Old 06-17-2016, 11:25 PM   #1
anchovy619
anchovy619's Avatar
Drives: Into Crowds
Securing subwoofer box in trunk
So how did you guys go about it? I'm using a bungee cord to hold mines in place, but it's a kicker box so it's shaped a little funky.
anchovy619 is offline   Reply With Quote
Old 06-17-2016, 11:53 PM   #2
Chimera
Drives: FRS
My first was high strength velcro... It was fine tbh, 2nd is bolted in place
Old 06-17-2016, 11:58 PM   #3
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
The Twins make me smile
Old 06-18-2016, 01:39 AM   #4
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
Bolting it down to metal is the only safe way. In an accident, a subwoofer box WILL break down the rear seat in the right kind of accident.
Just a year or so ago there was a guy that died in a car wreck because his box broke though his rear seat and crushed his head.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 06-20-2016, 09:06 AM   #5
RickyBobby
Drives: 2013 Firestorm FR-S AT
@soulreapersteve
From your pic it looks like you have your subwoofer bolted/screwed down to the fiberboard trunk mat.
Since the trunk mat is not secured does the subwoofer move when you hit a bump?
Velcroing the trunk mat down to one or all of the 3 secured styrofoam blocks under it would keep the trunk mat from moving.
I agree but the only metal in the trunk to secure it to would be the side wells, which I do not want to drill into.
RickyBobby is offline   Reply With Quote
Old 06-20-2016, 11:16 AM   #6
Chimera
Drives: FRS
For the sake of conversation, Im pretty sure mine did not, however mine was only about 1" shorter than the roof of the trunk space, so if it did, there wasn't very far for it to go..
Originally Posted by RickyBobby View Post
@soulreapersteve
Old 06-20-2016, 02:20 PM   #7
gramicci101
Off Topic
I have a small box (Pioneer UD-SW200D) that came with right angle brackets to secure it to the floor. I set them against the back of the back seat and used industrial Velcro to secure them.
Old 06-20-2016, 02:39 PM   #8
soulreapersteve
@soulreapersteve
Not very much, if at all. Its pushed back against the rear seat just a little so that helps. I can only see it moving if I'm in a rollover incident and landed upside down...
There are more ways of securing it but this works for me.
Old 06-23-2016, 11:28 PM   #9
Jrider
Jrider's Avatar
Drives: 2013 Silver BRZ
Wink
I have a 10" single sub. I tried it in the trunk but it slid around, rather than bolting or bracing it down I decided to put the passenger rear seat to use. Works perfectly like a speaker box cradle. Keep the amp secure in the trunk with velcro and pass the wires right by the rear seat.
Jrider is offline   Reply With Quote
Old 06-24-2016, 01:34 PM   #10
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
Just a word to the wise, that speaker and box probably weigh over 20lbs. In an accident that 20+ pounds will go wherever it wants to inside the passenger area of your car.
You should really look into bolting the box down somehow. Especially since the speaker is in the passenger area.
iamjacob is offline   Reply With Quote
Old 06-24-2016, 02:03 PM   #11
jwvand02
Drives: 2013 SWP BRZ Limited
I ended up using a bungee cord as well, because my box is a weird shape. One day I'd like to re-make it in fiberglass so I can indeed fix it to the floor of the car.
jwvand02 is offline   Reply With Quote
Old 07-09-2016, 09:59 AM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
my integrity concepts box didn't..
just sayin'
Old 07-09-2016, 06:10 PM   #13
TOOSTUBBORN2FAIL
You got lucky. Just sayin.
Old 09-28-2016, 12:25 PM   #14
nickson555
Drives: 2015 Subaru BRZ Limited
I'm holding mine with a bunch of velcro as well but . I think mine don't fit through the back seat hole if folded. I have a 12". The problem is the thin card board in the trunk that moves now.
nickson555 is offline   Reply With Quote
Trunk Space / Subwoofer Box ckcrown84 Electronics | Audio | NAV | Infotainment 29 08-14-2017 01:26 PM
Securing subwoofers UNCC_BRZ Electronics | Audio | NAV | Infotainment 8 03-03-2016 01:58 PM
Stealth Trunk Subwoofer Enclosures? STS-V Electronics | Audio | NAV | Infotainment 10 06-25-2014 04:54 PM
Anybody running OEM Kicker trunk subwoofer ? Simon99 Electronics | Audio | NAV | Infotainment 16 04-24-2014 08:02 PM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 02:12 PM
