DustinS, FullBlown
Old 08-03-2016, 04:29 PM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by GsxrMe View Post
Sorry I've been busy at work. I should have the pump today or tomorrow. I've been using the torque app to monitor the direct injection pressure. When I get a complete return systle fuel system with a FPR I will install a fuel pressure sensor and gauge.
The factory fuel rails and system makes it to gimmicky to install a fuel pressure sensor.
Agreed.
On another note, I have installed all kinds of FP on this car, and I currently run the FB WAlbro 485 and it's the best quality of all and the kit provides for a nice fit even though the pump is quite large.
Old 08-03-2016, 05:14 PM   #30
Andew727
Drives: Scion FR-S
I would love to but I don't see a location to hook my fuel pressure gauge to.
I was talking to delicious tuning and full blown via email to build an e85 return style system but now my car got word of replacing the current system and it decided to kill itself?
This really sux because I just purchased a jeep wrangler for a daily and I don't want 2 project cars atm. Ideally I wanted to finish the jeep and then upgrade the brz more.
I'm really like two seconds from throwing my wallet at full blown for the Walbro 485 kit
i didnt read everything on here but i am having some fuel issues as well... if youve run e85 for sometime now you may want to stick your injectors on a flow bench and test them. i had a direct injector completely blocked.
Andew727 is offline   Reply With Quote
Old 08-03-2016, 10:18 PM   #31
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I haven't had a chance to run e85 or anything at this point. I was saving for a real fuel system before making that switch. I do have my own home made fuel injector flow bench I made using an old fuel pump and regulator out of my saturn. I've had to test injectors in the past. I'll more than likely check this pigs to see if they are pissing or spraying.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-03-2016, 10:29 PM   #32
GsxrMe
GsxrMe's Avatar
I got the bad today. The guys at Fullblown next day shipped the fuel pump kit to me.
Full kit in the box
Basket Spacer to make up for the extra pump size
Sock, nothing else to say
Walbro 485, has the spacers installed and idiot poof
I ran out of day light and that damn jeep is in my garage, so i'm going to have to do this in the drive way hopefully after work tomorrow.
2014 Subaru BRZ
Old 08-04-2016, 10:02 PM   #33
GsxrMe
GsxrMe's Avatar
5 crank starting and A/R swinging problem is now resolved with the Walbro 485. The car starts on in 1 crank. Compared to the factory fuel pump or Fullblown 270 fuel pump, you know you have a Walbro 485 in your tank. Oh boy you can hear it prime. I'm so happy that issue is resolved. I have zero cons & the car now has it's balls back. Worth every penny!
Thank you Full Blown Motorsports!
2014 Subaru BRZ
The Following 2 Users Say Thank You to GsxrMe For This Useful Post:
DustinS (08-04-2016), ShadowReaper (03-26-2018)
Old 08-04-2016, 10:15 PM   #34
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Sounds Like I need to double check my pump. Just installed a DW 300C right before I made the switch to ecutek with flex-fuel. No issues until after the ecutek switch.
Old 03-26-2018, 09:52 PM   #35
Dru670
Drives: 2016 Scion FR-S
Did you figure your problem out? Was it the fuel pump?
Dru670 is offline   Reply With Quote
Old 03-26-2018, 11:20 PM   #36
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Good read.
I havent been having the same exact issues but my fuel trims are well into the negatives, not sure if that's good.
Also, sometimes I start the car just fine but the RPM needle won't go all the way to 9000 RPM and bounce back to the actual read, it'll just go straight to it.
I definitely do plan on getting Walbro 485 tho. IS THIS PUMP JUST A DROP-IN?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-27-2018, 10:34 AM   #37
DustinS
DustinS's Avatar
Never did figure out. Fuel Trims were off all the way up until it chucked a rod through the block. Didn't find anything weird on tear down either.
Old 04-07-2018, 04:35 PM   #38
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Anyone else ever figure out this issue?
Decimus is offline   Reply With Quote
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 07:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
Fuel pump failure? EMS Guy Issues | Warranty | Recalls / TSB 6 08-29-2014 09:31 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 11:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
