals, just no juice to the starter.
I was thinking either steering wheel lock or clutch switch. |
#16 | |
Drives: 2014 BRZ
Still happens with new car battery AND new key. I have no desire to mess with clutch and am 93% sure it's the clutch safety switch. |
#17 |
Drives: 2014 BRZ Limited
A new key with a new battery, or the spare key that came with the car, which has been sitting for two years?
That brings up an interesting question I don't think I've seen asked or answered here. The key fob on my Jeep doesn't transmit anything until you push one of the buttons. The rest of the time, it's completely inactive. If you push the buttons more often, the battery will die more quickly. The battery in that fob lasts several years. My BRZ key is different. It works whether I push any buttons at all. I can walk up to the car, open the trunk to stash my bag, open the driver's door with the switch in the door handle, start the car and drive away without ever touching the key at all. The battery in it died a few months ago (and behaved similar to the way you have described, but only for a day or so before it died altogether). It seems to have a much shorter life span than the one in my Jeep key. Is the BRZ key inactive until the car senses it, at which time the car tells it to start transmitting? Or is the key always transmitting a low power signal for the car to detect? Based on the short battery life, I suspect it's the latter. That would be a lot simpler design, and a low power transmitter can certainly run for a couple of years that way on a wafer battery. I don't think the key is smart at all. It just sits there spitting out a signal without ever knowing it's near the car. If that's the case, that means your "new" key is not new at all. While your "used" key has been transmitting for the last two years to open and start your car, your "new" key has been transmitting for the last two years to the inside of a drawer, draining the wafer battery at the same rate. So again, regardless of whether you're 20% or 50% or 93% or 99% certain it's the clutch switch, I suggest you go buy a new battery and see if it fixes the problem. If I'm wrong, you're out six bucks and a trip to Best Buy. If I'm right, you saved yourself a lot of time and irritation fucking around with something that isn't broken. |
| The Following User Says Thank You to extrashaky For This Useful Post: | justatroll (08-21-2016) |
#18 |
Drives: BRZ tS
I have been experiencing this as well. I have to clutch in multiple times for the green key indicator to show up and then it will start.
#19 |
if you think it's the clutch safety switch, have you tried to fix it? maybe the spring mechanism on the switch is getting stuck due to excess dirt or something. I haven't heard of anyone having their clutch switch breaking, but there is always a first time for everything.
#20 | |
Drives: 2014 BRZ
#21 | |
Drives: 2014 BRZ
edit: I got an appt for the 29th which is as early as they could get me in when the "main tech" guy is there because this issue apparently is confusing them. Last edited by pevsfreedom; 08-19-2016 at 04:32 PM. |
#22 | |
![]() I would just make sure that it's plugged in securely and that you can depress the plunger. It's possible that the lock nut has backed off and the plunger is not being depressed all the way / far enough. Since you're still under warranty get it back to the dealer and get them to work it out. ***** Nevermind, just saw that you have an appointment. |
#23 | |
TRACKBREAD
heads up! There are 2 of them, one in front of the pedal and one behind the pedal (with respect to the car, nose=front tail=rear). you want to check the front one. |
#24 |
Here's the info on the clutch switches from the service manual. There are TWO switches, a clutch switch and a clutch start switch.
![]() REMOVAL 1. Disconnection of battery ground terminal 2. Removal of instrument side panel RH 3. Removal of instrument panel under cover SUB-ASSY No.1 4. Removal of instrument panel under cover SUB-ASSY No.2 5. Removal of knee airbag module 6. Removal of clutch switch ASSY (1) Remove the clutch switch connector. ![]() (2) Remove the nut and then remove the clutch switch ASSY from the clutch pedal support SUB-ASSY. 7. Removal of clutch pedal support SUB-ASSY (refer to ) 8. Removal of clutch start switch ASSY (1) Disconnect the clutch start switch connector. ![]() (2) Remove the nut and then remove the clutch start switch ASSY from the clutch pedal support SUB-ASSY. INSTALLATION 1. Installation of clutch start switch ASSY (1) Install the clutch start switch ASSY to the clutch pedal support SUB-ASSY with the nut. Standard value:(2) Connect the clutch start switch connector. ![]() *a - Clearance (3) Measure the gap shown in the figure with the clutch pedal fully depressed. Normal clearance : 3.5 to 4.0 mm {0.138 to 0.157 in}2. Installation of clutch pedal support SUB-ASSY 3. Installation of clutch switch ASSY (1) Install the clutch switch ASSY to the clutch pedal support SUB-ASSY with the nut. Standard value: Tightening torque=8.0N·m { 82kgf·cm} {5.9ft·lbf}(2) Connect the clutch switch connector. ![]() *a - No gap (3) Check that a gap is not created when the clutch pedal is not depressed. 4. Installation of knee airbag module 5. Installation of instrument panel under cover SUB-ASSY No.2 6. Installation of instrument panel under cover SUB-ASSY No.1 7. Installation of instrument side panel RH 8. Connection of the battery ground terminal Standard value: Tightening torque=6.0N·m { 61kgf·cm} {4.4ft·lbf}9. Settings when removing/installing battery terminals 10. Check of airbag warning light ON-VEHICLE INSPECTION 1. Check of clutch start switch ASSY (1) Make sure that engine does not start with clutch pedal not depressed. (2) Make sure that engine starts with the clutch pedal fully depressed. If necessary, replace the clutch start switch ASSY with a new one. UNIT INSPECTION ![]() 1. Check of clutch start switch ASSY (1) Measure the resistance between terminals when operating the shaft. Captions in illustration *a - 4.0 to 5.5 mm {0.157 to 0.217 in} *b - ON *c - OFF Resistance When shaft is pressed in (ON) - Less than 1 Ω When shaft is not pressed in (OFF) - 10 k Ω or more |
| The Following 3 Users Say Thank You to extrashaky For This Useful Post: |
#25 |
Drives: 2014 BRZ
Awesome thanks everyone.
#26 | |
Drives: 2005 Toyota Camry
The switch that the clutch pedal arm touches when you depress the pedal all the way is for engine start. The switch that the arm touches in a natural resting position is to disengage cruise control if you have it on. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Sportsguy83 (12-01-2016) |
#27 |
Yes, but which one is which?
#28 |
| The Following User Says Thank You to mav1178 For This Useful Post: | Ultramaroon (08-19-2016) |
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 09:57 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
| Tad's CBS BRZ From The Start | Tad_07 | Member's Car Journals | 8 | 10-12-2012 02:19 AM |
