Old 06-28-2016, 06:54 PM   #1
cf6mech
Drives: FRS Silver LS1 swapped.
Hydromat
Ok......i want to get rid of my two pump set up for fuel starvation in my Frs and go with a single pump and the Holley hydramat.......I understand Macken Industries FRS is running a hydramat.....anyone know the size they are running?......called Holley twice and i get put on hold it seems for EONS.
cf6mech is offline   Reply With Quote
Old 06-28-2016, 07:28 PM   #2
CSG Mike
CSG Mike's Avatar
Iirc they covered the entire floor of the tank
Old 06-28-2016, 09:12 PM   #3
cf6mech
Any idea of that size.......would like to have it on hand before i drop the tank......looked all ovef the net on a build or reference about their car.....no mention of the size
Old 06-28-2016, 09:28 PM   #4
CSG Mike
CSG Mike's Avatar
Most big builds will not be disclosing any of the details of their builds, beyond the very basics... R&D isn't free.
Now, something tells me that their fuel system is not as simple as just a hydramat
funwheeldrive (10-25-2016)
Old 06-29-2016, 12:04 AM   #5
cf6mech
Your probable correct.....was thinking the same thing.....only part of their solution......im running to power my LS two pumps one on each side of the saddle as well as a return system with regulator as i was having starve/lean issue on hard left turns below half a tank......got it resolved but would like to simplify it with a hydramat and one pump......i would know instantly i had a pump failure this way car would quit......where as with the dual pump it would continue to run but very lean.
Old 06-29-2016, 01:04 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If it works...
Wouldn't a fuel pressure gauge or an AFR gauge let you know if there's a problem? What are you running for engine management and data tracking? No failsafe? If you don't have something that can handle issues like this, maybe it's time to upgrade? It might be less painful then redoing your fueling system, and it will open up new vistas of awesomeness to your tuning.
Old 06-29-2016, 01:32 PM   #7
cf6mech
I have a N/A stock LS swaped FRS dynoed at 350whp, I have oil pressure/oil temperature/coolant temp gauges.....was seriously considering adding fuel pressure as well......my idea as both pumps alone can supply the needed 60 psi pressure was to eliminate one for simplistic reasons and run a full length hydramat .
Old 06-29-2016, 01:42 PM   #8
jvincent
jvincent's Avatar
Thread jack.
I love how the crappy Toyota digital clock is poking its head into your bad-ass gauge picture.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
cf6mech (06-29-2016), FRSBRZGT86FAN (07-28-2016)
Old 07-07-2016, 02:11 PM   #9
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
I tried Hydromat in my FR-S race car and it was a disaster. The issue is that there is literally no space for it below the stock fuel pump assembly. So, we modified the assembly. It did not work at all for this application. It actually made the situation worse.
I bit the bullet and installed a Fuel Surge Tank. On top of that, we removed the crossover pickup side and installed a second stock fuel pump assembly. We plumbed them together and now have a dual feed and dual return to/from the FST. No more fuel starve issues.
bem75 is offline   Reply With Quote
The Following User Says Thank You to bem75 For This Useful Post:
cf6mech (07-28-2016)
Old 07-07-2016, 02:49 PM   #10
CSG Mike
CSG Mike's Avatar
Since the cat's out of the bag, the Mackin FRS uses a fuel cell with two hydramats, and then a surge tank in addition to that.
Old 07-07-2016, 02:49 PM   #11
CSG Mike
CSG Mike's Avatar
Radium is actually making a drop-in solution for that!
Jonsey (07-07-2016)
Old 07-07-2016, 04:44 PM   #12
bem75
Round 3 Racing
bem75's Avatar
Like as in drop-in the fuel tank? If so, that is exactly what I was hoping that someone would develop. Great news!
I use a Radium FST with integrated FPR that I took from my other race car. I'd love to put the FST back in the other car and get the in-tank solution. I just checked the Radium website and don't see it yet. Any idea when it will be released?
Old 07-07-2016, 05:40 PM   #13
CSG Mike
CSG Mike's Avatar
"it's ready when it's ready", as with all Radium products.
I probably shouldn't have even mentioned it... but It'll be on the CSG website the day it's available to the public!
Old 07-28-2016, 08:24 PM   #14
cf6mech
That pretty much is the same set up as i have minus the surge tank.....and it eliminated the fuel starve......was trying to eliminate complexity which equals more things that can break by using a hydra and one pump......thanks for the reply......guess im wiring in a fuel pressure gauge for the dash.
