#99 | |
Drives: Japanese
and oh an AWD would def. ruin the vehicle but adding a little more power through N/A or supercharger would be nice.. I mean why not subaru isnt this their first RWD car (correct me if im wrong I dont really know subaru's) why not toss a superchager or let it be an N/A beast.. |
#100 |
Drives: Attitude
Why would they want to build a mini STI? Get yer heads outta yer asses guys, it's not happening.
#101 | |
Drives: CBS BRZ Limited 6MT
Back in (Crystal) Black.
#102 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I'm thinking the cries for a small, turbo, AWD coupe will be answered with the new clean-sheet WRX |
| The Following User Says Thank You to Draco-REX For This Useful Post: | Chewie4299 (06-24-2012) |
#103 | |
Reap the BReeZe
Drives: 04 LandShark STi
You don't seem to care that Imprezas are not lookers, or that the best looking one (yet still quirky) we got in the states wasn't turbo (2.5RS). I'll assume the TT was a joke. I mean, why not just get a 911 GT2 RS, right? That would be the target. Turbo, check. AWD, check. Looks, check. Affordable... 3 out of 4 ain't bad. Some people like different things, and options aren't bad for anyone. They're just options. It's not like they'll stop making NA BRZs if a turbo model is added to the lineup. You're mind doesn't have to change if someone on the internet has a different opinion. It's all good. Buy the NA version if it makes you happy. People still bought 289 Cobras when the 427 was available. Some are happier with the lighter motor. Others aren't satisfied without the brute force. In general, are the totally anti any turbo people also defending the Prius tires? The car may be the best vehicle many have ever owned (or will soon own), but that certainly doesn't make it perfect. |
#104 | ||
Drives: '06 AM V8V Coupe
On the other hand, a turbo is "peaky", and maximum boost anywhere needs to be limited. You can put a small turbo that peaks early in, but it'll choke the power at high rpm and the gains will be nonexistent. You can put a slightly bigger turbo with a very free flowing turbine in for high end boost, but the "turbo lag" will suck ass and so will the response. You can make the turbine more restrictive and limit boost through wastegates and stuff, but you lose efficiency, and backpressure will be sapping close to what the supercharger is sapping. Turbos make a lot more sense when you want big boost. |
#105 |
Kuruma Otaku
It's called the next WRX, people...
Platform sharing, much?
Because titanium. |
#106 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
Any of you guys against superchargers, I dare you to go find someone with a rotrex-equipped Miata. Driving one of those almost made me want to sell my turbo and convert my turbo miata to a rotrex miata.
#107 | |
Drives: 07 Impreza Wagon, 04 F150
Yes, it's cheaper than the Audi TT... but not by much. The TT does have an expensive DSG auto tranny, and some stuff only in the Limited BRZ (Alcantera leather seats), which is probably the rest of the expense. What other turbo AWD vehicles are under $30000? The WRX($25.5k), the Lancer Ralliart ($28k), and....? I looked and found nothing else. Subaru has 2 options for you... Turbo AWD = WRX. NA RWD = BRZ. About the same price, very different choices made during design. Like a 'gaming laptop', any attempt to cram all the features together will probably come out bigger, heavier, and more expensive than you'd like. |
#108 | |
As for the TT, I was being perfectly serious. If a WRX base price is $25,595 and a WRX STi starts at $34,095, what makes you think the BRZ's base price of $25,495 isn't gonna jump nearly $10k with AWD and a turbo, too? $38k for an Audi TT is a relative bargain, and it ticks all the boxes of what everyone seems to want: light weight, all-wheel-drive, turbo, quick, sexy and affordable. It effectively is what the BRZ would be with AWD and a turbo, except with an aluminum space frame. What exactly does a $200k limited production über-Porsche have to do with this argument? And BTW, the GT2 RS is rear-wheel-drive
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 06-20-2012 at 06:34 PM. |
#109 |
AWD will never happen on the BRZ but I fully expect to see a 35K turbo version next year. Subaru makes turbo engines so as much as a supercharger would be great it's not going to happen.
#110 | |
BR-Zizzle
Subaru also makes nothing but AWD cars, so as much as an FR Subaru would be great it's not going to happen
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ 1986 Toyota Corolla GT-SR5 1985 Toyota Corolla SR5 |
#111 |
I just can't see the point of a turbo. Shed some 100-200lbs in weight, remove the rear seats if need be, more aggressive suspension tuning, bigger brakes, better exhaust and intake, and a better ECU tune. You'd have a 2500lb car with 250-275hp. This car doesn't need a turbo.
Everyone is obsessed with FI to the point where if it isn't turbo then it needs to be somewhere along the line. I had a 240SX with an SR swap that weighed about 2300lbs, had 300hp, and made every attempt to kill me. 250-275hp in a 2500lb car is plenty fast enough. AWD is not even an option on this. Every single part of the front suspension and chassis would need modifying to even get close to accepting the required AWD components. Adding almost 300lbs worth of weight to the front end and only bumping hp to 300 would result in almost exactly the same 0-60 times but with worse handling characteristics.
| The Following 3 Users Say Thank You to Zadkiel For This Useful Post: |
#112 | |
Reap the BReeZe
![]() Perhaps it's just me, but low end Audis don't do it for me anymore. In fact, none of the alternatives thrown out in here spark any interest for me. I don't actually think they will make an AWD version, but I still don't see what's wrong with wanting. We can call it a BRX if it makes everyone feel better. If they don't make one, it will just make my life more difficult. Maybe even a hybrid would be OK, with just electrics on the front. Hey, how about a full on diesel electric hybrid, and put the motor wherever you want. ![]() I'm still holding the prediction of a turbo for MY 2015. It's going to happen. |
| [Norcal] *Works is looking for an R&D car | Lonewolf | Southern California | 8 | 06-09-2012 04:38 AM |
| Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? | HitTheGas | BRZ First-Gen (2012+) — General Topics | 12 | 02-21-2012 01:24 PM |
| Who here works for Toyota and/or Scion? | PAImportTuner | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-28-2011 12:38 AM |
| Who works on your vehicle? | Midship Runabout | Other Vehicles & General Automotive Discussions | 23 | 09-25-2011 02:57 AM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
