#15 |
Rambling Man
Drives: 2013 FR-S 6MT - In Heaven Now
I was hoping to avoid bugging Darren, but I did get in touch with him to beg for his help!
Sent from my SM-G935V using Tapatalk |
#16 |
Drives: 2013 ARGENTO A/T
I was given a quote from my toyota dealer for $400 for labor and $245 for the TRD springs.
#17 |
Rambling Man
#18 |
Drives: 2013 Asphalt Fr-s,91 240sx missle
Depending how much you trust your friend, I would say let him install them. They are really easy to install
Also you can rent a spring compressor from auto zone for free. Just need a air wrench to use it. |
| The Following User Says Thank You to Slammedsteve For This Useful Post: | FNCrazy (07-09-2016) |
#19 |
Off Topic
You don't need a spring compressor on these cars. They're under so little static load that you can undo the top nut while the car is on the ground and the spring will unload as you jack the car up. The only tools you need are a jack, torque wrench, pass-through socket set and allen wrench set. If you were close to me I would do it for a pizza.
DIY thread for compressor-less install. http://www.ft86club.com/forums/showthread.php?t=32414 |
#20 | |
a really thorough video on it also.
#21 |
Just another BRZ owner
Drives: 2014 Subaru BRZ Limited MT
DIY,
You don't need spring compressors at all, i didn't use any and i didn't die and no spring explosions.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz |
#22 |
Drives: '13 FR-S
It's not hard if you have the tools and a friend, but it's just one of those jobs that can SOMETIMES take a long time. Suspension bits get rusty and dirty, and you can run into a bolt here or there that just soaks up a lot more time than a DIY may make you expect.
That said, it's a pretty easy car to do it on. If you or your friend have ever done it before, there's a good chance this car is easier to swap springs on. |
#23 |
| Lowering spring FAQ- stock FR-S | gconron_86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-22-2015 03:35 PM |
| TireDiscounter Qoute for Lowering Spring Install | raven1231 | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-10-2015 09:00 AM |
| RS-R SUS lowering spring reviews? | jvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-24-2014 12:44 PM |
| WTB Lowering Spring | FRS_Jack | Want-To-Buy Requests | 0 | 02-27-2014 12:48 AM |
| North FL: Lowering Spring install | BlueDubbinTDI | Southeast | 1 | 01-01-2014 07:12 PM |
