Old 08-12-2016, 07:16 PM   #1
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
PTUNING Competition Turbo System V2 (version 2)
Scheduled Release Date: September 1, 2016
Pricing: $5895.00 w/GT2871R or GT3076R (additional cost to upgrade to GTX-2867R, GTX-2871R, GTX-3076R)
To Order: Call one of our sales associates for details or to place an order 1-877-PTUNING or (703) 257-1728.
It's been a crazy 12+ months but we've finally completed our much anticipated PTUNING FRS / BRZ Competition Turbo System V2. For version 2 of our turbo system, we took one of the most reliable, efficient and track-proven forced induction system for the 86--our first version, and step it up a few notches. The following are some of the significant changes in version 2:
Changes in Version 2
Garrett GT28R & GT30R Options
One of the most common requests we have had over the past year was for an option to run the smaller, faster spooling Garret GT & GTX28 frame turbocharger. To make this happen, we had to design a new turbo-to-transmission support bracket along with a few custom-molded silicone couplers to accommodate the smaller compressor housing. The custom-molded silicone coupler had to be designed not only for the GTX28 compressor housing that uses a 3” inlet, but also a separate one for the standard GT30R which uses a 4” inlet. The new coupler was also designed to connect to the new Cobra Intake and clear the newly redesigned turbo over-pipe. The kit will be offered with the GT3076R or GT2871R turbocharger as standard and can be upgraded to the GTX2867R, GTX2871R, or GTX3076R for an additional cost. Power ranges from 300 WHP to 550+ WHP.
Rotomolded Cobra Air Intake
Another request we have had from some of our customers was the ability to retain the factory strut cross-bar. To accomplish this, we had to redesign the original aluminum 4” air intake from a material that would allow us to produce complex shapes while minimizing unnecessary weight. Using rotational molding, we were able to produce a custom molded 4” cobra-shape intake out of lightweight, heat resistant, and very durable polyethylene. Countless hours were spent digitizing, 3D modeling, 3D printing, CNC tooling and producing the new Cobra Intake. The Cobra Intake wraps around the back side of the engine block, transitions from 4” round to 6” oval back to 4” round. The transition still maintains the nominal 4” cross-sectional area. The 4” diameter intake along with our 4” custom molded dry-element air filter allows for more air flow than the FA20 motor can handle.
Investment Cast 304 Stainless Steel Two-Piece Over-Pipes
Also, a big change in version 2 is the redesign of the 304 stainless steel, two piece, turbo over-pipe. Even though our customers were fine with the existing over-pipe, we felt it needed some improvements in terms of all-out track use and ease of installation. To help manage the enormous amount of radiant heat from the over-pipe, we opted to redesign the two piece over-pipe and manufacture it by investment casting it in 304SS material. This same process is used to produce the Tial 304SS turbine housing used in our Turbo System. The thicker-wall material not only adds durability but also reduces heat transfer. In addition, we reposition the v-band connection on the two pipes further back towards the turbo to allow easier access to the v-band clamp from underneath the vehicle. Just like the new intake tube, we spent countless hours digitizing, 3D modeling, 3D printing, and tooling investment to produce the new over-pipes. In addition to the new over-pipes, we reinforced the transmission bracket and added a front support bracket for the over-pipe to header connection. This helps further reduce the load of the over-pipe on the header.
Mechanical Turbo Oil Scavenging Pump
Finally, for those concerned about our use of an electrical turbo oil scavenging pump or potential user-installation issues, we now include a mechanical turbo oil scavenging pump in version 2. The new setup uses a custom billet aluminum cylinder head block-off plate, a custom CNC-modified factory FA20 DIT oil pump, and a custom billet aluminum turbo oil sump. To make the kit even more track-worthy, all oil lines to and from the pump, turbo, and oil sump are all race-style stainless-braided PTFE oil lines with race-style AN-flare fittings. The oil lines are all covered with a black PVC coating to prevent abrasion with other components on the vehicle. In addition, we also supply thermal heat shield sleeving for all lines (oil and coolant) around the hot turbocharger—no cheap rubber hoses for critical fluid lines are used in our kit.
