Old 08-04-2016, 06:55 PM   #183
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by gramicci101 View Post
I'm sure you're right; I just want to see what they could come up with. The old closed deck STis were monsters back in the day, and technology has only progressed since then.
The EJ257 still is @ 305 HP, 2.5 L. Except when the glass pistons shatter (ringland issue). The very reason I went with FA20T in the WRX.
The STI block is excellent, the internals, not to much.
A 2.0 L like in the CLA 45 would be sweet. Stock with forged internals, 375 BHP
Anybody have a shoehorn?
Old 08-04-2016, 08:29 PM   #184
FRS Justin
Drives: 2013 Asphalt FRS
I made 710whp on a closed deck FA20 and I know it can hold more.... I stopped only because I used Pauter rods and Pauter said good to 700hp. Im debating on building another one with better rods just to see what happens....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
gramicci101 (08-04-2016)
Old 08-04-2016, 10:05 PM   #185
wbradley
Sarcastic SOB
wbradley's Avatar
Wow that's a lot of physics. Anyone here able to supply calculations? LOL
That's a ton on Nm/cylinder, bearings, crankshaft and more. OK so an F/A20 is no 2JZ but is that the highest anyone has claimed?
Old 08-07-2016, 12:41 PM   #186
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I have to wonder where the short-term/long-term undiscovered weaknesses are in the FA20 when you start pushing north of 700hp. I like watching others be guinea pigs while I patiently observe. lol
Fenix is offline   Reply With Quote
Old 08-07-2016, 12:56 PM   #187
Rods, rod bearings, valve train, pistons, crankshaft, crankshaft bearings, head gaskets, heads, crankcase, injector seals, ....... just to name a few .....
Old 08-07-2016, 01:08 PM   #188
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Justin, do you mind telling me what the peak rpm was for your 710whp? (Im doing this gentleman the math)
Old 08-07-2016, 01:42 PM   #189
Fenix
Fenix's Avatar
In general, yep.
Old 08-07-2016, 02:20 PM   #190
FRS Justin
710whp achieved Around 6600rpm... I have done the old missed shift 8600rpm thing
710whp
Old 08-07-2016, 02:57 PM   #191
Lantana frs
Drives: 13 frs red
Being 52 yrs old and a veteran of muscle cars, bikes etc it sometimes strikes me as odd that a car that does 0-60 in 6 seconds, 14 second quarters, gets 25 miles per gallon and can go 100k plus is touted as being slow but "balanced". Possibly because the rolling menopause crate next to us isnt that far behind? Its all relative. I remember when 100 hp/litre naturally aspirated was considered exotic. I still have my eyes on another long tube header though. Never enough
Lantana frs is offline   Reply With Quote
The Following 4 Users Say Thank You to Lantana frs For This Useful Post:
DriveDriftDogfight86 (08-08-2016), new2subaru (08-07-2016), Tcoat (08-07-2016), Ultramaroon (08-07-2016)
Old 08-07-2016, 03:58 PM   #192
Nvm hp. Where is peak torque, and is the curve sharp?
Old 08-07-2016, 07:28 PM   #193
gramicci101
Off Topic
It seems like the engine block is the weakest point. Whenever someone talks about blowing an engine there's always a hole in the block.
The Following User Says Thank You to gramicci101 For This Useful Post:
Ultramaroon (08-08-2016)
Old 08-07-2016, 08:30 PM   #194
wbradley
Sarcastic SOB
wbradley's Avatar
Which appears to be result of a broken rod or shattered pieces of piston shooting through the cylinder wall.
Old 08-07-2016, 08:35 PM   #195
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Well I'm sure there is a reason why Subaru replaced so much thing in our engine in 1st real update/refresh? lol
I'm sure our engine will hold up maybe 200k but it's not Lexus or other older Subaru boxers.
Old 08-07-2016, 08:49 PM   #196
Lantana frs
Drives: 13 frs red
Dont panic. Sometimes "improvements" are cost related. If I find a cheaper plating process im going to tout it as "friction reduction". I expect minor changes to valve train geometry and a few other things but the use of a manifold specific to the m/t puzzles me as does having 2 engine packages for a low volume niche product.
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Longevity of the the Twins? FRSBRZGT86FAN Scion FR-S / Toyota 86 GT86 General Forum 41 04-13-2014 03:51 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Longevity/Reliability of Enhine Mark Ducati Forced Induction 10 11-05-2013 09:43 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
