Old 07-14-2016, 10:11 AM   #15
D_Thissen
D_Thissen's Avatar
How many KM are on the tune?
Old 07-14-2016, 10:13 AM   #16
D_Thissen
D_Thissen's Avatar
Originally Posted by Roadcone View Post
that last log, commanded vs actual AFR... thats WAYYYY off.
commanded 12:1
actual 11.25:1
yet lt and st fuel trims are at 0... that makes ZERO sense.
At least he is on the richer side
Old 07-14-2016, 10:46 AM   #17
sIowbrz
Drives: 2015 brz
I HAD ABOUT 100KM ON THE TUNE
sIowbrz is offline   Reply With Quote
Old 07-14-2016, 10:51 AM   #18
sIowbrz
Drives: 2015 brz
i dont plan to get it tune until i get the header but ill be taking it to the track want to make sure that im not damaging anything haha
Old 07-14-2016, 11:31 AM   #19
D_Thissen
D_Thissen's Avatar
1000km is more than enough for the car to 'learn' the new tune. I haven't had a chance to look through your logs, but if your IAM is <1.0 on the street, it more than likely will drop further on the track as your Oil/Coolant Temps rise. You could always give PC94 a shot. I had good luck using that when I was on the Stg.1 93 tune.
Old 07-14-2016, 11:46 AM   #20
Kodename47
Kodename47's Avatar
Drives: UK GT86
commanded 12:1
actual 11.25:1
How does that make no sense?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-14-2016, 01:18 PM   #21
sIowbrz
Drives: 2015 brz
sorry its 100 km not 1000 km lol
Old 07-14-2016, 04:18 PM   #22
bababooey
Drives: BRZ SWP Limited -6MT
commanded 12:1
actual 11.25:1
apologies if I created confusion concerning who's log that reply was towards. this thread seems to be a little more lower level conversation than the sticky I originally posted that in.
still trying to learn which values are critical for a healthy engine. if the KM question was to me, i had to of put much more than 200 miles on since this reflash. prior to that was another 93 tune that was too agressive so the relearn of ecu from switching fuels isnt a possibility.
bababooey is offline   Reply With Quote
Old 07-14-2016, 07:05 PM   #23
steve99
Drives: FT86
couloured link below on ECU logging might help
Old 07-14-2016, 07:09 PM   #24
steve99
Drives: FT86
commanded 12:1
actual 11.25:1
If ltft is low then that usually means the closed loop portion of maf scale is good ie kind of the lower rpm and light throttle portion, section below 3v maf.
if the commanded and actual afr follow each other well in wide open throttle areas means open loop area of maf scale is good ie sextion over 3v maf
in this case it appears the closed loop is ok but the open loop section of maf scale is not correct hence his ltft is low but car runs rich during wide open throttle runs
11.2 is the rich limit of standard 02 sensor scaling so it might be even richer.
fix would be to reduce the values in the open loop area af maf scale be the percent difference in the afr and commanded afr in this case about 8%. Their is a nice maf scaling tool that will do the work for you.
Old 07-14-2016, 07:52 PM   #25
sIowbrz
Drives: 2015 brz
I have no idea how to do it would you able to help a noobie out? Haha
How to datalog azynneo Software Tuning 0 07-06-2016 05:01 PM
Open flash knocking datalog Yamadawg770 Software Tuning 7 04-02-2015 04:22 PM
OFT datalog with Perrin intake acj47 Software Tuning 25 01-19-2015 09:58 PM
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
Will someone please send me a datalog? ATSAaron Forced Induction 48 09-10-2013 10:29 PM
