Old 07-03-2016, 05:11 AM   #29
Zer0
Drives: 2015 frs
Is the long tube header what caused the loss of the stock swaybar mounting position?
Zer0 is offline   Reply With Quote
Old 07-03-2016, 07:42 AM   #30
cf6mech
Drives: FRS Silver LS1 swapped.
Yes.........didnt quite under stand the reasoning ......... honestly I think it slipped by them........no one else seems to have an issue with the front sway who has done the swap.......if you were to ask me i would omit the long tube header and just go with this......https://www.holley.com/products/exha...arts/8501-3HKR not 100% these would fit yet....
cf6mech is offline   Reply With Quote
Old 07-03-2016, 08:16 AM   #31
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.ft86club.com/forums/showthread.php?t=89789
Old 07-03-2016, 12:27 PM   #32
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
There's a reason why people should just spend the $$$ on a proven solution. I spent months trying to get ProEFI to work with my 2JZ swap, only to sell it and go with Emtron (which works). I didn't want to go with a piggyback or additional hardware. I didn't spend an arm and a leg, either.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 07-03-2016, 12:34 PM   #33
cf6mech
Originally Posted by Calum View Post
Yes remember seeing those......even though the pics wont come up.....id be really concerned about the heat those things would generate for my purpose.....
Old 07-03-2016, 12:40 PM   #34
cf6mech
May go that way......but all i need is steering and want the factory tach.....thats it.....to me a stand alone just doesnt seem cost effective for those two items...... as of yet... who knows.....what did it cost if you dont mind me asking.......
Old 07-03-2016, 03:07 PM   #35
Calum
That Guy
I just wanted to make sure you knew it was it option.
Love watching your build.
The Following User Says Thank You to Calum For This Useful Post:
cf6mech (07-04-2016)
Old 07-03-2016, 06:50 PM   #36
boomslang
Drives: Toyota
Emtron KV8 is in the $3K "range".
By comparison, the Motec M1, costs thousands of dollars more.
boomslang is offline   Reply With Quote
The Following 3 Users Say Thank You to boomslang For This Useful Post:
cf6mech (07-04-2016), civicdrivr (07-05-2016), slicktop (07-03-2016)
Old 07-04-2016, 01:28 AM   #37
Zer0
Drives: 2015 frs
Thank to everyone for your input it is helping me out immensely. When I do the swap I will be using OEM GM ecu, exhaust manifolds,cats, intake manifold, and a canbus translator to get it bard in California after that I was going with itb's, lighter headers and a standalone ecu if needed. Emtron most likely.
The Following User Says Thank You to Zer0 For This Useful Post:
Old 07-04-2016, 03:34 PM   #38
Ross
Drives: 85 corolla gts
Tuning itb's on the factory ecm I expect to be a pain in the ass. you will hit atmospheric at a much lower throttle opening position then 100%. that will cause your mapping to be less then ideal. If you are using a maf you would want to have both banks reading off of it for accurate fueling and ignition data. Go standalone, life will be easier. You can tweak things around to a point of mapping it, but it will never be ideal.
Ross is offline   Reply With Quote
The Following User Says Thank You to Ross For This Useful Post:
Zer0 (07-04-2016)
Old 07-04-2016, 04:54 PM   #39
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Did you read the part about him getting it reffed in cali? He can't use an after market ecu
Jaden
Jaden is offline   Reply With Quote
Old 07-04-2016, 06:49 PM   #40
Zer0
Drives: 2015 frs
GM ecu to get through the inspection, and get my sticker. then upgrade to itb's ,and standalone ecu. Save the stock GM ecu, intake and exhaust manifolds to go back on when it is smog check time. Time to start ripping this thing apart.
Old 07-25-2016, 06:15 AM   #41
Zer0
Drives: 2015 frs
@cf6mech did you get your can bus translator in the car and programmed yet? if so How is it functioning are you happy with it. I was in contact with @wutsaiu I ordered the parts he used and I will be using those parts and his program until i eventually go standalone. I will post a build thread when I have my swap 90% finished. just selling my old stuff and purchasing the new parts at this time. Probably Feb or March it should be completed for the most part.
Old 07-28-2016, 05:29 AM   #42
cf6mech
Translator by AGT in Australia was a complete BUST.....believe me I tried everything to get this unit to work, spent many hours checking and double checking wiring diagrams.....and many other things,....spoke to a computer engineer in person, he opened the unit and examined it,....he said yes this could, (Ill empathize could work), but dont count on it to be seamless, he said that there will be data spikes occasionally that will cause your gauge to go off scale.....great!....but in my case none of it worked to worry about spikes.....didnt cost me anything as I was a tester except hours and hours in my garage in 100 degree heat.....so I guess I can be grateful for that....I know that there is video of this thing working,....but I'm done with it.....my next move is much more promissing....its a German based company that has a branch here in Ohio with an engineer thats a car guy......all they do is can-bus engineering on a much bigger scale
http://www.mrs-electronic.de/english/home.html This engineer was requested by Flyin Miata and has already hooked them up for the V8 ND Miata conversion, and as I type working with a buddy of mine in Seattle getting his V8 BRZ computer talking to a GM ECU,.... and without data spikes,....Stay tuned to something being available commercially soon. Hopefully I'm a few weeks away (as I have been told)from getting mine working.
The Following 3 Users Say Thank You to cf6mech For This Useful Post:
Calum (07-28-2016), civicdrivr (07-28-2016), wparsons (07-28-2016)
Switching to LEDs. Do I need CANBUS bulbs? soilent BRZ First-Gen (2012+) — General Topics 11 01-08-2016 12:28 AM
Odb2/canbus flexibility Futaba Electronics | Audio | NAV | Infotainment 1 08-25-2015 04:00 PM
CanBus Triple xjohnx Electronics | Audio | NAV | Infotainment 8 01-31-2015 12:39 PM
Toyota codefest CANbus competition robot Electronics | Audio | NAV | Infotainment 5 12-12-2014 04:11 AM
CANBus pseudo Electronics | Audio | NAV | Infotainment 4 09-03-2014 02:11 PM
