Old 07-04-2016, 05:03 PM   #1
budul05
Drives: BRZ Limited
Question Best fuse to tap in?
I want to hardwire a radar detector, but i need to find a fuse that would be powered only when ignition is on and would be safe to do so. Any tips ?
16 BRZ Limited
budul05 is offline   Reply With Quote
Old 07-04-2016, 05:31 PM   #2
ryoma
ryoma's Avatar
accessory fuse. you have two cigarette adapter ports so find one that you don't use (like the one in the glovebox) and figure out which fuse it is (there are 2) and tap into that. picking any accessory fuse is probably fine since the radar detector won't draw too many amps but it doesn't hurt to be safe just in case you want to charge an ipad on the same port or something that uses a lot of power.
or you can just plug into the cigarette port into the glovebox and hide the wiring. that's what I did for my dashcam and it's easily reversible. tapping a fuse isn't that reversible unless you do an add-a-fuse. some people also tap right behind their auto dimming mirror too.
Old 07-12-2016, 03:14 AM   #3
greencounty
greencounty's Avatar
I used one of these for a dash cam...might be worth it:
http://www.autoharnesshouse.com/76297.html
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
hardwire, radar, radar detector
Hot fuse tap - Which fuse? cgrey Electronics | Audio | NAV | Infotainment 9 09-17-2016 08:24 PM
Fuse box. Chen Northwest 4 01-19-2015 04:51 PM
Best fuse to tap that is hot with car off? Frs32907 Electronics | Audio | NAV | Infotainment 0 08-30-2014 11:11 AM
Where to FUSE Tap for fog lights? IgnitionGundam Electronics | Audio | NAV | Infotainment 1 04-24-2014 11:19 PM
Fuse Box beagoodruslan Electronics | Audio | NAV | Infotainment 0 04-20-2014 12:31 AM
