Old 07-13-2016, 12:16 PM   #43
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by Psy-q View Post
The DENSO unit will most likely be 100% backwards compatible with older models. Because the 2017 will have 2 engines - Red Top/ Black Top.
I am sure they would use 1 fuel pump for both, so we can use the new 2017 pump on our older engines.
I hope you are correct...
However your premise does not support the conclusion. They have demonstrated that they are perfectly willing to run two different engines with minor variations when inventory cost would doubtless be cheaper for a single variant.
Perhaps the most interesting counter argument is, if you read the change document closely, that they claim to have actually altered the camshaft to reduce the throw of the fuel pump eccentric...
There are LOTS of little changes between the "red top" and "black top" engines... will the new pump be totally interchangeable? Will the difference in throw be within tolerance? Will the new pump with the old cam have acceptable flow and pressure? WIll the pump still chirp with the old camshaft eccentric? I have no idea...
"Hope springs eternal" - Bill S.
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
Stang70Fastback (07-13-2016)
Old 07-13-2016, 01:50 PM   #44
BRZErskine
Drives: 2016 WRB BRZ Limited
Manufactured 3/16, a little over 200 miles on the car. Flowery surface on top of fuel pump. I can already hear the crickets...
BRZErskine is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZErskine For This Useful Post:
funwheeldrive (07-27-2016), Stang70Fastback (07-13-2016)
Old 07-13-2016, 02:33 PM   #45
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Interesting notes based on the parts catalog for 2017:
The service part number (at least for early production 2017's) for the fuel pump hasn't changed, so the old fuel pump should work just fine with the new camshafts and vice versa.
Both engines got the camshaft updates, not just the redtop.
Both engines use the same fuel pump, so they should be interchangeable without issue.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Old 07-13-2016, 03:48 PM   #46
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
'16 manufactured 9/15. Have a little over 7000 miles. Old style fuel pump. I've never had crickets. However I've never put ethanol in my car. Every fill up is from an unbranded ethanol free gas station down the road. 93 octane ethanol free...
sly is offline   Reply With Quote
Old 07-18-2016, 10:06 AM   #47
BRZErskine
Interesting...I'm in Northern Colorado and I have yet to find a station that has less than 10% Ethanol in all fuel. Maybe I should search a little harder, but it seems 93 Octane isn't readily available here either. However, E-85 is local...Just filled up for the first time over the weekend with 91 Octane (10% ethanol), crickets still there. A little over 400 miles on the car now. I'll be searching for a higher octane / lower ethanol % station before the next fill up to see if this makes a difference.
Sent from my SM-G935V using Tapatalk
Old 07-18-2016, 12:10 PM   #48
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Shit my crickets are back when I turned on the A/C on a very hot and humid day last week and I haven't had crickets for over a year with my 08/2013 built 2014MY. Car has had ethanol free Shell V-Power 91 all its life.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
BRZErskine (07-18-2016)
Old 07-23-2016, 11:11 AM   #49
Ballu01
Drives: Subaru BRZ 2016
Originally Posted by Da Brz View Post
Around what mileage did y'all's pumps start chirping? My 16 has the old fuel pump but it doesn't chirp. Got around 6k miles on it so far. Built in March 2016.
Mine started chirping the first day I got it lol
Back in January 2016.
Ballu01 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ballu01 For This Useful Post:
BRZErskine (07-23-2016), funwheeldrive (07-27-2016)
Old 07-23-2016, 08:28 PM   #50
sly
sly's Avatar
Maybe you can find a station here: http://www.pure-gas.org/index.jsp?stateprov=CO
The Following User Says Thank You to sly For This Useful Post:
Old 07-23-2016, 08:53 PM   #51
BRZErskine
Thank you for this. There are actually 3 very close to me in Fort Collins. I filled up last night at at a 10% station, but I will try one of these next time.
Old 07-23-2016, 09:04 PM   #52
DirtDrift
DirtDrift's Avatar
Drives: 2016 FR-S
Not "all" Shell V-Power 91 is ethanol free. It's dependent on the seller.
DirtDrift is offline   Reply With Quote
Old 07-24-2016, 01:02 AM   #53
krayzie
Drive From Home
krayzie's Avatar
In the Greater Toronto Area if not all of Southern Ontario, "all" Shell V-Power 91 and Petro Canada SuperClean 91 are ethanol free. All other gasoline have 5 to 10% ethanol content depending on the brand and grade. It's all clearly labelled on the gas pump.
I know in the States it's exactly what you mean as I've driven thru Upstate New York and New Jersey.
Old 07-24-2016, 08:53 AM   #54
gravitylover
I've never seen a Shell that isn't 10% ethanol. I would try it if I happened upon one but I've pretty much given up on getting rid of the crickets by using ethanol free. I'm tired of paying extra for off brand 91 octane just to get ethanol free since it only works sporadically.
Old 07-24-2016, 11:23 AM   #55
sly
sly's Avatar
Forgot to mention that this is a user edited database so sometimes it's not exactly accurate. I try to keep it accurate for my area by adding and removing gas stations as I see them.
BRZErskine (07-27-2016)
Old 07-27-2016, 10:04 AM   #56
Jonnyfkncoolguy
Drives: 2016 BRZ Limited
Manufactured 4/16 new style pump, little over 1000 miles and no crickets yet...here's to hoping they don't start haha
Jonnyfkncoolguy is offline   Reply With Quote
The Following User Says Thank You to Jonnyfkncoolguy For This Useful Post:
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
True Fix to Crickets and Pump CharlieChaos Issues | Warranty | Recalls / TSB 48 08-17-2013 01:17 AM
Crickets Gone Or Returned After Pump Replacement? FR-S Matt Issues | Warranty | Recalls / TSB 38 02-25-2013 03:16 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
