Old 07-09-2016, 12:27 AM   #15
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
I was hoping to avoid bugging Darren, but I did get in touch with him to beg for his help!
Sent from my SM-G935V using Tapatalk
FNCrazy is offline   Reply With Quote
Old 07-09-2016, 07:46 PM   #16
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
I was given a quote from my toyota dealer for $400 for labor and $245 for the TRD springs.
Spacemane969 is offline   Reply With Quote
Old 07-09-2016, 08:20 PM   #17
FNCrazy
Rambling Man
FNCrazy's Avatar
The one time I don't call the dealer!
Of course, they probably wouldn't install rce springs
Old 07-09-2016, 09:26 PM   #18
Slammedsteve
Drives: 2013 Asphalt Fr-s,91 240sx missle
Depending how much you trust your friend, I would say let him install them. They are really easy to install
Also you can rent a spring compressor from auto zone for free. Just need a air wrench to use it.
Slammedsteve is offline   Reply With Quote
The Following User Says Thank You to Slammedsteve For This Useful Post:
FNCrazy (07-09-2016)
Old 07-09-2016, 09:36 PM   #19
gramicci101
Off Topic
You don't need a spring compressor on these cars. They're under so little static load that you can undo the top nut while the car is on the ground and the spring will unload as you jack the car up. The only tools you need are a jack, torque wrench, pass-through socket set and allen wrench set. If you were close to me I would do it for a pizza.
DIY thread for compressor-less install.
http://www.ft86club.com/forums/showthread.php?t=32414
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
FNCrazy (07-09-2016), humfrz (07-09-2016), Romanov (07-12-2016)
Old 07-12-2016, 12:49 AM   #20
Spacemane969
a really thorough video on it also.
Old 07-12-2016, 11:10 AM   #21
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
DIY,
You don't need spring compressors at all, i didn't use any and i didn't die and no spring explosions.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
Old 07-12-2016, 03:30 PM   #22
CatDaddysBBQ
Drives: '13 FR-S
It's not hard if you have the tools and a friend, but it's just one of those jobs that can SOMETIMES take a long time. Suspension bits get rusty and dirty, and you can run into a bolt here or there that just soaks up a lot more time than a DIY may make you expect.
That said, it's a pretty easy car to do it on. If you or your friend have ever done it before, there's a good chance this car is easier to swap springs on.
CatDaddysBBQ is offline   Reply With Quote
Old 07-12-2016, 03:32 PM   #23
FX86
Originally Posted by BrunoS72 View Post
My experience:
-Toyota Dealer quoted $520 plus alignment (TRD springs). Service Advisor didn't recommend, FR-S is already low.
a stealership turned down money?
NO WAY!
Lowering spring FAQ- stock FR-S gconron_86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-22-2015 04:35 PM
TireDiscounter Qoute for Lowering Spring Install raven1231 Scion FR-S / Toyota 86 GT86 General Forum 19 04-10-2015 10:00 AM
RS-R SUS lowering spring reviews? jvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-24-2014 01:44 PM
WTB Lowering Spring FRS_Jack Want-To-Buy Requests 0 02-27-2014 01:48 AM
North FL: Lowering Spring install BlueDubbinTDI Southeast 1 01-01-2014 08:12 PM
