Old 06-18-2016, 03:51 PM   #4033
marusteri
Drives: 2013 BRZ Limited AT
Originally Posted by jjaisli View Post
1. Do those of you who do track events with ambient temperatures > 90* frequently pull a cel 0351?
about 50 track days, I never stop due to heat (just drink water and sweat it out), never got a 0351. 2 weeks ago I did Butonwillow 13CW both Sat and Sun, 107 deg on Sat and 104 on Sun. I didn't skip a single lap.
But the drivetrain is 100% stock, transmission is auto (which probably saves the engine due to the higher gear ratios - it also slows me down )
Speed not that much, last session of the day with only about 5 cars left on the track the best lap I could do was 2:15.75. But I was with OEM suspension (Tein SRC CSG spec to be installed) and OEM tires with about 75 heat cycles on them.
Florin
marusteri is offline   Reply With Quote
Old 06-18-2016, 03:55 PM   #4034
ZionsWrath
Thanks
ZionsWrath's Avatar
haha I just put back my OEM wheels with OEM tires, so they are like 4 years old, maybe ~dozen track days on them. They have been standing in as my coffee table for the past 2 years.
My goodness they are like ice skates. I think I will just run them for the rest of this season and get some Continental DW next season so I can double them as my "rain tire". But I do enjoy the better road manners vs the staggered 18s I just took off.
Old 06-18-2016, 04:04 PM   #4035
dp1
driving smoother faster
Drives: Sold
Got a track related question? I'll try to answer.
Originally Posted by Superstar View Post
Anyone have experience with running an aftermarket front grill (such as grillcraft) with an oil cooler? Could you share some temp data (with and w/out grill) if possible?
Just learned this today at the track. Swapped to grillcraft to protect intercooler rad etc in the front from rocks. Pitted when oil got up to 265F with Grillcraft + JR OC + Hood louvers...took grillcraft off and left the hole...next session oil came up to 244F after running high rpm for a while to see how high it would go, couldn't get it higher. 80F ambient both sessions. Not worth risking engine on track with this product, doesn't allow enough air to enter engine bay at speed.
dp1 is offline   Reply With Quote
Old 06-18-2016, 04:14 PM   #4036
marusteri
I don't know the official values, but "hand tight". It's not a load-beading member. Err on the side of caution, and mark where your bolts are locked, so if they slide, you can quickly adjust it back to where it was, and torque slightly higher. Or, lock them im place (use the outermost holes) with a "ballpark" camber, and fine tune using an eccentric bolt on the bottom.
Thanks Mike,
Locking the front camber in place at the top plate wouldn't work very well because my plan is to keep increasing the front camber in the morning before getting on the track and reverting to street values when I leave the track. I am hoping this plan would work because I don't see better options for a dd which also gets plenty of track. This is why I wanted to know as much as I can about the right torque for those bolts, 'cos they will be used a lot. Of course I will lift the front when adjusting camber to reduce the stress as much as I can.
Florin
Old 06-18-2016, 11:00 PM   #4037
CSG Mike
CSG Mike's Avatar
Originally Posted by marusteri View Post
Thanks Mike,
Florin
Keep in mind, that changing camber via the plates also minorly affects toe...
CSG Mike is online now   Reply With Quote
Old 06-19-2016, 12:35 PM   #4038
Pat
Pat's Avatar
Drives: 2023 BRZ
Good point. Toe is affected about 10% as much as camber changes.
Old 06-22-2016, 01:30 AM   #4039
marusteri
Florin
Forgot to mention I did get a CEL: about 1yr ago at Buttonwillow (not very hot weather) in the pits just after fueling I got P000C: Camshaft Position "A" - Timing Slow Response Bank 2
The manual describes it as:
"Integrated deviations in target intake valve timing and actual intake valve timing per specified time exceed thresholds for 15 seconds (bank 2). (2 trip detection logic)"
and specifies the fail-safe operation for it as:
"Fix intake VVT control at intermediate position"
I didn't risk staying on the track with it, I drove home tail between legs. The dealer fixed it under warranty and wrote:
"found code P000C in memory, off at this time, AVCS slow pressure. Per service bulletin 02-132-12R, followed procedures, found AVS sensor questionable readings, replaced, cleared code, test drove and rechecked, no light present at this time"
Florin
Old 06-28-2016, 03:38 PM   #4040
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
After that discussion about ignition coil failures... Guess who got to swap a coil at the track? I didn't even miss a session, though I got some burns and scrapes doing the swap on a hot car.
Time to buy another spare.
Old 07-03-2016, 11:00 PM   #4041
redlined600
redlined600's Avatar
Drives: Fr-s
When replacing my seats if the airbag light is on does this trigger the trac/abs light too(meaning defeating them). I can put the resistors in I'm just not sure if I need to focus on this before the next track day. I won't be driving it on the street like this.
redlined600 is offline   Reply With Quote
Old 07-04-2016, 02:57 AM   #4042
CSG Mike
CSG Mike's Avatar
No, but it does disable the airbags.
Old 07-06-2016, 10:39 AM   #4043
ShadowTS
Drives: Toyota GT86 SWP
When changing brake pads (from the stock ones) to new ones (Ferodo DS2500, plus oil and brake lines), how many km should I drive before tracking? Could I go directly to the track?
ShadowTS is offline   Reply With Quote
Old 07-06-2016, 11:18 AM   #4044
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Go directly to the track. Just bed the pads.
http://www.ferodoracing.com/products...g/pad-bedding/
You can also bed the pads on the street.
Old 07-06-2016, 01:19 PM   #4045
Panamaniac
Quick question!
What Transmission Oil do you guys recommend for a track only car?
We are on Mobil 1 75w90, but had problems with getting 4th in. We were thinking Motul Gear 300, but want a better opinion on people who have tracked the car more than us.
Panamaniac is offline   Reply With Quote
Old 07-06-2016, 01:33 PM   #4046
CSG Mike
CSG Mike's Avatar
Originally Posted by Panamaniac View Post
Quick question!
Try the Motul Gear 300. But, if there is damage that is already done, then the Motul can't magically undo the damage.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
