Old 07-16-2016, 04:47 PM   #15
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Originally Posted by cdrazic93 View Post
I would also reccomend making the side vents functional, as another route of ventilation.
yep working on that today!
canyons is offline   Reply With Quote
Old 07-16-2016, 05:59 PM   #16
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
One option many of us have found helps remove heat from the engine bay is to remove the rubber at the base of the windscreen.
It is designed to be able to come off and then reattach really easily and creates a nice gap for airflow without making the bonnet bounce or shake any more than it usually does. It works well and costs nothing. I remove it at the start of a track day and put it back on for the drive home afterwards - takes 20s.
Here's a pic where I've removed part of it so you can see what I mean
nzer is offline   Reply With Quote
Old 07-16-2016, 06:11 PM   #17
lazyluka
Drives: GT86
Not sure if you are actually data logging, but removing that rubber makes the problem worse, it may cool down faster when you are going slow/in the pits but on track you will effectively make your cooling system worse!
Essentially this is the same as a few washers under hood hinges addressed previously....
Originally Posted by DocWalt View Post
Sure, if you want to make the heat problem worse. There's a big high pressure bubble at the base of the windshield and as soon as you give that air somewhere to go like the engine bay you increase the pressure. That increase in pressure evens out the pressure differential across the radiator and there goes your cooling air flow.
lazyluka is offline   Reply With Quote
The Following 2 Users Say Thank You to lazyluka For This Useful Post:
DocWalt (07-16-2016), Tokay444 (07-17-2016)
Old 07-17-2016, 11:21 AM   #18
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
this has been debated before in the "Combating the heat" thread http://www.ft86club.com/forums/showthread.php?t=53580
I don't think it was ever solved, but I don't think it would be too much trouble to remove the seal, and tape some short lengths of yarn to the underside of the hood near the new gap and see if they get blown out at speed and tape some to the base of the window to see if they get sucked in.
As for the OP's original question, it was also addressed in that thread, page 31: http://www.ft86club.com/forums/showp...&postcount=427
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 07-17-2016, 08:39 PM   #19
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
What about @Reaper and cutting the windshield cowl?
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Undertray Bolts Part #'s and/or sizes smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-15-2017 08:55 PM
undertray missing behind bumper RacerX661 Cosmetic Modification (Interior/Exterior/Lighting) 4 04-06-2016 11:13 AM
Removed undertray, now rubbing above 60 mph? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 7 05-02-2015 07:30 PM
Undertray rattling Tainen Issues | Warranty | Recalls / TSB 2 09-29-2014 10:27 PM
Modifying orders? sieeegel BRZ First-Gen (2012+) — General Topics 7 03-04-2012 09:24 PM
