#29 | |
I Love custom Turbo kits
Drives: Limited BRZ
On another note, I have installed all kinds of FP on this car, and I currently run the FB WAlbro 485 and it's the best quality of all and the kit provides for a nice fit even though the pump is quite large.
#30 | |
Drives: Scion FR-S
#31 |
Drives: Late 2014 Subaru BRZ
I haven't had a chance to run e85 or anything at this point. I was saving for a real fuel system before making that switch. I do have my own home made fuel injector flow bench I made using an old fuel pump and regulator out of my saturn. I've had to test injectors in the past. I'll more than likely check this pigs to see if they are pissing or spraying.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#32 |
I got the bad today. The guys at Fullblown next day shipped the fuel pump kit to me.
Full kit in the box ![]() Basket Spacer to make up for the extra pump size ![]() Sock, nothing else to say ![]() Walbro 485, has the spacers installed and idiot poof ![]() I ran out of day light and that damn jeep is in my garage, so i'm going to have to do this in the drive way hopefully after work tomorrow.
2014 Subaru BRZ
#33 |
5 crank starting and A/R swinging problem is now resolved with the Walbro 485. The car starts on in 1 crank. Compared to the factory fuel pump or Fullblown 270 fuel pump, you know you have a Walbro 485 in your tank. Oh boy you can hear it prime. I'm so happy that issue is resolved. I have zero cons & the car now has it's balls back. Worth every penny!
Thank you Full Blown Motorsports!
2014 Subaru BRZ
| The Following 2 Users Say Thank You to GsxrMe For This Useful Post: | DustinS (08-04-2016), ShadowReaper (03-26-2018) |
#34 |
Drives: 2013 Ultramarine FR-S
Sounds Like I need to double check my pump. Just installed a DW 300C right before I made the switch to ecutek with flex-fuel. No issues until after the ecutek switch.
#35 |
Drives: 2016 Scion FR-S
#36 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Good read.
I havent been having the same exact issues but my fuel trims are well into the negatives, not sure if that's good. Also, sometimes I start the car just fine but the RPM needle won't go all the way to 9000 RPM and bounce back to the actual read, it'll just go straight to it. I definitely do plan on getting Walbro 485 tho. IS THIS PUMP JUST A DROP-IN?
Instagram: Gabe.it.the.ole.college.try |
#37 |
Never did figure out. Fuel Trims were off all the way up until it chucked a rod through the block. Didn't find anything weird on tear down either.
#38 |
BAE
Drives: Asphalt FRS
Anyone else ever figure out this issue?
| FS: Moto-East Flex Fuel Kit - OEM Fuel Pump | FR-Shred | Engine, Exhaust, Bolt-Ons | 1 | 05-16-2016 07:28 PM |
| Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 04:52 PM |
| Fuel pump failure? | EMS Guy | Issues | Warranty | Recalls / TSB | 6 | 08-29-2014 09:31 AM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 11:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