One of the biggest challenges in designing a reliable turbo system is heat management. We address this in our turbo system by positioning the turbocharger and exhaust components away from the front of the engine bay. The turbocharger, wastegate, and exhaust components make up the bulk of not only the radiant heat in a turbo system but also the weight. By moving the hot turbo out of the engine bay and to the bottom rear of the engine block, we created a low mid-mounted turbo system. The placement of the turbo in this location allows a constant air flow from underneath the vehicle to help cool the turbo, wastegate, and downpipe. In addition to addressing the heat management issues, placing the turbo low and mid-ship on the vehicle helps to maintain the low center of gravity of the boxer engine as well as the balance of the vehicle.
Design Features
• Low, Mid-Mounted Turbo System
  • Maintains the low center of gravity of the boxer engine and balance of vehicle by positioning the turbo low and center on the vehicle.
  • Placement of the turbo underneath the vehicle allows for better turbo cooling and eliminates additional heat soak to the engine bay
  • Allows for a very efficient (almost straight) downpipe
• Easily Revert Vehicle Back to Stock (if necessary)
  • No bumper support cutting or removal
  • No removal or modification of the factory radiator fan and shroud -- the factory radiator shroud and fans are very efficient and reliable
  • No modification to the factory oil pan -- no need to remove, modify or weld the factory pan for the turbo oil return
• Effective Boost Control (Wastegating)
  • Wastegate-priority turbo over-pipe -- designed to prevent boost creep
  • External Racing Wastegate -- More reliable control of boost pressure for high output applications
  • Wastegate placement away from turbocharger -- prevent radiant heat from the turbine housing from affecting the reliability of the WG diaphragm & valve(stabilizes boost pressure)
  • Efficient 3" Downpipe and recirculated Wastegate dump tube -- A larger and straighter downpipe, means a more efficient turbo system and the greater the power potential with a given turbo and boost pressure. The recirculated WG dump tube is positioned over two feet downstream from the turbine outlet to not affect the exhaust flow exiting the turbine housing.
• Proper MAF Sensor Placement
  • Ample length of straight piping ahead of the MAF sensor allows for smooth flow for stable readings.
  • Sensor is centered within the piping.
  • Smooth and consistent part throttle drivability is maintained.
  • OEM quality transient throttle response is maintained.
  • Blow-through design prevents any drivability issues associated with vent-to-atmosphere BOV’s.
• Mandrel Bent Aluminum Intercooler Piping
  • Constructed out of 6061 aluminum.
  • Mandrel bent tubing is used throughout to allow for the most efficient flow.
  • Brackets are fitted to the piping in key locations to secure the system and allow it to move with the engine, preventing any unwanted noises.
  • All couplers are made of high quality 4 ply silicone made in the USA.
  • Piping routed through tight spaces use flexible silicone couplers.
  • 1/8”NPT boost reference bung on the hot pipe available for wastegate reference line.
  • 1/8”NPT bung located on inlet pipe available for water/meth injection (WMI) nozzle. Eliminates modification to IC piping to run WMI
  • No cutting in the engine bay required.
  • Intake shroud to reduce intake of hot air from the engine bay and the radiator.
  • Intake shroud fitted with rubber seal strip to seal against the hood and prevent any noise due to vibration.
• Intercooler Core
  • Utilizes custom 24" x 3.5" thick made in the USA Bell Intercooler Core
  • End-tanks constructed of laser-cut CNC-bent 6061 Aluminum.
  • Largest size core used to make effective use of the available front opening in the stock bumper.
  • Supports upwards of 600whp.
  • Professionally welded in house.
  • Aluminum mounting tabs secure the intercooler and prevent it from moving.
  • Because the core is only as large as the front bumper opening, it does not fill the space behind the bumper support, allowing airflow to reach all of the radiator.
  • Retain all lower bumper cover and undertrays and fits properly behind front bumper cover without modifications.
• Mechanical Turbo Oil Scavenging Pump
  • OEM Subaru Pump (Custom Machined)
  • No wiring required.
  • Quiet operation.
  • No modification of factory oil pan required.
  • Billet oil scavenge sump designed to be compact and allow for proper underbody clearance.
• Turbocharger
  • Only quality Garrett dual ball bearing GT turbochargers are used.
  • Available with GT2871R, GTX-2867R, GTX-2871R, GT3076R, GTX-3076R. Ranging from 300whp to 550+whp
  • Properly sized oil restrictor included and pre-installed on turbo.
  • Ball bearing design allows for fast spool and quick response.
  • Water cooled CHRA prevents degradation of the oil when the engine is shut off (no turbo timers are required).
  • Water cooled design prolongs the life of the oil seals.
