Old 06-20-2012, 10:29 AM   #1
SWAMechFRS
SWAMechFRS's Avatar
Drives: 2013 Scion FR-S Asphalt 6-Spd
Any plans for the Rear fog light?
I saw a thread on the rear fog light but no one addressed any plans to make it a functioning fog/brake light.
I think it would be cool to make it a flashing brake light for track use like the F1 cars have. Would need to be switched because I could see it being a problem for street use.
Anyone?
Don't Text and Drive
KCCO:happy0180:
SWAMechFRS is offline   Reply With Quote
Old 06-20-2012, 02:25 PM   #2
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
To answer your first question: YES
I'll post my results the first week of July. All your dreams will come true!
Lil Abner is offline   Reply With Quote
The Following User Says Thank You to Lil Abner For This Useful Post:
Filipino Royale (06-21-2012)
Old 06-20-2012, 02:28 PM   #3
HunterGreene
Hail Magnet
HunterGreene's Avatar
I'm tempted to make it a third reverse light, since the wiring is there already, but that might require some work depending on how it looks with the red in there.
Old 06-20-2012, 04:45 PM   #4
xcelir8brz
Drives: 2013 BRZ Limited
I prolly' will be working on it this weekend too!
xcelir8brz is offline   Reply With Quote
Old 06-20-2012, 06:49 PM   #5
Lil Abner
HA, the race is on! My parts aren't in for it yet, so you might win!
Old 06-20-2012, 07:35 PM   #6
robotvoice
Drives: 07 STI
For those who wire up the rear fog, post some pics to the rear fog thread I made: http://www.ft86club.com/forums/showt...light=rear+fog
And PLEASE don't be lazy and wire this up as a fourth brake light. That's not what the light is meant for.
robotvoice is offline   Reply With Quote
Old 06-20-2012, 08:58 PM   #7
Heero
Heero's Avatar
Drives: 2-door
I wonder how this would work out... will this work just like a regular light that you turn on when in Fog? Is its purpose served because it is so low to the ground making it more visible? Or do we need a brighter light? Also, how would be turn it on - my limited BRZ does not have front fog lights - so wondering how I would set it up.
Heero is offline   Reply With Quote
Old 06-21-2012, 12:04 AM   #8
robotvoice
Drives: 07 STI
Yes, the whole purpose of the rear fog light is to make it easier for cars behind you to judge their distance from you in bad weather. It's as simple as that. If you add in the correct sized bulb and wire it up, it should have the same intensity as your brake lights. You can either run it to your front fog light switch (if you have one) or run it to an independent switch in the cabin. It looks like there are plenty of switch blanks in the interior of this car so finding a place for a switch should be a non-issue.
Old 06-21-2012, 06:34 AM   #9
Lil Abner
Bingo! But now the question is, what size bulb is suppose to go in there? My guess is a 921 bulb. A 7440 seems a bit large for that small light.
Old 06-21-2012, 08:39 AM   #10
robotvoice
Drives: 07 STI
It might be a 7440. What size are your reverse lights? It will be either that or very similar.
Old 06-21-2012, 08:53 AM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Reverse lights are 921s. I'd personally like to do the rain light with a 7440 for it's 25W output instead of the 921 with it's 17.5W output. But it's a lot easier to find small 194 sockets which the 921s will fit into than the larger ones for the 7440.
I'll have to dig further.
Old 07-01-2012, 12:21 AM   #12
eiye19
Drives: 2013 Subaru BRZ Limited GBS DZE
found a youtube video of someone that already hooked it up.
[ame="http://www.youtube.com/watch?v=46v0w4OuECg"]Subaru BRZ Tanabe Medalion Exhaust Launch! - YouTube[/ame]
eiye19 is offline   Reply With Quote
The Following User Says Thank You to eiye19 For This Useful Post:
86design (07-01-2012)
Old 07-01-2012, 01:19 AM   #13
notFRS
Drives: BRZ Sport-tech
This is clearly going to be a million thread topic:
Try searching, there are already multiple people working on getting these working.
It's not a 3rd brake light nor should it be hooked up as one, you already have this in your rear window. It should be activated as a rear fog and thats it.
From a 30 second search, there are more but these are the 3 more current and relevant:
http://www.ft86club.com/forums/showthread.php?t=9961
http://www.ft86club.com/forums/showthread.php?t=9819
http://www.ft86club.com/forums/showt...rear+fog+light
notFRS is offline   Reply With Quote
Old 07-01-2012, 03:42 AM   #14
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
thats me
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Rear Fog Light Thread robotvoice Cosmetic Modification (Interior/Exterior/Lighting) 38 03-11-2023 01:32 PM
Red triangle on rear, fog light? eriktherod Scion FR-S / Toyota 86 GT86 General Forum 50 12-22-2012 07:22 PM
HID Yellow Fog Lights and Rear Halogen Fog Light Lighting Red Cosmetic Modification (Interior/Exterior/Lighting) 35 06-29-2012 09:57 PM
Facebook IPO's today. Any plans? SVTSHC Off-Topic Lounge [WARNING: NO POLITICS] 21 05-21-2012 09:28 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
