Old 08-01-2016, 04:15 PM   #323
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
Quick question must you run headers? If not how much power are you losing on stock manifolds. Thanks,
Gearbanger is offline   Reply With Quote
Old 08-01-2016, 04:17 PM   #324
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
HKS recommends that you run the HKS manifold. In theory you could still run the stock manifold, but we have no data on how much power loss that would be. If you're running the HKS tune, it was tuned for the HKS manifold also.
Torry@HKSUSA is offline   Reply With Quote
Old 08-01-2016, 06:20 PM   #325
klear
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
Originally Posted by jimmyw86 View Post
I've been having some rough starts in the morning on my vehicle. I have the v3 running e85. Temperature this morning was 62 degrees. Also notice that when I start the car first thing in the morning, it will idle a little rough for the first minute or so. I did put a k&n air filter in and recently sprayed the maf sensor with maf sensor cleaner and it ran much better. Now it's doing it again. Wonder if more oil got onto the sensor.
The rough start is not your SC it is your E85, On E cold starts are interesting.
klear is offline   Reply With Quote
Old 08-01-2016, 10:03 PM   #326
blindfold
Drives: brz
anyone tried the smaller pulley kit on 93/98 onctane fuel? I do not think we need 700cc injectors to run with the smaller pulley with straight gasoline? Does anyone have set figures of pressure for smaller pulley kit? And if it's an HKS part upgrade, anyone have the part number by chance?
Thank you very much.
blindfold is offline   Reply With Quote
Old 08-02-2016, 08:21 AM   #327
Torry@HKSUSA
Drives: HKS
Part number is 12002-KK001.
As for running the smaller pulley on stock injectors, I would not recommend that.
Old 08-02-2016, 07:53 PM   #328
Gearbanger
Gearbanger's Avatar
How does this kit compare to the Vortech?
Old 08-02-2016, 07:57 PM   #329
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Originally Posted by Andew727 View Post
go with a Tial QRJ full recirculating BOV. i have one on my car with a high boost pulley. sounds amazing, looks better, and in my opinion performs better than the bypass valve.
pictures on my IG: andyb727
ill have videos up soon once i fix the crank pulley pin that i bent.
Your setup is much different from the V3 we are running. Looks like you can recirculate a bit differently.
HuntingtonFRS is offline   Reply With Quote
Old 08-03-2016, 08:13 AM   #330
Andew727
Drives: Scion FR-S
v1, v2, and v3 all are able to run a recirculating bov or bypass valve like the kits are supplied with. you just need to make sure you are running the correct spring inside the bov and a tune wouldn't hurt. are you still running the draw through maf? or did you go speed density with a blow by maf? if you are using a draw through maf you can locate the bov anywhere you want but if you use a blow by then it needs to be furthest from the maf sensor as possible.
Andew727 is offline   Reply With Quote
Old 08-03-2016, 08:17 AM   #331
Andew727
Drives: Scion FR-S
i would recommend better fuel (e85) or consider water meth injection if youre adding more boost then 9-10 psi.
p.s. evasive performance sells the pulley upgrades
Old 08-03-2016, 09:15 AM   #332
Andew727
Drives: Scion FR-S
[IMG][/IMG]
[IMG][/IMG]
The Following User Says Thank You to Andew727 For This Useful Post:
zeal86 (08-03-2016)
Old 08-03-2016, 09:57 PM   #333
blindfold
Drives: brz
Yessir, I believe I was told by the tuner that the HKS intercooler is already almost at its limits with regular gasline at stock setting of .6bar, so I have not gone the way with bigger injectors/pump to go with gas.
Did you guys swap out the oem pressure sensor, I was talk it max out at at .38bar, but most of air flow is still metered with MAF sensor close to the airbox, does swapping out a 3bar sensor make any difference in terms of power/feel? Thanks.
Old 08-04-2016, 09:39 AM   #334
Andew727
Drives: Scion FR-S
i didnt need one with the stock set up from HKS, but when adding more boost and removing the restrictor plate you may... also keep in mind im on the version one kit. the 2nd and 3rd version kits are different. i didnt need a 3 or 4 bar pressure sensor with the base kit and i believe the second and third versions were able to accomplish more power with less boost pressure and impeller speeds on the compressor so i doubt a base kit would need to upgrade. i will swap out my sensor with a 3bar when i remove the restrictor/reduce pulley size more and tune the car with james martin on the 21st. ill let you know how that goes.
Old 08-07-2016, 03:59 PM   #335
HuntingtonFRS
What did you guys use for a template to paint HKS on the intercooler?
Old 08-08-2016, 07:01 PM   #336
wheelsun
wheelsun's Avatar
Drives: 2015 WRB BRZ
My cars currently in the shop having the V3 installed, excited to be part of this group soon!
wheelsun is offline   Reply With Quote
The Following 3 Users Say Thank You to wheelsun For This Useful Post:
craigpitts7 (10-21-2016), CxG (08-10-2016), zeal86 (08-08-2016)
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