  • Check-valve included on oil feed line minimize oil-coking to CHRA when engine is shut off.
  • Turbo comes pre-clocked to reduce installation time and fitment issues.
  • Tial Stainless Steel Turbine Housing standard .63 A/R for optimal performance (other A/R sizes available on request).
  • Stainless steel locking tabs for turbine housing bolt. Pre-installed for reliable track use.
• Turbo Oil & Coolant Lines
  • All turbo oil lines are race-quality, custom crimped, PTFE, braided stainless steel lines with PVC coated outer for abrasion resistance.
  • All turbo coolant lines are race-quality, custom crimped, PTFE, braided stainless steel lines with PVC coated outer for abrasion resistance.
  • All lines include thermal heat shield tubing to minimize heat transfer from turbine housing -- a must for reliable track use.
• Exhaust Components
  • Turbo system allows the use of the factory header, PTUNING racing header, or most, if not all of the aftermarket headers on the market. This allows you to retain your existing equal length or un-equal headers.
  • Full 3" 304 SS downpipe for the ultimate in horsepower and response.
  • Full 304 SS Turbo two-piece overpipe.
  • Full 304 SS wastegate inlet pipe.
  • Full 304 SS wastegate recirculated dump tube with flex bellows standard (eliminating unnecessary exhaust noise when reaching full boost).
  • Full 304 SS wastegate DTA dump tube (very loud and obnoxious at full boost) (optional at no extra cost).
  • All turbo exhaust components to and from the turbo/WG use race-style stainless steel v-band clamps for a gasket-less exhaust connection.
• Wastegate & Blow-off Valve
  • Turbosmart Race Port blow-off valve.
  • Turbosmart Comp-Gate 40mm external wastegate.
• Swaybar & End-Links
  • Included with our turbo system is a custom solid front 21mm swaybar (stock is 19mm)
  • Adjustable Whiteline front sway-bar end-links for proper corner-balancing.
• Optional Components (The following components have been designed and thoroughly tested with our turbo system using our in-house Dyno Dynamics dyno)NOTE: The PTUNING Race Header pictured with the turbo system is sold separately and not included with the turbo system. The V2 turbo system is scheduled for a release at the end of August 2016. More details will follow..
Complete Turbo System
Complete Turbo System w/ PTUNING 4-to-1 Equal-Length Racing Header
Engine Bay Layout
GT2867R (Left) vs GTX-3076 (Right)
Turbo Oil Scavenge Pump & Sump
Mrc@ptuning is offline   Reply With Quote
The Following 21 Users Say Thank You to Mrc@ptuning For This Useful Post:
civicdrivr (08-17-2016), Coheed (04-09-2018), CxG (01-08-2018), Cybmx (08-14-2016), flippy (09-18-2016), GhostOp86 (09-09-2016), Guff (08-13-2016), JonAvalon (09-19-2016), kask2_6.0 (08-12-2016), kch (08-15-2016), M1K3 (08-13-2016), mkivsoopra (08-16-2016), pcuerpo (09-09-2016), Pin Flare (08-12-2016), rb6freak (08-13-2016), solidONE (09-09-2016), tato.valverde (08-24-2016), Teseo (01-15-2017), trigger happy (02-05-2017), whataboutbob (09-09-2016), Zaku (10-18-2016)
Old 08-12-2016, 07:17 PM   #2
Mrc@ptuning
Drives: S1000RR
PTUNING Turbo System Dyno Graphs
PTUNING '13 FR-S
GTX3076R - E70, 500whp
Mod List:
Garrett GTX3076R .63 A/R
PTUNING Electronic Boost Control Solenoid (Single Port Configuration)
10PSI Wastegate Spring
Custom Return-Style Fuel System w/ Racing Swirl Pot/Surge Tank
Fuelab Mini-Fuel Pressure Regulator
FIC850CC Injectors
Omnipower 4bar MAP Sensor
PTUNING 3” Turbo-back Exhaust System
PTUNING Flex Fuel Kit
E70 Fuel
Walbro in-tank E85 Pump (Housed in Racing Swirl Pot)
Exedy Twin-Plate Clutch Kit
Kanundrum's '13 FR-S:
702219.318 (Teal) - GT3076R Base
702219.618 (Blue) - GT3076R WMI
702219.681 (Red) - GT3076R E70
Mods:
PTUNING 3" Exhaust System
Garrett GT3076R .64 A/R
FIC 850CC Injectors
PTUNING WMI System
Exedy Stage 1 Clutch Kit
GTX2867R
115531.914 (Red) - 93 Octane/E10
