#995 | |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | FingR-S (06-27-2016) |
#996 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Some batteries can't handle it. Rob tried quite a few before settling on the Big Crank's. I went with 4 audio batteries to get lower resistance. This gives a quicker dump and a quicker recharge rate. One of these days I'll find someplace to just put the pedal to the floor, and hold it down, to see how low these batteries go. The lowest I've seen so far is 23V, and they bounced back to 28V in a minute.
If I say yes, will that make you think I understand?
#997 |
Still 17!
Drives: 2014 Silver BRZ Limited
The reason the voltage is dropping so fast and then climbing back up again is because the batteries are being over taxed. You're not draining the batteries down and recharging them, you're drawing them down and then they are recovering.
Normal battery recharge takes time...it doesn't happen in minutes...These are not Lithium Polymer batteries..and they take at least an hour to fully charge. The same way as if your car doesn't start and you keep the starter turning for 8-10 seconds. Only this is doing that on a regular basis. Which (I've always understood) is murder on the batteries...
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
#998 |
Drives: FR-S,GTI
My batteries lasted for about two years. And they're the cheapo Power Sonics. So much for "murdering" them.
#999 |
Drives: FR-S,GTI
Oh
And by the way, my STARTER battery died first. Long before the dump batteries. |
#1000 | |
Actually, those aren't the batteries used by everyone else
#1001 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Hey kool! The odyssey batteries pc-680s are the new recommended dump batteries. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#1002 |
You've got to be kidding me. They are weaker in every way. 16 AH and only 170 CCA. How could these possibly be better?
#1003 | |
Less chances of shorting I'm assuming. But per Rob these are the recommended batteries now. Sent from my iPhone using Tapatalk
#1004 | |
Drives: White 2014 BRZ
Did I miss something? When did he (Rob) say that?
JDL Turbo kit - Ecutek, HRI tuned.
#1005 |
A few people are running it this way, and the new kits will be recommending it. The Odyssey batteries are safer to put into series then the big cranks. Sent from my iPhone using Tapatalk
#1006 |
Hmm ok. On paper in seems like a downgrade. Anybody butt dyno yet?
#1007 | |
No butt dyno yet. Hopefully soon. What's interesting though is that it takes longer to charge up then the big cranks so they hold their charge better. Also supposedly the Odyssey is capable of supplying a higher cranking amp for a short burst (5 seconds) which may also be why Rob chose them. Sent from my iPhone using Tapatalk
#1008 |
Still 17!
As I said in my original post. I am trying to figure out how it is that the batteries are lasting any time at all.
Not that you guys are doing something wrong....just that my experience tells me that the batteries should not last long at all..... so much for my experience huh? ![]() Pax
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
