#4327 | |
Drives: '22 BRZ
#4328 | |
The Stig's German cousin
#4329 | |
Drives: 2013 Red 6MT Scion FR-S
Sent from my XT1254 using Tapatalk
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street http://yawmomentracing.blogspot.com/ YouTube Channel |
#4330 | |
Corvette convert
Maximizing exit speed was vital in all sections leading to extended acceleration zones, even at the expense of adding distance. One had to take full advantage of available runoff room to carry speed through the 90s. We were seeing 66 mph on Sunday; I'm not sure about Saturday, as this was our first time using SoloStorm and the day one logs were kind of jacked up. Saturday's course required three shifts into third, while Sunday took four. Fortunately for the two of us, our plan of attack was solid and we executed well enough to pull the 1-2 finish. The weekend's results were especially satisfying for us after having a similarly sound plan at Spring Nats, but failing to execute as well on day two. (Big props to Dan McCelvey for applying the pressure early with great driving on the second day in Lincoln). C Street is a great class with impressive diversity, so it's cool to see us in position to break the Nationals class entry record. Sorry to hear that.
John W. | 191 DS
#4331 |
Drives: 2015 FR-S
Had a pretty good time in Blytheville. I feel like I made McCelvey work for his win. After the morning session on Saturday, I was leading by about 0.5 seconds. We both coned our fast runs in the afternoon session and he was leading by about 0.3 seconds going into Sunday. I couldn't put together a good clean run on the right side on Sunday and he ended up winning by 0.460 seconds. I was just happy being this close to McCelvey after the show he put on in Lincoln at Spring Nats in a RX-8.
The course possibly favored the FR-S a little better, since on the way out we were both on the rev-limiter and thus I had a few more mph on the way out. Here is a video:
#4332 |
Student Driver
Drives: 2016 Subaru BRZ Limited
18" Wheels?
Has anyone tried running 18" wheels in C Street? If so, is there any advantage?
Rules allow wheel diameter 1" larger than stock. I'm getting ready to replace my stock rims, and I'm wondering whether to go for 17s or 18s. Any feedback would be appreciated. |
#4333 |
Drives: In Perfect Control At All Times
I would try... but haven't found any 7J 18's that I think are likeable enough to buy. You have?
#4334 | |
Drives: '14 FRS TT5
I don't have any data to backup my thoughts, but crisper handling doesn't necessary equate to quicker lap times, especially when the 17's with stiff walled tires like the Bridgestones are already crisp. The increased wheel weight will definitely slow down acceleration. So my short answer is no, and I don't think it's even worth testing. Some here have done testing the opposite direction (@seanrtr) and dropped down to a 16" wheel to save wheel weight. I don't think his tests were entire conclusive (you'll have to search back a few posts), but they didn't seem to yield a huge advantage. Speaking of Sean, sorry to hear about the injury, that sucks man! Hope you have a speedy recovery.
Follow my NASA TT5 build here: JHill Motorsports
#4335 | |
C-Street AutoX
Thanks. I think if I could get an ultra lightweight wheel, with the correct offset, the 16's may actually be the correct setup. The 225/50/16 Bridgestone is wider, and shorter than the 225/45/17. To me, the RE71R has a stiff enough sidewall, that actually adding more sidewall seemed to make my car easier to 'feel' and drive at the limit. I won't know the true potential of this setup until my tires have more runs, which sounds like it won't be this year. I don't see how 18's would be of any benefit.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
| The Following User Says Thank You to SeanRTR For This Useful Post: | TMF (08-10-2016) |
#4336 | |
C-Street AutoX
Question, is McCelvey actually going to try and run those stupid BFG tires @ Lincoln? I assume he was running those because he preferred their superior contingency, and figured he could cover the field? I'd be very surprised if a big player like him choses to run BFG over Bridestone on that surface, that has proved all compounds of BFG to be completely inferior to Bridgestones for a CS car.
#4337 | |
Drives: 2015 FR-S
#4338 |
C-Street AutoX
I can't even believe people are still doing this, the tires are definitely faster with runs on them, as much as people don't want to believe it.
#4339 | |
Drives: Raven 6 speed Manual FRS
Until they aren't anymore. My 100+ run set is significantly slower than a friends ~40 run set.
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
#4340 | |
C-Street AutoX
Interesting. How much tread is left, and how many street miles?
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
