Old 10-10-2015, 03:10 PM   #43
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by rice_classic View Post
If anyone is telling you that Double Clutching is harder on the transmission vs regular shifting, they probably need to wear a helmet before they leave the house.
Double Clutching is quite literally syncing the 2 shafts without having to use the synchro to do it. When you double clutch your synchros do almost no work.
Edit: that civicforum link is specifically asking about the clutch/engine. Double clutching means you are pressing on the clutch pedal more often but usually when a double clutch is performed so is a rev match. No extra wear or stress occurs on the engine (probably less due to rev match) and the clutch is doing a negligible amount of extra work. The only thing that's actually getting more use is the throwout bearing. Reading that thread cost me 2 IQ points. I feel dumber after reading it.
I have read, from Road and Track, I believe, that double clutching is better for the car IF done correctly. I don't know what that means exactly, but I suppose if the target rpm were 3000 and you revved the engine and tranny to 6000 before slamming into the lower gear you would be doing more harm than good by your ham-fisted attempt.
It does take some skill, which some people have a hard time developing.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-10-2015, 08:03 PM   #44
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The though that one would be "doing it correctly" was assumed. Doing anything incorrectly is well... incorrect.
PRO86 | WTCC | STL
Old 07-30-2016, 10:46 PM   #45
86Tony
Drives: 2015 AOZORA EDITION
Originally Posted by pepelocuas View Post
Are this people who blame always the driver being paid by toyota?????
I have replaced 2 transmission on a2013 frs and i explain that car was 100% stock and alway be driven and shift below 3500 rpm an a bunch of people dont believe it and say that is drivers fault. I am in my 60 and i always drove manual and i never hsd to replace a transmission. Give me a brake this Aisin transmission is GARBAGE. Everybody has grinding problems and shifting problems and always is drvers fault
Aisin had the same problems on a Honda S2000 ten years AGO and still didnt figure it out!!!
exactly.same way how i feel. i hope the 2017 tranny will be much better
86Tony is offline   Reply With Quote
Old 07-30-2016, 11:08 PM   #46
radroach
Drives: car
Honda s2000 box wasn't Aisin, right?
5th Gear Grind at Freeway Speeds? l0aded Issues | Warranty | Recalls / TSB 124 03-21-2018 07:04 PM
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 09:39 PM
Gear and shift knob vibration and grind Howardwei Issues | Warranty | Recalls / TSB 3 07-11-2013 10:37 AM
Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? ahausheer Issues | Warranty | Recalls / TSB 7 08-26-2012 03:31 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
