Old 08-05-2016, 08:20 PM   #1
WWFT86
Drives: 2017 BRZ Limited
Best way to eliminate the torque dip
Found older posts but would like to see what's the mid-2016 opinion on eliminating the torque dip while minimizing noise?
Will the OFT stage 1 alone do it? If it's a aftermarket header which one is known to be quietest?
Thanks
WWFT86 is offline   Reply With Quote
Old 08-05-2016, 08:28 PM   #2
Don't think the mid 16 opinions have changed much.
Old 08-05-2016, 08:28 PM   #3
Ernest72
Thanks for asking this. I have been doing the same, reading everything. So far nothing I have read gets rid of it, just makes it more shallow and not as wide. I think it will have to be louder but I'll wait for some more experienced to respond.
Old 08-05-2016, 08:30 PM   #4
The only way to get rid of it is to do an engine swap. Or just learn to drive around it. Or just ignore it.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
e_lunatic (06-01-2017), gramicci101 (08-06-2016), Hoahao (08-06-2016), humfrz (08-06-2016), Kenny_LongWrench (08-06-2016), lantsalot (05-31-2017), nikitopo (08-06-2016)
Old 08-05-2016, 08:37 PM   #5
Lantana frs
Drives: 13 frs red
An equal length long tube header and tune will put a hump where the dip was. I had a catted p&l. Only drawback for me was that it was soft below 3k rpms. Could've been tune related though. Mounted to stock op and catback it was no louder than stock.
Lantana frs is offline   Reply With Quote
Old 08-05-2016, 11:37 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Get a powerful car. If not engine swap.
Old 08-06-2016, 12:17 AM   #7
Brayden_23
Drives: Asphalt 2015 FRS
What is wrong with the torque dip?? If I understand correctly, many cars have it - including Porsche. It's almost like our own version of VTEC; engine gets louder and louder without much happening, then WHAMMO, here's the torque you want!
IMO the torque dip isn't hard to handle. Daily driving you barely notice it, and if you are on the track your RPMs barely ever fall that low (depending on which track) to have it make a difference.
That being said, I don't think there is any way to get rid of the dip without getting louder as everything you need to do to get rid of it involves straying from stock which typically means getting louder. You can try to stay quiet by finding a catted header and getting a tune but even then technically you will still probably be louder than stock. Even going the boost route means ramming more air through your engine which comes out your exhaust meaning more noise...
Like others have said, you can always engine swap, but this probably isn't worth it if you aren't trying for insane numbers
Brayden_23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brayden_23 For This Useful Post:
humfrz (08-06-2016), WWFT86 (08-23-2016)
Old 08-06-2016, 12:29 AM   #8
Teseo
Drives: frs
FI
Engine swap
Trade in?
Old 08-06-2016, 01:15 AM   #9
WWFT86
Thanks LantanaFRS for the suggestion. I like the fact that the cat has lifetime warranty for longevity/ROI sake.
So the catted P&L with everything else oem gives a stock like volume (which I frankly prefer).
Any other headers to consider or P&L is it? Thx
Old 08-06-2016, 01:18 AM   #10
WWFT86
I don't need way more HP or torque. Simply want a more linear delivery instead of a dip between 3500 and 4500 rpm... so engine swap is out of question for now
Different car - I actually like the BRZ and the balance it has so not going there either.. thx
Old 08-06-2016, 01:24 AM   #11
WWFT86
Just want the power delivery to be more linear so "more shallow" will do.. don't necessarily need to completely gt rid of the dip. Noise level is a consideration though as I work shifts.
Old 08-06-2016, 01:27 AM   #12
Lantana frs
Drives: 13 frs red
Hks, jdl for starters. There are cheaper uels available. Vishnu can get u a header and tune for 1100 I believe. For me the header and tune combo make a day and night difference.
Old 08-06-2016, 01:36 AM   #13
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
If you want to eliminate that dip, you must sacrifice some noise. With that said, it is certainly possible.
My friends runs ACE 350, Perrin 2.5 in, JDL Ultra Quiet FP, JRSC, flexfuel, and a custom tune. The dyno reading is just an uphill slope at an incline of 45 degrees. I could not believe what I saw. It's a different car. Specifically, like a different engine. Chassis was always brillant.
Sent from my SAMSUNG-SM-G900A using Tapatalk
ohmai18 is offline   Reply With Quote
Old 08-06-2016, 01:41 AM   #14
DAEMANO
Time Traveller
Header and a tune... UEL or long tube EL + OFT or ECUTek add e85 if available in your area will give you more power across the board.
Least harmful additives to eliminate crickets Muskokan Issues | Warranty | Recalls / TSB 46 05-07-2017 01:10 PM
Eliminate oil pressure switch? @Art_Mighty Engine, Exhaust, Transmission 13 09-17-2015 10:23 PM
The truth behind the option to dealers to eliminate the scion part Frstorm Scion FR-S / Toyota 86 GT86 General Forum 8 08-21-2013 04:37 AM
Best Method to Eliminate Sand ShoShin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-29-2013 05:45 PM
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 10:40 PM
