Old 07-25-2016, 03:18 PM   #4089
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
For $15 I'll take the peace of mind and ease of mounting wheels.
I can go on with stories of how car I've owned had vibrations on the highway without hub rings (or VERY careful tightening of lug nuts while holding the wheel centered) but I'd rather not waste my breath and attract the anti-hub ring people.
DocWalt is online now   Reply With Quote
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
CSG Mike (07-25-2016), Lynxis (07-25-2016), Yanbags (07-25-2016)
Old 07-25-2016, 03:56 PM   #4090
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Yanbags View Post
Hi guys,
Question about wheel hub rings on track. I've read and was told mixed things from seemingly credible sources about whether or not to use them. On track, I'm running 17x9 Enkei RPF1 wheels w/ RE71R tires.
From what I'm gathering for the BRZ on the forums - the wheels are centered by the lugs since they're conical, and after proper star-pattern torquing, there is no load on the studs/lugs. My alignment/race shop and a customer of theirs this weekend claimed metal (aluminum?) hub rings are very much recommended because they've seen broken studs when not used. I tend to trust them because they have several years of track experience and STI/BRZ specific setups but I'm a sitting duck on this one.
What gives?
Like above, I prefer the peace of mind of using aluminum hub rings. There is no real downside.
The Following 2 Users Say Thank You to kch For This Useful Post:
CSG Mike (07-25-2016), Yanbags (07-25-2016)
Old 07-25-2016, 04:04 PM   #4091
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Hi guys,
What gives?
FYI - I also run the RCE T2 400/400 with their out of the box recommended settings for damper clicks and I wouldn't say it understeers at all on track. It could very well likely be your alignment setup; what are your alignment specs?
I'm running -3/-2.1 f/r camber and zero toe all around. I don't think the understeer is pronounced but I felt it was there. I've since raised the rear a centimetre for clearance reasons plus removed extra weight from the rear (all the tools and the OEM Scion rubber mat on top of the spare tire) and it seems to have made the car pretty neutral.
infinity21 is offline   Reply With Quote
The Following 2 Users Say Thank You to infinity21 For This Useful Post:
CSG Mike (07-25-2016), Racecomp Engineering (07-25-2016)
Old 07-25-2016, 04:27 PM   #4092
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Hi guys,
What gives?
There was a discussion a few pages back about hub rings when I asked, the long and short of it is:
If you torque your wheels properly every time, you don't need a ring, the bore doesn't take a significant portion of the load and is used primarily as an alignment feature. The lugs and studs do all the work.
I've got a set of plastic rings that came with my RPF1's, I usually use them for autocross because they're free and relatively low hassle. Except they get stuck and I have to pry them off with a screwdriver, need to get to the hubs with some scotchbrite and clear up the gunk buildup...
You can search this thread for 'hubcentric' and come up with most of the posts on the topic, but I already did it so here's the links:
http://www.ft86club.com/forums/showt...ic#post1015715
http://www.ft86club.com/forums/showt...ic#post2557865
http://www.ft86club.com/forums/showt...ic#post2558002
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Old 07-25-2016, 04:41 PM   #4093
CSG Mike
CSG Mike's Avatar
Hi guys,
What gives?
Rings are not necessary, but it removes the stress from the stud from the first lug being tightened, if you're not evening tightening slowly, e.g. using an impact to put on the studs.
RCE T2 are designed to understeer. Making the T2 with stock spring rates neutral or oversteer can only be achieved by taking away grip from the front axle (which is slower; you're reducing grip).
@dp1 is local to you, and can demonstrate for you a truly neutral setup.
Old 07-25-2016, 04:42 PM   #4094
CSG Mike
CSG Mike's Avatar
Originally Posted by Takumi788 View Post
I am looking to change the pads in my almost track only car. (I drive to some car shows and to the track only.) I want to go with the Hawk DTC-60 pads. I hear rumors of blank rotors being 100% good to track with. Is this true? or is slotted the way to go? My car is NA with DOT slicks.
Blanks are used because they're cheapest. Drilled rotors tend to crack faster. Slotted can increase bite, but that's purely a preference thing.
I recommend you go with a pad with a non-corrosive brake dust.
Old 07-25-2016, 04:43 PM   #4095
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
Thanks for chiming in.
Thanks for this, didn't notice the posts on this thread when searching.
I see, I'm pretty much the same at -3/-2 but .06* toe out F, .06* toe in R. I watched your video, it's a little hard to tell. Do you find yourself maybe going into corners too hot and over-driving the front tires? Tire pressures okay? With my RE71R tires, I find the car totally neutral and it rotates very well with throttle.
Yanbags is offline   Reply With Quote
The Following User Says Thank You to Yanbags For This Useful Post:
Old 07-25-2016, 04:54 PM   #4096
kch
Senior Misanthrope
kch's Avatar
What can be done to make them more neutral without slowing down?
Old 07-25-2016, 06:22 PM   #4097
CSG Mike
CSG Mike's Avatar
Increase the rear net spring rate or decrease the front net spring rate.
kch (07-25-2016)
Old 07-25-2016, 06:37 PM   #4098
strat61caster
Typo?
ineedyourdiddly
Old 07-25-2016, 07:07 PM   #4099
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Typo?
Nah, OP likes to drive backwards.
Old 07-25-2016, 07:22 PM   #4100
CSG Mike
CSG Mike's Avatar
Typo?
Oops.
Taking away grip from the rear.
Old 07-25-2016, 10:46 PM   #4101
infinity21
infinity21's Avatar
I purposely make it understeer more because I think it's faster. I can make it oversteer if I step on the throttle too early but I find I can corner harder if I don't break traction.
Old 07-26-2016, 02:50 AM   #4102
CSG Mike
CSG Mike's Avatar
It's easier to extract a quick time out of an understeery car, but the fastest state of cornering is a mild state of oversteer, where both the front and rear tires simultaneously are at the limit of adhesion. Understeer means you still have untapped rear grip. Oversteer means you have untapped front grip.
infinity21 (07-26-2016)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
