DustinS, FullBlown
Old 08-01-2016, 10:02 PM   #15
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by daironchef View Post
My fuel pump died/ not pushing 60psi, BRZ/FRS fuel line needs to be at 60psi, if it is not you might need to check your fuel system.
Sent from my Nexus 6P using Tapatalk
I would love to but I don't see a location to hook my fuel pressure gauge to.
I was talking to delicious tuning and full blown via email to build an e85 return style system but now my car got word of replacing the current system and it decided to kill itself?
This really sux because I just purchased a jeep wrangler for a daily and I don't want 2 project cars atm. Ideally I wanted to finish the jeep and then upgrade the brz more.
I'm really like two seconds from throwing my wallet at full blown for the Walbro 485 kit
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-01-2016, 10:21 PM   #16
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I think I remember a fuel pressure reading in ecutek.
Old 08-01-2016, 10:25 PM   #17
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
What tune you running? Custom shop tune or an off shelf for the kit stand alone?
tofurun is offline   Reply With Quote
Old 08-01-2016, 10:51 PM   #18
GsxrMe
GsxrMe's Avatar
Full Blown tune, Its been awesome for over a year. All of a sudden the cars gone to complete shit. No balls, A/F is all over the place, 5 crank start. After work tomorrow i'm going to pull the pump and inspect. If I have to and I don't see anything wrong with the Fullblown pump that came with the kit, i'm going to drop the factory pump in the car and give it a shot. If the factory pump fires up right away i'll know.
When the car try's to start, if i give it a little throttle I can get it to turn on faster.
That's the direct injectors only, 580-600 PSI idle
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post:
DustinS (08-02-2016)
Old 08-02-2016, 02:20 AM   #19
daironchef
Drives:
There is no reading from ecutek, as there is no fuel pressure sensor built into the fueling system. You would need to attach a pressure gauge in series before the rail, and if its long enough it might able to sit on the windshield so u can monitor it while the hood its down. You should check the pressure while its in idle and during WOT.
daironchef is offline   Reply With Quote
Old 08-02-2016, 08:26 AM   #20
GsxrMe
GsxrMe's Avatar
I broke down and purchased a Walbro 485 kit from Fullblown last night. Well see how it go's, kinda wanted it anyways.
All the fingers are pointing at pump. I was thinking if it was an injector the car should start easier but sound like shit with a missfire sounding idle, like it's running on 3 cylinders. The car sounds normal just doesnt start up right away and has a/f bouncing trick.
I'll update everyone when it's installed.
2014 Subaru BRZ
Old 08-02-2016, 11:37 AM   #21
tofurun
tofurun's Avatar
This is incorrect. I read fuel pressure all day on my head unit using idatalink tapped into the obd2 harness. The only reading I know of not coming up is the oil pressure. I don't believe Ecu tec will read oil pressure but I know it will read fuel pressure.
Old 08-02-2016, 12:20 PM   #22
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Can you read both high, (direct) and low, (port) pressure fuel systems? Usually it's only the high pressure system that is readable.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 08-02-2016, 02:32 PM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There is no rail fuel pressure sensor on the car. The only fuel pressure sensor is for the HPFP.
Old 08-02-2016, 06:10 PM   #24
tofurun
tofurun's Avatar
^^^^^ I think you would need an aftermarket fuel pressure gauge between the rails and the regulator. Correct me if im wrong.
Old 08-02-2016, 06:12 PM   #25
Sportsguy83
Drives: Limited BRZ
Yes, you would need an aftermarket gauge, you're correct.
Old 08-02-2016, 06:13 PM   #26
tofurun
tofurun's Avatar
that would be a 0-100 gauge where as the HPFP reading that can be pulled off the OBD2 which is like a 500 to 2k plus reading
Old 08-02-2016, 06:14 PM   #27
Sportsguy83
Drives: Limited BRZ
Exactly.
Old 08-03-2016, 08:41 AM   #28
GsxrMe
GsxrMe's Avatar
Sorry I've been busy at work. I should have the pump today or tomorrow. I've been using the torque app to monitor the direct injection pressure. When I get a complete return systle fuel system with a FPR I will install a fuel pressure sensor and gauge.
The factory fuel rails and system makes it to gimmicky to install a fuel pressure sensor.
2014 Subaru BRZ
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump failure? EMS Guy Issues | Warranty | Recalls / TSB 6 08-29-2014 08:31 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