115531.942 (Blue) - E70
GT3076 vs GTX2867R
702219.318 (Red) - GT3076R .63 A/R
115531.914 (Blue) - GTX2867R .64 A/R
The Following 9 Users Say Thank You to Mrc@ptuning For This Useful Post:
BassKeys88 (08-20-2016), civicdrivr (08-17-2016), Coheed (05-12-2018), CxG (01-08-2018), Guff (08-13-2016), mkivsoopra (08-13-2016), rb6freak (08-13-2016), tato.valverde (08-24-2016), whataboutbob (09-09-2016)
Old 08-12-2016, 07:17 PM   #3
Mrc@ptuning
Drives: S1000RR
PTUNING Competition Turbo System V2 - Kit Content
[img]https://imgur.com/gwBXGlt.jpg/img]
Old 08-12-2016, 07:17 PM   #4
Mrc@ptuning
Drives: S1000RR
reserve3
Old 08-12-2016, 08:03 PM   #5
Pin Flare
Luna
Pin Flare's Avatar
Drives: 2016 FRS Release Series 2.0
One day
2016 FRS RS 2.0 #347 of 1000
2013 SCION FRS DEAD AND GONE THANKS TO A FLOOD.
Pin Flare is offline   Reply With Quote
Old 08-12-2016, 08:22 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
NICE. PTUNING does it again! I still remember you posting on the scionlife forums about your turbo kit for the first gen tC and your crazy time attack tC.
Originally Posted by humfrz
I'm old and lazy
Old 08-12-2016, 11:55 PM   #7
TruthfulDeception
Drives: '14 FRS
If this stays anywhere close to the cost of the v1, I'm so sold. I'd been looking at something to tackle the mountains with, and this may be it.
You all already made a super reliable and efficient turbo kit once, I can't wait to see you all do it again!
TruthfulDeception is offline   Reply With Quote
The Following User Says Thank You to TruthfulDeception For This Useful Post:
Ken@PTuning (08-13-2016)
Old 08-13-2016, 01:43 AM   #8
kanundrum
Drives: 2013 Whiteout FR-S
Bump for one of the best kits out there. I have taken my car on many time attacks, fun runs and high speed runs with out a issue. The support and quality of research Ptuning does is with the greats and I will always remain a customer for any platform.
The Following 2 Users Say Thank You to kanundrum For This Useful Post:
Ken@PTuning (08-13-2016), rb6freak (08-13-2016)
Old 08-13-2016, 04:20 AM   #9
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Every upgrade from version 1 is worth it! Love to see PTuning continuing development and progressing this platform.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
Old 08-13-2016, 10:37 AM   #10
Ken@PTuning
Drives: '92 Nissan 240sx KA-T
Send a message via AIM to Ken@PTuning
We've done our best to keep the pricing similar to our V1 kit. Our V1 kit was $5795 and our current kit is priced at $5895.
Ken@PTuning is offline   Reply With Quote
The Following 3 Users Say Thank You to Ken@PTuning For This Useful Post:
Cybmx (08-14-2016), rb6freak (08-13-2016), SkAsphalt (08-18-2016)
Old 08-13-2016, 10:42 AM   #11
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Jesus christ....and I just paid my school tuition.....
Alltezza is offline   Reply With Quote
Old 08-14-2016, 09:36 AM   #12
Cybmx
Drives: 2016 Hyperblue Brz
Would this affect transmission cooling? Would I be needing additional transmission cooler?
Cybmx is offline   Reply With Quote
Old 08-14-2016, 11:33 AM   #13
Mrc@ptuning
Drives: S1000RR
A tranny cooler is not necessary.
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
CxG (01-08-2018)
Old 08-14-2016, 05:43 PM   #14
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
So will a V2 upgrade package be available for the V1 Kit owners??
skylinekin is offline   Reply With Quote
The Following User Says Thank You to skylinekin For This Useful Post:
rb6freak (08-14-2016)
garrett, ptuning, tial, turbo, turbosmart
PTUNING Spec-SS Turbo System with GTX2867R option ptuning Forced Induction 52 06-11-2018 10:25 AM
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 11:48 AM
PTUNING Equal-Length Competition Header RJasonKlein Engine, Exhaust, Bolt-Ons 5 07-07-2016 01:43 AM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 04:52 PM
