Old 06-21-2012, 08:41 AM   #1
Laurie
Drives: Toyota86, MX5, Jeep, FJ45, 59 Caddy
Toyota sized Kenwood Navigation unit
Thought some of you guys might be interested in this...
I've always preferred the Kenwood navigation systems because they use the Garmin Navigation ECU's, which means the Garmin mapping works on them. Garmin is the only ones that are really keeping their Middle East mapping up to date - I'm in Dubai.
Turns out Kenwood has a couple models that are specifically Toyota sized - the one I got was the DDX630WM - combined with the navigation module KNA-G630.
Stock radio:
After installing:
With the Garmin navigation:
Very nice - very factory appearance - so nice to not need the Metra / Scosche style adapters on each side! Also came with a plug and play harness for the Toyota audio connector.
Only thing is the Toyota antenna is a different connector - need an adapter as I'm sure most of you have figured out already.
Will try and get some better pictures for you in daylight
Laurie
2013 Toyota 86 - 2008 Mazda MX5
2001 Jeep Wrangler - 1982 FJ-45 Land Cruiser Pick-Up
1959 Cadillac Sedan DeVille
Laurie is offline   Reply With Quote
The Following 13 Users Say Thank You to Laurie For This Useful Post:
baldolera (06-22-2012), Bonburner (08-20-2012), civicdrivr (06-21-2012), Dadhawk (06-22-2012), Efferalgan (12-26-2012), Fly Guy (06-21-2012), Jeff86 (01-19-2013), MaXimus (11-18-2012), Nardi330 (06-22-2012), normancw (06-27-2012), Scooby (07-14-2012), Slartibartfast (06-23-2012), sure74 (06-21-2012)
Old 06-21-2012, 09:20 AM   #2
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
The top is the stock head unit? I think that might be worse than the FR-S unit lol....I like the replacement you picked up though.
Pscylo is offline   Reply With Quote
Old 06-21-2012, 10:44 AM   #3
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
I was just looking at a pic with the metra kit installed saying, "Nope".
This is great, thanks!
So what is the actual name of this DIN size?
sure74 is offline   Reply With Quote
Old 06-21-2012, 03:41 PM   #4
SpecPer
SpecPer's Avatar
Drives: Many
which kenwood model is that?
SpecPer is offline   Reply With Quote
Old 06-21-2012, 04:57 PM   #5
Laurie
That's what we get in the Middle East! It's not a good unit at all! Sound quality is terrible and menus are a pain to navigate and it would not remember that I was using the USB previously and defaults to FM every time I re-start the car. Annoying to say the least!
Happy with the replacement
Old 06-21-2012, 04:58 PM   #6
GremlinGSP
looks good.
GremlinGSP is offline   Reply With Quote
Old 06-21-2012, 04:58 PM   #7
Laurie
Don't know what the official name is but I've always called it "Toyota Double Din"
The Following User Says Thank You to Laurie For This Useful Post:
sure74 (06-22-2012)
Old 06-21-2012, 05:01 PM   #8
Laurie
As mentioned in the original post - Kenwood DDX630W with Kenwood KNA-G630 Navigation ECU.
Kenwood has an absolute mess of part numbers though with slight changes for different regions - at least I know that the Navigation ECU in the USA is the KNA-G610, not G630.
There is also a radio called the DDX630 which is not the same - standard Double Din. I think the key is the "W" part for "wide" I'm guessing.
Anyway - tracked down a suitable Antenna adapter today so I'll be putting that in soon. The Antenna adapter has one blue wire on it - any idea what I'm supposed to do with that?
Old 06-21-2012, 05:24 PM   #9
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
Apparently our cars have amplified antennas so hook that blue wire up to the antenna or remote wire off the aftermarket unit.
Nitro is offline   Reply With Quote
The Following User Says Thank You to Nitro For This Useful Post:
Laurie (06-21-2012)
Old 06-21-2012, 06:29 PM   #10
Laurie
Easy - thanks
Old 06-21-2012, 07:10 PM   #11
burnt_rice
burnt_rice's Avatar
I just called my Kenwood rep and it's a no go on getting this in the states. I'd like to import one just to check it out though. Different am/fm tuner but I don't really care about that.
burnt_rice is offline   Reply With Quote
The Following User Says Thank You to burnt_rice For This Useful Post:
sure74 (06-22-2012)
Old 06-21-2012, 07:50 PM   #12
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
You sir are a sexy beast! This is exactly what I was looking for!
|-Goku-| is offline   Reply With Quote
Old 06-21-2012, 08:09 PM   #13
vividracing
vividracing's Avatar
Ask your rep what they have for nav units in a 1.5 DIN configuration. That's all this one is. Some people call it "Din and a half" or "one and a half din." I say "one point five din" personally.
vividracing is offline   Reply With Quote
Old 06-21-2012, 11:35 PM   #14
|-Goku-|
|-Goku-|'s Avatar
I'm curious..what are the sizes of each DIN. From what I found online
Single is about 2x7
1.5 is about 3x7
Double is about 4x7
So, If ours is 1.5, how does that work?
Again, I'm going on what the interwebs said, so it might now be accurate.
BRZ Navigation Audio Run Through F1point4 Electronics | Audio | NAV | Infotainment 84 10-14-2012 11:20 AM
2013 FR-S - 1st inventory unit for Scott Clark Toyota Scion sctcmediaman Scion FR-S / Toyota 86 GT86 General Forum 5 05-23-2012 07:57 PM
BRZ Navigation System Guaruja BRZ First-Gen (2012+) — General Topics 15 04-13-2012 08:52 AM
replace the Ford Navigation system? megancheung Electronics | Audio | NAV | Infotainment 1 03-22-2012 02:51 AM
New Here (Navigation Option Question?) Jokester Scion FR-S / Toyota 86 GT86 General Forum 36 02-19-2012 08:25 PM
