Old 06-25-2016, 09:39 PM   #15
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
Unfortunately I don't know much more than you. You could get a tuners opinion but Subaru won't give a shit cuz they are the "experts". Maybe if you took them to court but obviously we don't want to fuss with that. It seems very unlikely that you would have a flash from the wrong year. Other than they are probably lying to you and there likely is nothing you can do I can't offer much help
I understand well nonetheless I appreciate your time just even reading my incredibly long story up to this point.
Jordan Silveira is offline
Old 06-26-2016, 12:46 PM   #16
Ashikabi
Ashikabi's Avatar
I had an idea. Could the ECU have been replaced with the wrong model years ECU? Maybe it wasn't flashed but the whole unit replaced(which would then have the wrong flash on it). Is there a vin or post number that could be matched to your cars VIN?
Ashikabi is offline
Old 06-26-2016, 02:20 PM   #17
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I would refuse any payments to the current subaru shop you are at. Currently you are at the mercy of the rep theyre sending out. If the rep from SoA provides you with warranty coverage, get that baby towed to another shop and never go back. If they deny you the warranty I would immediately get my car towed back home and figure out what you are going to do from there. DO NOT let the current douche working on your car continue to work on your car. Refuse any payments and tell them to see you in court.
tofurun is offline
The Following User Says Thank You to tofurun For This Useful Post:
kritch (06-28-2016)
Old 06-26-2016, 02:21 PM   #18
tofurun
tofurun's Avatar
If this was the case why would it all of a sudden stop working out of no where? Wouldnt this show up on a car fax if it was done by any reputable shop?
tofurun is offline
Old 06-26-2016, 05:08 PM   #19
Ashikabi
Ashikabi's Avatar
I don't know... really that's the weird part is why did it happen suddenly ? Op mentioned looking at security footage for someone flashing the car, what about a quick ecu swap on the complete other side of the vehicle? I'm pretty stumped, it was just one tiny clue I thought he could check
Ashikabi is offline
Old 06-26-2016, 06:11 PM   #20
tofurun
tofurun's Avatar
The thing is a Cobb ap shouldn't work at all. The device has to pair with a car and once it's paired it can't be used on another vehicle is my understanding. The access port is very persnickety from my experience. Makes you wonder if for some reason a wire or something got cut or crimped during the tint installation. Idk what they did to install the tint. Maybe car died while tinting and it's something as simple as a bad battery. What I don't get is why the shop doesn't just slap a new battery in it and reset the Ecu and go from there. The whole 2015 Wrx tune is bull crap IMO
tofurun is offline
Old 06-26-2016, 06:22 PM   #21
Jordan Silveira
@tofurun You are 100% with me on that one. I won't be trusting them to do anything further with the car. Believe me, I am already worried about them trying to exact revenge because I opened up a case with SoA. I know this is clear paranoia but a part of me says if my car didn't have a tune prior to entering the dealer, it sure does now. Again, I know that sounds preposterous but I just don't trust the dealer especially after I was called a liar despite me going through all I've done in the last week to say otherwise. As for the COBB stuff, the service manager called me later in the same day to say he was inaccurate and upon speaking with a SoA technician about the readings, it was a 2015 BRZ profile and that the calibration ID/numbers were off which is why he still claims the car was "tuned/flashed"
@Ashikabi Thank you for the suggestion. I mean I guess it could be possible but I doubt the car was really ever tampered with. I bought it with a 193 miles as used. Who really goes and purchases a tune or tuning equipment with the car that new? I still believe the dealer did a half assed diagnosis. As for the tint, all that was done is my doors were left opened as the tint was being done. they did something with where the door latches were that the owner described as them disabling the auto window roll down when we open our doors. From that point everything looked on point. They drove the car out of the bay to a parking spot with the doors ajar as to not close anything. They then had a worker go around and clean up any solution residue etc on the car but that was it. It is an extremely reputable shop that has 5 stars on yelp and I have used them before and others I know have with zero issues. Nonetheless I appreciate the suggestion
Old 06-26-2016, 11:52 PM   #22
Ashikabi
Ashikabi's Avatar
Officially out of ideas
Ashikabi is offline
Old 06-27-2016, 01:05 AM   #23
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I wouldn't look into any of these bizarre theories until you try a new fully charged battery. It won't attempt to crank on half arsed voltage.
Wayno is offline
The Following User Says Thank You to Wayno For This Useful Post:
Jordan Silveira (06-27-2016)
Old 06-27-2016, 08:05 AM   #24
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Speaking of wild theories....
Did you actually see the car being driven out of the bay at the tint place? If you weren't there they could have pushed it out. Look around and see if one of the employees there has the same car as you. <tin foil hat time> It's possible one of the employees had a flash go bad, brick their ECU and they did the ole' switcharoo and you ended up with the brick.
If you drove it in to the tint place and the car worked then went to start it up and it didn't- the tint place is liable for the repair.
guybo is offline
Old 06-27-2016, 08:17 AM   #25
Ashikabi
Ashikabi's Avatar
This is pretty much what I was suggesting. It's just such a weird occurrence I think all possible theories have to be pretty wild. What would happen if they hooked up the battery backwards? Is that even possible?
Ashikabi is offline
Old 06-27-2016, 08:54 AM   #26
At no point in this saga have I seen any indication that the battery power was checked. The car is known to have sat for hours (if not a whole day) with the doors open which means lights were on.
"The vehicle had full electricity from alarms, stereo, lights, etc. However, the engine would not turn over (crank)." Has low battery written all over it.
Car won't start? Step one, check battery power.
Tcoat is offline
Calum (06-28-2016), JazzleSAURUS (06-27-2016), kritch (06-28-2016), Tectoniic (06-27-2016)
Old 06-27-2016, 09:06 AM   #27
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Can you PLEAAAAASE go hook the car up to a voltmeter? RIGHT NOW? I wanna know!
JazzleSAURUS is offline
The Following 4 Users Say Thank You to JazzleSAURUS For This Useful Post:
brandonblt2 (06-27-2016), kritch (06-28-2016), Tcoat (06-27-2016), Tectoniic (06-27-2016)
Old 06-27-2016, 09:20 AM   #28
Ashikabi
Ashikabi's Avatar
I've actually had this fail, battery read 12 volts but wouldn't crank. I'd suggest new battery all together
Ashikabi is offline
Subaru trying to deny my warranty please help! Jordan Silveira BRZ First-Gen (2012+) — General Topics 173 08-02-2016 07:28 PM
Subaru trying to deny my warranty please help! Jordan Silveira Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-30-2016 09:46 PM
Subaru trying to deny my warranty please help! Jordan Silveira Issues | Warranty | Recalls / TSB 21 06-30-2016 09:30 PM
Subaru trying to deny my warranty please help! Jordan Silveira Southern California 10 06-30-2016 08:52 PM
Subaru trying to deny my warranty please help! Jordan Silveira Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 02:25 AM
