Old 06-17-2016, 10:50 PM   #1
RJasonKlein
RJasonKlein's Avatar
PTUNING Equal-Length Competition Header
PTUNING Equal-Length Competition Header - $925 shipped (continental USA)
*Sold*
Used less than 1,000 summer miles in mint condition, with only mild discoloration from heat differentiating it from new. Perfect condition, ships in original PTUNING box, big power gains, save 30% over retail. Does not include gaskets.
Description (from PTUNING website):
- Designed and manufactured in the USA using only the best quality domestic grade materials.
- Custom spec 1/2" thick CNC T304 SS head flanges with back cut gasket face for better exhaust port gasket sealing.
- Custom spec 1/2" thick CNC T304 SS 2-bolt overpipe inlet flange.
- T304 SS v-band near merge collector for possible future upgrades to a full v-band header back exhaust system.
- Runner lengths designed around the offset cylinder 1 and 4 exhaust ports on the FA20 cylinder head.
- All 4 runners lengths are within 1.5% of each other from the back side of the exhaust valves to the merge collector.
- Rotational firing order into the 4-1 merge collector. Only one of it's kind for the FA20.
- Double-Slip 4-1 merge collector with custom spring tabs to allow for proper heat expansion without the need for flex bellows. Only one of it's kind for the FA20.
- Minimal exhaust runner up sweep at the front of the engine ensures that radiant heat is kept to a minimum. This also makes this header SC friendly.
- Low profile design allows the factory metal under tray to bolt back into place without any modifications or spacers.
- Each mandrel bent exhaust runner is constructed using the fewest number of sections possible. This ensures perfect exhaust flow as well as eliminating the need for extra weld joints.
- All six exhaust port studs are readily accessible to allow for ease of installation as well as the ability to properly torque down each nut.
- O2 sensor bung placement does not require extending the O2 harnesses.
- No CEL codes.
MADE IN THE USA
Last edited by RJasonKlein; 07-07-2016 at 12:42 AM. Reason: Corrected a typographical error.
RJasonKlein is offline
Old 06-20-2016, 06:23 PM   #2
RJasonKlein
New photos added.
Old 06-24-2016, 06:48 PM   #3
RJasonKlein
Price reduced.
Old 06-29-2016, 10:40 PM   #4
RJasonKlein
Bump - one of the best headers available, like new, and priced right.
Old 07-07-2016, 12:41 AM   #5
RJasonKlein
Sale pending.
Old 07-07-2016, 12:43 AM   #6
RJasonKlein
Sold.
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header (200+whp 93 pump gas) ptuning Engine, Exhaust, Transmission 616 01-30-2020 09:59 AM
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header(Second Batch pre Order) Peace@Ptuning Engine, Exhaust, Bolt-Ons 57 04-16-2015 04:38 PM
*BRZ Part Out* PTuning equal length header xDanger_208x Engine, Exhaust, Bolt-Ons 2 03-31-2015 01:43 AM
