Old 07-04-2016, 03:09 PM   #225
Lonewolf
Lonewolf's Avatar
Drives: Moped
Subaru spends all this development time and money improving the FA20 and the gearing and then restricts the improvements to the manual model only? The quick model gets quicker, the slow one stays slow (maybe even gets slower due to added weight), how is that improvement over time?
How about charge an extra 500-750 bucks for the auto guys for the good FA20 so they actually have useable power and torque throughout the rpm band as well...
I like how they finally fixed the taillight sealing issue...lol
Old 07-05-2016, 01:54 AM   #226
Resolute
in the recliner of rage
Drives: Asphalt FR-S
Actual pic of the new engine bay with red aluminum intake manifold, courtesy of Motor Authority:
Link to Motor Authority's first drive of the new BRZ:
http://www.motorauthority.com/news/1...t-drive-review
Resolute is offline   Reply With Quote
The Following 11 Users Say Thank You to Resolute For This Useful Post:
DatsunDimer (07-05-2016), drew_kar (07-05-2016), funwheeldrive (07-05-2016), irax (07-05-2016), krayzie (07-05-2016), Mr.Impreza (07-05-2016), nikitopo (07-05-2016), NissanGuy (07-05-2016), Oxyg3n (07-05-2016), Sport-Tech (07-05-2016), URACK (07-05-2016)
Old 07-05-2016, 02:42 AM   #227
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Just a quick google search brought this up. Didn't read it yet but thought I'd post it.
http://www.motor1.com/reviews/64734/...17-subaru-brz/
Oxyg3n is offline   Reply With Quote
The Following 4 Users Say Thank You to Oxyg3n For This Useful Post:
Guff (07-05-2016), irax (07-05-2016), Mr.Impreza (07-05-2016), URACK (07-05-2016)
Old 07-05-2016, 03:02 AM   #228
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Good find! I'll make a thread for this!
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
irax (07-05-2016)
Old 07-05-2016, 05:40 AM   #229
Oxyg3n
Oxyg3n's Avatar
Motortrend's jab at it.
http://www.motortrend.com/news/2017-...-drive-review/
Sent from my SAMSUNG-SM-G920A using Tapatalk
The Following 3 Users Say Thank You to Oxyg3n For This Useful Post:
goldenfri (07-05-2016), Sport-Tech (07-05-2016), URACK (07-05-2016)
Old 07-05-2016, 06:30 AM   #230
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Great read (as are the other two posted).
As I was hoping, they had the old version on site for comparison drives, so Subaru obviously has a great deal of confidence that the MCR'ed car has noticeably improved in terms of its handling and ride. Looks like they were right according to these reviews.
Frankly, I can’t picture anything that packs more giggles for this little money.
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
URACK (07-05-2016)
Old 07-05-2016, 11:53 AM   #231
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Originally Posted by Stang70Fastback View Post
So, I know everyone was excited about the new Performance Package available on the 2017 - specifically the Brembo brakes. I tried to find information about the size of them in the PDF document, and couldn't find any direct information. Then I looked at the massive data spreadsheet at the end of the document. All the listed models for the US market had the same rotor diameter (294mm, which is ~11.5", which is the standard rotor size.)
On a whim, I looked at the Japanese models, and look what I found. I'm going to ASSUME that these are the Brembo rotors, considering that these models also come with the 17x7.5" wheels that you get with the Performance Package. If so, I'm seeing 326mm, which is ~12.8", which is ~1.25" larger than the standard size! A decent size increase!
This isn't an official confirmation, obviously, but it seems like a reasonable conclusion.
As for the Brembo brakes I guess they will probably reuse the same design as used in the 2002 Impreza WRX, since the FT86 uses also the WRX 293 mm brakes.
I quickly checked wicht parts Brembo offers for that WRX type and there is indeed a 326 mm disc listed.
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
The Following User Says Thank You to Flasher For This Useful Post:
Stang70Fastback (07-05-2016)
Old 07-05-2016, 03:04 PM   #232
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Can't quite figure out why they are going with a half-inch wider rim on the PP if they are not mounting a wider tire.....
The Following 2 Users Say Thank You to Sport-Tech For This Useful Post:
invaliduser (07-05-2016), Stang70Fastback (07-05-2016)
Old 07-05-2016, 03:12 PM   #233
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Originally Posted by Sport-Tech View Post
Can't quite figure out why they are going with a half-inch wider rim on the the PP if they are not mounting a wider tire.....
Scratching my head over that one myself.
Old 07-05-2016, 03:14 PM   #234
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
I'm running a 7.5 in wide wheel on the primacies.. definitely not ideal.
Sent from my Nexus 5X using Tapatalk
drew_kar is offline   Reply With Quote
Old 07-05-2016, 03:19 PM   #235
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
But I'm running 7.5 in wide wheel on stock size AS3s and it's perfect.
krayzie is offline   Reply With Quote
Old 07-05-2016, 03:27 PM   #236
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
It's to fit the Brembos up front without changing the characteristic of the tires too much.
Why not? Not progressive enough?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 07-05-2016, 03:42 PM   #237
drew_kar
drew_kar's Avatar
It keeps the progression of the stock setup (which I like). The slightly stretched tire gives a little better feel from what I can tell. I'm just tired of the primacies. I hope they go with a better tire for the performance package. On stock rubber and stock pads I feel as if I more braking power than grip.
The Following User Says Thank You to drew_kar For This Useful Post:
Bristecom (07-05-2016)
Old 07-05-2016, 03:48 PM   #238
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
1: to increase the effective tread width
2: to reduce tire squirm.
The wider wheel will stretch the tire somewhat, the section will stretch 1/4" for every 1/2" gain in wheel width. When you do that, the sidewalls angle slightly, allowing more contact with the shoulder blocks of the tire. So increasing wheel width actually will allow you to use more of that tire, within reason. (I would never recommend to exceed the tire manufacturer's recommended width range!)
The stretch in the sidewall preloads the structure in the sidewall, reducing the flex in it during cornering, keeping the car tighter in transitions. A lot of miata guys tend to follow this rule of thumb to maximize a certain tire size's effectiveness: keep the wheel width 1/2"-1" larger than the ACTUAL tread width.
*Actual tread width can vary wildly from tire to tire: a PSS is 7.7", a Primacy HP is 7.5 in the stock size. My current tires are 7.3" in that size.
-Josh
The Following 6 Users Say Thank You to Yoshoobaroo For This Useful Post:
Bristecom (07-05-2016), drew_kar (07-05-2016), invaliduser (07-05-2016), krayzie (07-05-2016), Sport-Tech (07-05-2016), URACK (07-06-2016)
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Official: 2017 Acura MDX Teased, Will Debut In New York! Bye Bye Bird Beak? vh_supra26 Other Vehicles & General Automotive Discussions 4 03-23-2016 05:30 PM
2017 FRS Official Facelift Pics Zhangy Scion FR-S / Toyota 86 GT86 General Forum 2 03-17-2016 05:06 PM
Official New England random discussion thread! PRORICAN New England 503 07-24-2014 04:08 PM
Official FA20CLUB Turbo Kit FAQ Discussion FA20Club.com Forced Induction 67 01-09-2014 12:06 AM
