Old 07-28-2016, 10:07 AM   #15
CARBON10
CARBON10's Avatar
Drives: 13 FR-S 10 series #0783
those velox ones look killer... gives it a OEM+ kind of feeling.... adding it to my list of must haves. haha.
CARBON10 is offline   Reply With Quote
The Following User Says Thank You to CARBON10 For This Useful Post:
VerusEric (07-28-2016)
Old 07-28-2016, 11:09 AM   #16
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by churchx View Post
@VeloxEric : I wonder ..
- Wouldn't it be better to make them from metal to reflect heat? (possibly cheaper too)
- Also .. how about making also maching "blank" ones, for single-exhaust owners.
- And imho squared form like in OP looks a bit more stylish (though i'd prefer covering more area, eg. up to towing hook hole and slightly wider).
-Carbon fiber is actually a great insulator for heat. The shape of the cutout would be difficult to do with metal as well, this is perfect for composites.
-They are sold separately, not as a pair.
VerusEric is offline   Reply With Quote
Old 08-02-2016, 10:38 PM   #17
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Originally Posted by VeloxEric View Post
We are in the process of releasing these right now .
Pictures below. The neat thing about our cover is that it doesn't use gel coat, so no yellowing over time. It is also 100% carbon throughout, no fiberglass. It is polished high temp carbon at that; which is meant specifically for this type of hot environment. It looks high-end motorsports in person.
Thanks,
Eric
Very nice.
Will this fit all exhaust systems. I an asking about my Perrin with 4 in tips.
Thanks!
Sent from my SAMSUNG-SM-G900A using Tapatalk
ohmai18 is offline   Reply With Quote
Old 08-02-2016, 10:55 PM   #18
VerusEric
VerusEric's Avatar
Originally Posted by ohmai18 View Post
Very nice.
Thanks!
It adds 1mm thickness (0.040") to the exhaust cutout area. You shouldn't have an issue unless the exhaust is already touching the bumper, and if you're at that point, you probably already have an extremely melted bumper.
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
ohmai18 (08-06-2016)
Old 08-06-2016, 12:46 AM   #19
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Cool. I got a pair from FT86speedfactory. Will post pics when installed.
The Following User Says Thank You to ohmai18 For This Useful Post:
VerusEric (08-17-2016)
Old 08-17-2016, 02:31 AM   #20
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
@VeloxEric, how does this install? interested with this product since my exhaust melted a little of the bumper already and it doesnt look good lol
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 08-17-2016, 11:11 AM   #21
VerusEric
VerusEric's Avatar
Our install manuals are always online under the support tab on our website
Install Manual Page
Carbon Exhaust Cover Install Manual
Quick answer is double sided foam by 3M. It's stout stuff from my testing *when installed correctly*, which is not difficult when following the above install manual.
Thanks,
Eric
pcuerpo (08-18-2016)
Old 08-17-2016, 11:20 AM   #22
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
It might be just me, but I think these would look awesome installed with a few rivets per side...
JazzleSAURUS is offline   Reply With Quote
Old 08-17-2016, 12:08 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Just you . In my eyes it would change looks from blending-in almost stock-ish looks to afterthought hack.
Old 08-17-2016, 12:33 PM   #24
Ashikabi
Ashikabi's Avatar
You mean a modification? Aftermarket wheels look like an afterthought too side stock wheels almost always look bad and even when they don't the style just isn't the same as the aftermarket
Old 08-17-2016, 01:42 PM   #25
8R6
8R6's Avatar
Drives: FRS
damn those cf exhaust shields look f'n BADASS
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
VerusEric (08-18-2016)
Old 08-18-2016, 05:59 AM   #26
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
@VeloxEric, one last question, if the bumper has already burnt parts, will there be any mounting issues? mine seems pretty light only but need to make sure before i make a purchase.. will try to take a pic for you to see the amount of damage if you want or need it
2013 Toyota 86
IG: @pcuerpo.images
Old 08-18-2016, 11:53 AM   #27
VerusEric
VerusEric's Avatar
It wouldn't be terrible to drill your own holes in the carbon. Just have to be careful and start small.
As long as you clean the burnt parts and make the surface uniform with the rest of the bumper, I'd say you'll be alright. I'd sand it till it was flat-ish again and then go along with the install per the manual. Dremel, orbital sander, hand sanding would all take care of this I believe.
Thanks,
Eric
pcuerpo (08-23-2016)
Old 08-27-2016, 12:16 AM   #28
Gin Ryuu
Drives: 2015 BRZ Limited ISM
Added the Velox Carbon Exhaust covers today. These looks fantastic. The fit is spot on and they really add to the look of my HKS exhaust. Great job Eric and everyone else at Velox for coming up with these.
Gin Ryuu is offline   Reply With Quote
The Following 2 Users Say Thank You to Gin Ryuu For This Useful Post:
Mim (08-27-2016), VerusEric (08-27-2016)
Which Exhaust for TRD JP rear bumper MisterSheep Engine, Exhaust, Transmission 27 03-16-2016 07:32 PM
MXP Quad Tip Exhaust designed for FRS TRD Rear Bumper Kami Speed Engine, Exhaust, Bolt-Ons 0 02-18-2016 06:51 PM
Quad exhaust and rear bumper JDsThatGuy Cosmetic Modification (Interior/Exterior/Lighting) 5 07-02-2015 12:33 PM
Quad exhaust list for TRD rear bumper 86Toyobaru Engine, Exhaust, Transmission 0 09-28-2014 01:55 AM
How long to wait to put x-pel shield on after bumper re-painted? Ammunition Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 02-21-2014 03:14 PM
