#281 | |
Drives: '22 BRZ
The Following User Says Thank You to DocWalt For This Useful Post: | strat61caster (05-17-2016) |
#282 |
Drives: '13 FRS - STX
Only a half inch where it matters
#283 |
anybody here did an 18x8 +35 up front and 18x9.5 +38 in the rear?
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
#284 |
Drives: 2013 Turbo FR-S Java Pearl
whiteout rpf1 gunmetal 17x9 +35
another one - *dj khaled voice*
rpf1's gunmetal 17x9 +35 toyo tires size 255/40 |
The Following 5 Users Say Thank You to Frs909 For This Useful Post: | dattran86 (10-04-2016), jliongh (10-15-2019), Josue Cafe FR-S (06-13-2016), SmartedPanda (06-30-2016), SuperTom (01-08-2020) |
#285 |
Drives: 2013 Asphalt FR-S
I'm interested in the 17x9 +35 RPF1s. I've got H&R Super Sports springs on right now. It sounds like these should fit my car ok but I'm confused if I will need camber bolts or not. If I do need camber bolts will I be alright with just the fronts or will I also need to get some for the rears? Thanks!
#287 |
Drives: 2015 Scion FRS
17x9.5
245/40 Toyo Proxes T1 sport ~1" drop ![]() |
The Following User Says Thank You to MobileSuit For This Useful Post: | s14sleepyeyez (06-30-2016) |
#288 |
Drives: pinto power
oops
#289 |
Drives: 2013 Argento Scion FR-S
#290 |
Drives: 2013 Subaru BRZ Limited (CBS)
I know this post is old, but goddamn, just wanted to give props to your RB build. Especially since you went with RPF1's as your wheel choice. Facking noice, friend. I think the wheels offset some of the wildness of the RB body.
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed 1996 Mazda Miata (Track car.) 2007 Suzuki SV650 (Track bike.) |
#291 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#292 |
#293 |
Drives: 2014 Raven FRS
Gunmetal 18x9.5 +38 with 245/35/18 tires, Stance coilovers and SPL lower control arms
#294 |
Drives: It alls slivery blue.
17x9+35 245/40 17 PSS
Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question | Victor Draken | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-19-2013 01:28 PM |
Track wheel Enkei RPF1 in 16" ?? | stockysnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-07-2013 09:13 AM |
