Old 08-01-2016, 02:05 PM   #1023
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Latest test logs:
More info soon.
Installed Mods:
Old 08-01-2016, 04:10 PM   #1024
stevo585
Drives: White 2014 BRZ
Originally Posted by Sojhinn View Post
Latest test logs:
More info soon.
Wow how do you have so much boost? That's the V2 TQ250 right?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
KoolBRZ (08-01-2016)
Old 08-01-2016, 04:11 PM   #1025
Sojhinn
Sojhinn's Avatar
More info soon. 😁
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
l0aded (08-05-2016), stevo585 (08-01-2016)
Old 08-01-2016, 05:31 PM   #1026
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
the NEW V1 SQ3000
It's not a V2 TQ250, it's the NEW V1 SQ3000 with THREE squirrels in a cage running madly to get their peanuts. The higher boost comes from a highly technical process involving roasted peanuts, instead of plain peanuts, a larger front-mounted squirrel cage, and of course, the roasted peanut feeder. There is also a new pulley fed conveyor belt system using pellet stove technology to feed more peanuts as the engine speed increases. This feeder passes the peanuts by the special exhaust roasting pan, before feeding them into the cage, providing more power through better flavor! Totally cutting edge technology. The squirrels have even been shaved to reduce wind resistance, resulting in a 0.000001% increase in passing wind efficiency. Best of all, it uses renewable energy, so it's GREEN technology.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
DAEMANO (08-01-2016), Sunrise161 (08-02-2016)
Old 08-01-2016, 05:32 PM   #1027
Sojhinn
Sojhinn's Avatar
Holy shit how did you hear?
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 08-01-2016, 05:49 PM   #1028
KoolBRZ
KoolBRZ's Avatar
The roasting pan. It was impossible to keep it secret with the smell of roasting peanuts wafting up out of the engine bay. Once the peanut smell was out, it was only a matter of time before industry spies started using xray and sonigram technology to piece together the rest. Also, a squirrel was bribed into spilling the beans, or peanuts, and the rest is history.
The Following User Says Thank You to KoolBRZ For This Useful Post:
Sojhinn (08-01-2016)
Old 08-01-2016, 06:03 PM   #1029
Urmyson
Latest test logs:
More info soon.
I want to be first in line for what ever upgrade this is!!!
Urmyson is offline   Reply With Quote
Old 08-01-2016, 06:29 PM   #1030
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
While this is currently factually correct, V-CMunk .1 is currently testing.
Advantages:
A chipmunk has pouches inside its cheeks, which it typically uses for storing food while foraging. After experimental hypnosis (the chipmunks had to learn English first of course), a cheek-stuffing parallel between throttle application and feeding frenzy was achieved such that the munks fed normally under low/moderate gas pedal input, but would fat kid on Smarties when the go pedal was mashed, developing instant cageyboost.
In addition, the munks weigh a few ounces less. And, as they run with tails straight up, an unexpected aerodynamic algorithm anomaly was identified wherein the tail air splice had a significant effective on cage spin vortices to the degree that stock suspension handling improved even beyond coilovers.
A skunkworks, skunkworks project is currently in the, um, skunkworks.
geezerbrzeezer is offline   Reply With Quote
The Following 4 Users Say Thank You to geezerbrzeezer For This Useful Post:
DAEMANO (08-01-2016), KoolBRZ (08-01-2016), Sojhinn (08-01-2016), Sunrise161 (08-02-2016)
Old 08-01-2016, 08:31 PM   #1031
KoolBRZ
KoolBRZ's Avatar
Advantages:
Good luck keeping that a secret. Those industrial espionage agents will sniff that out in a hurry. Although, a skunkworks unit could also double as anti-theft. That would really teach those parking valets to show respect.
Old 08-05-2016, 03:31 PM   #1032
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i am wondering if Rob or Fenton can make "Phantom E.SC" emblem we can buy and stick it
Old 08-05-2016, 05:08 PM   #1033
eft86
Drives: 2014 Scion FRS, 2016 Jeep Cherokee
Assistance is greatly appreciated! My ESC is en-route and slated to arrive next week and I'm just trying to line up all my ducks in a row here. I currently have an OFT and will be using that but I can't for the life of me seem to find a working link to an OFT map specifically designed for the ESC. If anybody can help that would be amazing. More specifically I am running stock headers and just the ESC
eft86 is offline   Reply With Quote
Old 08-06-2016, 09:14 AM   #1034
keen as
keen as's Avatar
Drives: 86 GT MT
https://drive.google.com/open?id=0Bw...0hjaEJDSzN0WFU
These may be old. Hope it helps you. You could ask Shiv, contact Openflashtablet. I have found the OpenFlash guys provide poor service.
keen as is offline   Reply With Quote
Old 08-06-2016, 10:53 AM   #1035
WNDSRFR
Drives: FR-S,GTI
Made my own.
Old 08-06-2016, 11:02 AM   #1036
Winjr
Drives: 2013 Subaru BRZ Premium
Starter Battery
Was having problems starting the car, started about a week ago. Finally had to jump it, and this is how I found the starter battery. Any ideas what happened? I've been running the basic 1.0 kit about 2 1/2 years now, this is the original starter battery. Ordered a new one from battery mart, which was delivered just 26 hours after ordering - great service!
Winjr is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
