Old 09-28-2013, 12:44 AM   #1
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
6th Gear Grind & Replaced Transmission
So I've been having a grind on 6th gear for a long time I think since 5k miles or so.
I took my 86 in at 14.2k miles and I demanded they take apart my transmission and they said come back when toyota reps come.
They said that if there is no problem it would be $1000.00 labor charge - I told them take out the transmission there Is something very wrong.
So my 6th was damaged - it looked fine but a few of the teeth were chipped.
The worst was the synchros - apparntly my synchros were shot somehow.
Toyota agreed to take it out of their pocket on a replacement transmission - they said this was not warranted repairs.
But it seems that we have a lot of "grinding" issues on these forums.
They claimed that I was shifting too aggressively to which I had a blank face to their response.
We'll see how long this transmission lasts ..
Old 09-28-2013, 01:15 AM   #2
Dezoris
Dezoris's Avatar
Toyota agreed to take it out of their pocket on a replacement transmission - they said this was not warranted repairs.I
Did you skip gears when shifting? Ie going from 4th to 6th? Or 3rd to 6th?
Old 09-28-2013, 01:51 AM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
not often - the few times i did I would wait to rev match
Old 09-28-2013, 02:13 AM   #4
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I wonder if all these grinding gear threads were really user error and not the gearbox itself...
hmong337 is offline   Reply With Quote
Old 09-28-2013, 02:58 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
You gotta be moving pretty fast to aggresively shift into 6th lol
Old 09-28-2013, 03:00 AM   #6
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Is your frs a 2012 or 2013 manufactured one ?
Im at 14xx km and have no issues
Young_makaveli is offline   Reply With Quote
Old 09-28-2013, 03:04 AM   #7
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Yeah a grind in 6th? definitely not user error. Unless you're sitting there without the clutch pushed just jamming it into gear going 110 on the highway for funs.
boxer 2.5 is offline   Reply With Quote
Old 09-28-2013, 03:21 AM   #8
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
my sig says when I got the car - the first month they were sold lol
i was averaging 28 mpg btw lol
i didn't shifted aggressively - almost always casually
never had the opportunity to track/hdpe/autox
Old 09-28-2013, 03:22 AM   #9
Young_makaveli
Drives: 2013 frs
Sorry on tapatalk lol
Old 09-28-2013, 03:24 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
My car is in first 1000 vin. Dont notice any trans problems so far, at 20k miles
Old 09-28-2013, 04:11 AM   #11
Sporran
Drives: Metallic Grey 86
I'm not sure why that should even be an issue - my belief is that if the synchro's can't handle skipping a gear they have no business being in this gearbox in the first place.
The ratios are quite closely spaced so why should going from say 4th to 6th in our box be any different from going from 4th to 5th in a less sporty 5-speed vehicle?
I know there's many threads on this issue and many differing viewpoints too - I'm just trying to get a better understanding of what's going on with our gearbox.
I've been driving manual transmissions for over thirty years and never experienced anything like the issues this gearbox appears to have.
Sporran is offline   Reply With Quote
The Following 2 Users Say Thank You to Sporran For This Useful Post:
sierra (09-28-2013), tech4pdx (09-28-2013)
Old 09-28-2013, 04:45 AM   #12
MIKE_909
Drives: firestorm FR-S
I've had my trans replaced because of the synchro going out car was at 10k mile if anyone comes up with why there messing up that would be great news being I don't wanna have this problem again being they were a little stubborn to fix it in the first place
MIKE_909 is offline   Reply With Quote
Old 09-28-2013, 07:47 AM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Looks like just a bad batch of transmission, like everything else alot of people have no problems with it and others have weird problems like a 6th gear grind. Sound like a bad assembly, improperly pressed in gear or something like that...I mean a chipped 6th gear tooth? Sounds like something was binding, NOT being abused.
Rayme is offline   Reply With Quote
Old 09-28-2013, 08:02 AM   #14
Mikem53
Drives: FR-S 6MT
That not going to cause an issue.. That's BS..
My corvettes, both with a T56 and the TR6060 had CAGS
Which would force the shifter from 1st to 4th gear if you were under
A certain speed. I also skip gears in this car with no issues. That's never
Been an issue with manuals.
There is something wrong with this tranny in its build from the factory..
They have some defective parts or are built with bad tolerances..
Skip shifting is common and not harmful unless there is something defective.. These trannys are not that fragile..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
5th Gear Grind at Freeway Speeds? l0aded Issues | Warranty | Recalls / TSB 124 03-21-2018 07:04 PM
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 09:39 PM
Gear and shift knob vibration and grind Howardwei Issues | Warranty | Recalls / TSB 3 07-11-2013 10:37 AM
Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? ahausheer Issues | Warranty | Recalls / TSB 7 08-26-2012 03:31 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
