| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: 2015 frs
Is the long tube header what caused the loss of the stock swaybar mounting position?
#30 | |
Drives: FRS Silver LS1 swapped.
#31 | |
That Guy
Drives: 2013 asphalt FRS MT
http://www.ft86club.com/forums/showthread.php?t=89789 |
#32 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
There's a reason why people should just spend the $$$ on a proven solution. I spent months trying to get ProEFI to work with my 2JZ swap, only to sell it and go with Emtron (which works). I didn't want to go with a piggyback or additional hardware. I didn't spend an arm and a leg, either.
#33 | |
#34 | |
#35 |
That Guy
#36 | |
Drives: Toyota
Emtron KV8 is in the $3K "range". By comparison, the Motec M1, costs thousands of dollars more. |
#37 |
Drives: 2015 frs
Thank to everyone for your input it is helping me out immensely. When I do the swap I will be using OEM GM ecu, exhaust manifolds,cats, intake manifold, and a canbus translator to get it bard in California after that I was going with itb's, lighter headers and a standalone ecu if needed. Emtron most likely.
#38 |
Drives: 85 corolla gts
Tuning itb's on the factory ecm I expect to be a pain in the ass. you will hit atmospheric at a much lower throttle opening position then 100%. that will cause your mapping to be less then ideal. If you are using a maf you would want to have both banks reading off of it for accurate fueling and ignition data. Go standalone, life will be easier. You can tweak things around to a point of mapping it, but it will never be ideal.
#39 | |
Road-hole
Drives: 2013 Whiteout FR-S
Did you read the part about him getting it reffed in cali? He can't use an after market ecu Jaden |
#40 |
Drives: 2015 frs
GM ecu to get through the inspection, and get my sticker. then upgrade to itb's ,and standalone ecu. Save the stock GM ecu, intake and exhaust manifolds to go back on when it is smog check time. Time to start ripping this thing apart.
#41 |
Drives: 2015 frs
@cf6mech did you get your can bus translator in the car and programmed yet? if so How is it functioning are you happy with it. I was in contact with @wutsaiu I ordered the parts he used and I will be using those parts and his program until i eventually go standalone. I will post a build thread when I have my swap 90% finished. just selling my old stuff and purchasing the new parts at this time. Probably Feb or March it should be completed for the most part.
#42 | |
http://www.mrs-electronic.de/english/home.html This engineer was requested by Flyin Miata and has already hooked them up for the V8 ND Miata conversion, and as I type working with a buddy of mine in Seattle getting his V8 BRZ computer talking to a GM ECU,.... and without data spikes,....Stay tuned to something being available commercially soon. Hopefully I'm a few weeks away (as I have been told)from getting mine working. |
| Switching to LEDs. Do I need CANBUS bulbs? | soilent | BRZ First-Gen (2012+) — General Topics | 11 | 01-07-2016 11:28 PM |
| Odb2/canbus flexibility | Futaba | Electronics | Audio | NAV | Infotainment | 1 | 08-25-2015 03:00 PM |
| CanBus Triple | xjohnx | Electronics | Audio | NAV | Infotainment | 8 | 01-31-2015 11:39 AM |
| Toyota codefest CANbus competition | robot | Electronics | Audio | NAV | Infotainment | 5 | 12-12-2014 03:11 AM |
| CANBus | pseudo | Electronics | Audio | NAV | Infotainment | 4 | 09-03-2014 01:11 PM |
