Old 07-11-2016, 07:07 PM   #1
sIowbrz
Drives: 2015 brz
Smile Can someone take a look of my datalog
Can someome please take a look at my datalog i want to make sure its running safe and nothing damage the engine thank you and appreciate!http://www.datazap.me/u/carewyip/log...29?log=0&data=
sIowbrz is offline   Reply With Quote
Old 07-11-2016, 08:18 PM   #2
Nah
Drives: 2013 Scion Frs 6mt
youve got a little bit of knock your IAM dropped when you floored it outta nowhere. Log RPM next time. I'd say decrease your timing there a degree or two nothing major. good logs fuel trims look decent.
Nah is offline   Reply With Quote
Old 07-11-2016, 08:55 PM   #3
randomthoughts
Drives: 2014 White BRZ
What fuel are you using? Did u end up using ultra 94?
Your IAM dropped to .88 then back to .9. If I'm not mistaken it should stay at 1. Flkc hit 2.9.
Some one more knowledge might crime in but if you are running 91 you might want to consider 93 or ultra 94
randomthoughts is offline   Reply With Quote
Old 07-11-2016, 09:30 PM   #4
sIowbrz
Drives: 2015 brz
Im running 93 esso i dont run 91 unless theres no 93 or 94 available
Old 07-11-2016, 10:23 PM   #5
phrosty
Yea, you've got some knock up high. Your engine is probably safe but you're losing power. I'd try different gas (Shell, etc.) -- go to a place that gets lots of customers so their gas is fresh. If it doesn't go away with different gas, you can tune it out.
Log RPM next time. Remove KC Learned if you're out of logging parameters.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-11-2016, 11:46 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That's correct IAM should for the most part always be at 1 unless theres bad quality fuels
Old 07-12-2016, 06:50 PM   #7
sIowbrz
Drives: 2015 brz
this is another log i did today can someone take a look and let me know? im using stage1 91oct tune with 93oct gas thanks!
http://www.datazap.me/u/carewyip/log...1-12-14&solo=2
Old 07-12-2016, 06:53 PM   #8
sIowbrz
Drives: 2015 brz
my IAM dropped to 0.36 for a second twice what can cause that??
Old 07-13-2016, 12:18 AM   #9
phrosty
answers will be no different for the new logs.
Old 07-13-2016, 03:02 AM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
Faulty readings....
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-13-2016, 06:40 PM   #11
sIowbrz
Drives: 2015 brz
this one looks better now?
http://www.datazap.me/u/carewyip/log...data=1-8-11-12
Old 07-14-2016, 03:32 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
Datalog....
Could do with taking out some timing over 5k or maybe make it a little richer.....
Here's a good view
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-14-2016, 09:29 AM   #13
bababooey
Drives: BRZ SWP Limited -6MT
is taking out timing recommended due to the 3.5 flkc reading? (from log above)
i ask because i am still trying learn what the readings mean in relation to my tune (latest link below)
http://www.datazap.me/u/n8brz/log-14...=0&data=1-5-13
also @ the 11.3 afr reading, is running too rich or too lean? thanks
Old 07-14-2016, 09:39 AM   #14
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
that last log, commanded vs actual AFR... thats WAYYYY off.
commanded 12:1
actual 11.25:1
yet lt and st fuel trims are at 0... that makes ZERO sense.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
How to datalog azynneo Software Tuning 0 07-06-2016 05:01 PM
Open flash knocking datalog Yamadawg770 Software Tuning 7 04-02-2015 04:22 PM
OFT datalog with Perrin intake acj47 Software Tuning 25 01-19-2015 09:58 PM
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
Will someone please send me a datalog? ATSAaron Forced Induction 48 09-10-2013 10:29 PM
