Old 08-09-2016, 10:34 PM   #1
86TX
86TX's Avatar
Drives: 2016 FRS
FRS Trunk Question
Sorry if I am not in the right area of the forum, it wouldnt let me post in the exterior section because I didnt have "enough permission" but I have come across a problem.
I have the 2016 FRS with the rear spoiler and back up camera. I want to eventually get the Rocket bunny V1 Wing. But I found out that the stock spoiler will cause the trunk to have holes in it. So i thought about buying a new oem trunk without the spoiler, but now I have to set up the back up camera.
My question is, what would be the easiest way of going about this? Should I do what I mentioned above and just drill holes in the new trunk i buy an install the Backup camera myself? Or should i try to find someone to do a trunk swap with? Throw me suggestions please.
Thank you and hopefully you guys go easy on me and dont troll.
86TX is offline   Reply With Quote
Old 08-09-2016, 11:01 PM   #2
Hi 86TX .....
If I understand you correctly, if you remove your existing trunk spoiler, it will leave holes. It already has the backup camera installed.
You wish to mount a new V1 wing.
Heck, I'd just use the existing trunk lid and plug the holes. Maybe with a plug that you have painted to match the color of your car ....... or maybe just leave the plug black.
Old 08-09-2016, 11:08 PM   #3
86TX
86TX's Avatar
Drives: 2016 FRS
Hi 86TX .....
I will look up plugs for the trunk, didnt know they had them to be honest. I hope they are unnoticeable :P Thank you i didnt even think of that!
Old 08-09-2016, 11:16 PM   #4
Any plastic or rubber plug from a hardware store would work, or maybe an auto parts store has some nifty ones.
Well, they will be noticeable until you put the big wing on ..... then most folks will be looking at that ......
Old 08-09-2016, 11:21 PM   #5
PNW FRS
PNW FRS's Avatar
If your profile pix is showing a dark colored 86... some black plugs would hardly be noticeable once the V1 is installed.
If your wallet can stand the pain, a body shop can fill the holes and repaint (colormatch) the trunk.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 08-09-2016, 11:21 PM   #6
86TX
86TX's Avatar
Drives: 2016 FRS
Yeah I will probably go with this then!
Old 08-09-2016, 11:24 PM   #7
86TX
86TX's Avatar
Drives: 2016 FRS
Yeah I have the Raven Black 86, it is metallic, so idk how the plugs will match, but for a temporary fix I shall use the plugs until I can save up for the weld and colour match.
Old 08-10-2016, 11:12 AM   #8
FX86
not really metallic when it's dirty..just don't wash it and it will match
Old 08-10-2016, 11:32 AM   #9
86TX
86TX's Avatar
Drives: 2016 FRS
lol i see what you did there
Old 08-11-2016, 09:51 AM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
You can remove the trunk garnish (where the factory back up cams are mounted) and swap it to the wingless trunk.
Old 08-11-2016, 11:05 AM   #11
Futaba
Futaba's Avatar
Drives: GT86
it does leave holes sadly!, lots of them, wings like the TRD cover it nicely, but other wings such as RBv1 wont.
You will likely find that the RBv1 wing covers the square holes (though it might not!), so you will have to plug the holes.
There are a few ways around it though:
- Swap boot lids with someone who wants a TRD/etc wing
- Install a TRD wing and just shave a little off of the plastic so the RBv1 wing fits on too, might look a little weird though.
- Fill in and sand flat, then either paint or get just the boot lid wrapped.
- Use plastic plugs to block the holes.
Regardless of which option you take, check each hole carefully, if you see any exposed metal, mask off the area and use the appropriate color spray paint to paint over the exposed metal, or use a touchup pen, just make sure no metal gets left exposed, as it will eventually rust and look a mess.
Futaba is offline   Reply With Quote
Old 08-11-2016, 11:26 AM   #12
86TX
86TX's Avatar
Drives: 2016 FRS
Im trying to keep the Back up camera, so id probably just swap it with someone who also has a backup camera
Old 08-11-2016, 11:26 AM   #13
86TX
86TX's Avatar
Drives: 2016 FRS
Wow i am going to look into this thank you!
Swapping a BRZ trunk for a FRS question Skegrider Cosmetic Modification (Interior/Exterior/Lighting) 0 03-09-2015 04:40 PM
trunk swap question Jake360 Scion FR-S / Toyota 86 GT86 General Forum 3 02-13-2015 08:13 AM
Trunk Garnish Question kdbar Cosmetic Modification (Interior/Exterior/Lighting) 4 07-14-2014 03:48 PM
Question about trunk swaps MooseWRX Cosmetic Modification (Interior/Exterior/Lighting) 4 12-13-2013 09:17 PM
trunk measurement question sieeegel BRZ First-Gen (2012+) — General Topics 9 05-05-2012 12:27 PM
